09-26-2019, 04:02 PM | #1526 |
Re: Whose on Steelies? Post 'em up!
09-26-2019, 06:56 PM | #1527 |
09-27-2019, 12:11 AM | #1528 |
The Drop is 5.5 in the front. 2.5" drop spindles and 3" drop coils. Front rubs a little at full turn. We've since went with a 2" drop spring. The rear is a FlipKit with one leaf pulled and helper airbags installed for hauling and trailering duties. So it's about a 6 or 7 inch drop in the back.
09-27-2019, 12:15 AM | #1529 |
Thanks, I'll try to get installed pics once I get the truck back on the road.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
09-28-2019, 04:53 PM | #1530 |
My .69 C20 with new 16" x 8" steel wheels
09-28-2019, 11:02 PM | #1531 |
Still running on factory wheels and hubcaps. Couldn't see myself dumping them.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades. Formerly known as mtndewmaniac66. |
09-28-2019, 11:29 PM | #1532 |
16s with caps
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
09-29-2019, 01:32 PM | #1533 |
Just bought this from original owner it has Chrome Reverse he put on truck from dealership before he took truck home! He bought 5 one for spare! I didn't even know they made them and they took original caps he got the truck in Sept 71! Tks Bill
09-29-2019, 02:04 PM | #1534 |
Here is a double take. My son in laws K10 hauling my Longhorn home.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
09-29-2019, 02:20 PM | #1535 | |
Thanks, other Larry
09-29-2019, 04:30 PM | #1536 |
Carpe manana
Hi Larry - love your pic btw, too cool. Springs came from Alcan Spring in Colorado. Zero lift stock height built to order w USA steel. No body lift. The 33" tires bump it up a bit. I'm happy with the stance as I can scramble in/out pretty easily.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-29-2019, 04:48 PM | #1537 |
Obviously I like the stance on your truck too (along with everything else about it).
You may not remember, but, this is the truck I was going to get when I contacted you in Albuquerque. My plans changed in California and it was early morning when I came back through so I didn't bother you. Anyway, I have it apart now and I may as well put in new springs. It looks like it sits a little low in the front. http://67-72chevytrucks.com/vboard/s...d.php?t=755797
09-29-2019, 04:56 PM | #1538 |
Carpe manana
Nice! Thanks for the link. I'm on board.
I re-arched the OEM springs on the K20. What a waste of time/money. The ride quality was substantially improved with new springs. I also replaced the plastic liners/anti-squeak spring pack pads with the new springs. One of the major truck vendors sells small asphalt pads for use between the bed to frame mounts. I used those at the time of the build. Maybe it quiets the ride a little bit. Maybe not. These didn't alter the body lines at least.
09-29-2019, 09:44 PM | #1539 |
Leaf Springs
' re - arching ' leaf springs is an old time scam ~ they ride higher again for a short while then poop out again, money wasted .
The teflon spring sheets really work wonders at making the rig ride smoother while still retaining the height and load capacity . Beware cheapo springs ! . Diamond or Eaton are both very good and there used to be plenty of other American spring manufactures .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
09-30-2019, 10:47 PM | #1540 |
...not quite road ready ,but rolling again.
10-25-2019, 12:04 AM | #1541 |
...all back together again.
10-25-2019, 09:37 AM | #1542 |
On The Road Again
Good deal, looking nice .
12-06-2019, 03:07 PM | #1543 |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
12-06-2019, 04:41 PM | #1544 |
12-06-2019, 06:39 PM | #1545 |
1970 C20 with 16X7 steel rims.
12-06-2019, 08:04 PM | #1546 |
12-07-2019, 11:37 AM | #1547 |
Looks great! Like the black paint, don’t see many of those.
Incapable of not thinking about my truck at least every other minute |
12-07-2019, 11:48 AM | #1548 |
12-07-2019, 11:49 AM | #1549 |
02-01-2020, 10:18 PM | #1550 |
Here are my steelies.
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). |
