#1526 |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
#1527 |
Post Whore
Re: Restoring Rusty
since the brake fluid did not come through for me, I wasn't going to allow that to be a show stopper [get it - brake fluid...] I'm on fire today
I decided to call up my friend Walter. Now many of you know that The Greg is a One Clown circus act, but when a friend offers to help, who am I to say no... So The Greg and his buddy De Walt working together stripped the paint off that fender in 5 minutes flat, things were going so well they even decided to stripped the paint off the belly too now why strip the paint if you is just going to turn around and paint the thing? well if you look see closer, you will see that cancer lurks beneath the paint, that my friend is the evil we effectionaly call RUST |
#1528 |
Re: Restoring Rusty
Yup. Meanwhile the wheel bristles end up flying off and hitting everything, including me!
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
#1529 |
Re: Restoring Rusty
Dude I love this thread. You're just fixing every little thing like I do. If it's not broken, clean it up and put it back on!
#1530 |
Re: Restoring Rusty
#1531 |
Re: Restoring Rusty
Stupid wire brushes! I hope your wearing a face shield using that.. I've had a few of those come loose and lodge in my face and hurt. Coveralls I've had look like a porcupine attacked me.
#1532 |
Post Whore
Re: Restoring Rusty
Always
#1533 |
Post Whore
Re: Restoring Rusty
Tomorrow
#1534 |
Post Whore
Re: Restoring Rusty
got the inner fender all cleaned up and hung it up in the paint booth, then it was 1.5 coats of Rust-Oleum Rusty Metal Primer (cause that's all a single spray can has)
Sunday we'll shoot some undercoating on it's belly... |
#1535 |
Post Whore
Re: Restoring Rusty
then it was back to the crappy power steering pump, check this out this is the $80 dollar one from Carquest
it came soaked in power steering fluid (despite the pink blanket) and the warning stickers just slid right off of it, well taking some paint with them at least the pulley slid right on this one, that's why I chose it over the one from O'Reillys I think I'm gonna touch it up with some semi flat black paint once all mounted up |
#1536 |
Post Whore
Re: Restoring Rusty
wrapped up the afternoon by giving the frame rail a second coat of POR15
#1537 |
Re: Restoring Rusty
Inner fender looks great! Hope your new pump works okay. Good luck at the swap meet tomorrow.
#1538 |
Post Whore
Re: Restoring Rusty
scored sum finned chevy valve covers for $20 bucks at the swap meet today
#1539 |
Post Whore
Re: Restoring Rusty
this can't be good... this is the underside of my hood after I POR15ed it a couple weeks ago
#1540 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
Fish-eyes are oil contamination of the paint. You didn't get it perfectly clean. Not surprising considering that it's the bottom of the hood.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#1541 |
Post Whore
Re: Restoring Rusty
so tried another brand of paint stripper in a spray can on those $20 dollar swap meet valve covers, and just reaffirmed myself to not waste any money on those and just buy the larger containers of the jelly like stuff you brush on, I have now officially spent more on the paint strippers than those covers, LOL
but with about three coats and some elbow grease scrubbing, they did improve, I will work on them some more later on and maybe put them on in a couple months when I mount the alternator lower, you see we have to re route all the wiring so it's hidden Hot Rod style |
#1542 |
Post Whore
Re: Restoring Rusty
shot the Rust Oleum undercoating on the inner fender today and was disappointed with the results
remember last time I used this product on the other side, and it left a puddle of liquid over night as I was waiting on it to dry, well this time it let me down by not drying all lumpy bumpy you know with that rough texture we expect, it just dried smooth, weird - and I did shoot two coats I am done with this product, I saw that they have a Professional version of it, so I may try that, of course it costs almost twice as much |
#1543 |
Post Whore
Re: Restoring Rusty
1. fix rear brakes - DONE
2. replace or fix left headlight - DONE 3. fix left rear turn signal - DONE 4. check out the lifter / rocker arm ticking noise 5. refresh the power steering - DONE 6. fix hazard signals - DONE 7. get the AM radio working 8. fix reverse lights - DONE |
#1544 |
Re: Restoring Rusty
Keeping it moving. I'm parallel processing with you.
Make sure you share how you reinstall the steering gear box. I'm concerned about how to get the Pitman arm back on so that that the steering column is correct. |
#1545 | |
Moderator
Re: Restoring Rusty
The best paint and powder coat primer for aluminum is anodizing but die cast parts are notoriously difficult if not impossible to anodize because of the way the alloys flow into the molds. I would shy away from anodizing these.
#1546 | |
Post Whore
Re: Restoring Rusty
Seriously though you should be ok, end to end is about 3 to 3.5 turns, so turn it all the way to one end, then turn it all the way to the other and count the revolutions then put the splines in the middle, the pitman arm when on points almost towards the driver, trial and error won't hurt either, put it on and twist the steering wheel if you are a tooth off pop it off and adjust (of course without driving, but when parked) Last edited by Gregski; 04-20-2015 at 10:10 AM. |
#1547 | |
Post Whore
Re: Restoring Rusty
#1548 |
I know the pieces fit
Re: Restoring Rusty
Do you have a build thread going yet?
#1549 |
Re: Restoring Rusty
#1550 | |
Moderator
Re: Restoring Rusty
SWMBO wouldn't like it if you used her range for powder coating or baking parts. It takes forever to get that burning oil smell out of the house... ![]() ![]() ![]() ![]()
