Old 02-14-2014, 11:00 PM   #1551
gdavis
gdavis's Avatar
Re: 1968
I started sand blasting the hood today. Worked untill the shadows started to cover my work. then it was to hard to see so I stopped. Tomorrow I will finish the hood and maybe put on some primer and see if there is any bodywork to do.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 02-14-2014, 11:02 PM   #1552
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by bpotter05 View Post
^^ agree with that!
yea I know it is cold up there guys. I follow the weather and I am thankfull I live in Florida. We are the only state in the us that has no snow on the ground.(except for Hawaii) Got a few more parts in today. Maybe I will get what I need to start something. Seems like I only get parts that i don't need now. Waiting for the money to get right before I get the wiring harness.
Check out Patches
Old 02-15-2014, 09:06 PM   #1553
gdavis
gdavis's Avatar
Re: 1968
Today I finshed sand blasting the hood. What a job. At 65 it took it all out of me. I am spent. I also sand blasted the door hinges. There was 4 layers of paint and primer on the hinges.
picturs before I sand blasted
pictures after I sand blasted
My 80 lb sand basted done all it could do today. You can see some of the black primer in square spots.
I then sand blasted the 4 hinges
I ordered a 15'' chrome over flow tank
door sill plates also chrome with Chevrolet boetie in the middle
door felt kit for both doors
ingition and door keys
i am hopeing to prime the hood and hinges Monday. I got the parts in the shop where no moisture can get to them untill Monday.
Check out Patches
Old 02-16-2014, 09:54 PM   #1554
gdavis
gdavis's Avatar
Re: 1968
Today I welded up the wear spot on the shifter mount to frame. It had a little wear and now it don't. Getting ready for the shifter to be installed.
Also made a deal on a rear bed sill. Who said that things don't go your way. Thanks Steve from Texas.
Check out Patches
Old 02-17-2014, 09:00 PM   #1555
gdavis
gdavis's Avatar
Re: 1968
Today, I welded up the pin holes in the front of the hood. 3 holes. Applied some bondo and now tomorrow I wll sand and prime the hood.
Check out Patches
Old 02-18-2014, 09:14 PM   #1556
gdavis
gdavis's Avatar
Re: 1968
Well today did not go as planned. I did not get to work on the hood. Had to put a new water pump in the washer for the wife. But I did get some more parts in today.
a set of arms for the sun visors.
a set of sun visors
Check out Patches
Old 02-19-2014, 02:46 AM   #1557
Bomp
Bomp's Avatar
Re: 1968
Sweet lookin visors.
Hood looks real clean too.
Bomp is offline   Reply With Quote
Old 02-19-2014, 09:30 AM   #1558
Low Elco
Re: 1968
Work's lookin' good, G! Keep at it!
Low Elco is offline   Reply With Quote
Old 02-19-2014, 10:04 PM   #1559
gdavis
gdavis's Avatar
Re: 1968
Thanks I got them from another board member. He was selling and I needed them.
Check out Patches
Old 02-19-2014, 10:05 PM   #1560
gdavis
gdavis's Avatar
Re: 1968
Thanks man I try every once in a while. The weather is being good to me now. 76 high today
Check out Patches
Old 02-19-2014, 10:24 PM   #1561
gdavis
gdavis's Avatar
Re: 1968
Today I got a lot done on the old girl: and also got a lot of parts in:
I also fixed the small hole with bondo and primed the hood.
a felt window kit for both doors
a set of door sill strips with Chevrolet boe tie in the middle
cowl seal
hood bumper set
set of tail gate chains for the step side tail gate
ignition and door locks with matching keys
glove box and ash tray bumpers
switch retainer benzil
set stanless steal outside mirrow arms
outside mirrow arm gaskets
blue dot reflectors (2)
radiator over flow tank (15 inch)
rear in cover gasket 12 bolt
angle for the wood bed pair
angle covers for the wood bed
jam door switch (2)
running board chrome bolt set
inside mirrow mounting plate
outside mirrow arms screws (6)
67/68 grill mounting clip (28)
wind shield wiper mount ground strap installed
inside rear view mirrow arm
I am hopeing to get the paint this week so I can start painting some color
Check out Patches
Old 02-20-2014, 08:02 PM   #1562
gdavis
gdavis's Avatar
Re: 1968
I pulled the wiper motor back off the truck today. I installed the new ground plate on the wiper motor and re-installed it on the truck.
Check out Patches
Old 02-20-2014, 09:00 PM   #1563
cees
cees's Avatar
Re: 1968
Originally Posted by gdavis View Post
Today I primed and painted most of my front end parts. Going to paint the linkage orange and uppers and lowers arms black alone with the frame. The shocks were almost new so I gave then a coat of paint also. Just could'nt put dirty shocks on a nice and painted frame.
someone take the orange paint from him! quick! lol
cees is offline   Reply With Quote
Old 02-22-2014, 01:44 PM   #1564
cubber
Re: 1968
looks like you have been getting lots done, George! I have been fixing up our new house, so I have only had time to do that and work. It helps me to see that you are still getting some things done. Keep up the good work!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 02-22-2014, 08:05 PM   #1565
gdavis
gdavis's Avatar
Re: 1968
That picture and post were a long time ago. I repainted them black so no one has to take the orange paint from me.
Check out Patches
Old 02-22-2014, 08:07 PM   #1566
gdavis
gdavis's Avatar
Re: 1968
Yea I understand about working on your home. I am doing it also. I am making our office larger. I will turn it into a bedroom for the oldest boy. And the office will joint our master bedroom.
Check out Patches
Old 02-22-2014, 08:10 PM   #1567
gdavis
gdavis's Avatar
Re: 1968
Today I went through some of the new parts. I needed to take a inventory of the parts in my mind again. That way I don't order them a second time. I hope to paint the truck this week for sure.
Check out Patches
Old 02-22-2014, 08:12 PM   #1568
litew8
litew8's Avatar
Re: 1968
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-23-2014, 06:11 PM   #1569
69sinker
69sinker's Avatar
Re: 1968
Let's see a pic!
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 02-24-2014, 08:30 PM   #1570
gdavis
gdavis's Avatar
Re: 1968
Today I went and picked up the paint for the truck. I bought a new spray gun also. Maybe tomorrow I will shoot some color on the hood. Trying to do too many thing at once just isn't working out. Got to many project started and none finished. The little wife is starting to complain.
Check out Patches
Old 02-25-2014, 10:10 PM   #1571
gdavis
gdavis's Avatar
Re: 1968
Today, I finished the sanding on the hood. Then I shoot some color on it also. I painted it in the shop so nothing would get in the paint.
Check out Patches
Old 02-26-2014, 02:23 AM   #1572
Xeen
Xeen's Avatar
Re: 1968
The hood looks good George.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-26-2014, 10:14 PM   #1573
69sinker
69sinker's Avatar
Re: 1968
Looks great! That orange looks sharp.
Old 02-27-2014, 01:04 AM   #1574
gdavis
gdavis's Avatar
Re: 1968
thanks a lot. I hope t paint the rest of the truck maybe this next week.
Check out Patches
Old 02-27-2014, 01:13 AM   #1575
gdavis
gdavis's Avatar
Re: 1968
Today I went down to Tarpon Springs and seen a fellow board member. He rebuilt my steering column. What a difference it made. I also got all the right parts for my shifter from the column to the transmission. I also got a new rag joint and I hope to install It this week in. Got so much to do I don't know what to do first.
This is what I will want to install this week.
steering column
steering shaft
rag joint
shifter from column to transmission
If I get these parts installed it will be a lot done. The key work is IF
Check out Patches
