09-15-2015, 11:29 PM | #1601 |
Re: What did you do to your truck today part III
Made some progress over the weekend. Sorry about the sideways pictures, any tips to rotating them? They were not sideways on my computer.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
09-16-2015, 07:34 AM | #1602 |
Registered Truck Offender
No T-man,, the whole truck once it's back to a more street friendly version (unless someone were to make me an offer for it with the 660HP motor and all,, it's going to eventually)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-16-2015, 05:03 PM | #1603 |
Been trying to finish blasting my frame,but keep blowing holes in the ball valve on the blaster hose. Already been through 4 valves in two bags of media. Ordered some stainless steel one today,so maybe next week I will have some new pics. Finally cooling off enough to get motivated. Only problem with that is now its Deer season.lol
09-16-2015, 05:51 PM | #1604 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
09-16-2015, 06:08 PM | #1605 |
Oh I love the progress,just not the heat,lol
09-16-2015, 06:46 PM | #1606 |
headlights quit on me Saturday night after leaving a local cruise. So I figured I had better figure it out with Goodguys coming up this weekend in Bowling Green.
Narrowed the problem down to the dimmer switch. Had some high resistance in some terminals. So cleaned them up and did a little solder job. Put it back together and still no luck. I would get power when I pushed down on the switch so I took it back apart. I filled the dimples in the spinner wheel with solder and now all is well. I guess it had worn and created enough clearance that it would not make good contact.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
09-16-2015, 07:14 PM | #1607 | |
09-16-2015, 07:33 PM | #1608 |
Thanks, Probably should have bought a new one, but did not want china junk.
09-17-2015, 10:01 AM | #1609 |
RKS NICE work on the PS adapter.
Bruce, I admire your tenacity - fix'n what you got - love it. I just bought a dimmer from NAPA and we'll see how long it lasts. Last night I finished wiring and shrinking all my connections in the home-made harness going aft for lighting and fuel sender. Turned out good. Added ground wires in several places too. Blazer tank filler and vent hose added. Tightened bed mounting bolts and touched up some paint underneath. I'm trying to get it back on the floor so I'm buttoning up everything I can think of underneath! So I installed and ran the speedometer cable my buddy gave me... now to bleed the brakes and sit it back on the tires. |
09-18-2015, 06:09 AM | #1610 |
Didn't get the brakes bled but I plinked a bit anyway
Turned the re-pop Stock gas tank cover into a back panel, finished my Civic door seals, rebuilt my instrument panel, modified my glove box door. |
09-18-2015, 08:36 PM | #1611 |
Still have yet to bleed the brakes, but I do have doors that close and latch now.
09-19-2015, 06:32 PM | #1612 |
Loads of stuff, captured in my build thread.
However, also removed the old steering column..... And tried out the "new" one. Understood to be from a Chevy Day van of unknown vintage. Possibly 80/90's I was wondering if anyone knows what it's cable operated section is for? If you turn the ignition key beack and push it in after turning it to the "off" position, it activates a cable in there, but then you cannot remove the ignition key. This component is in the way where I need to fit the column,so needs to be removed, but I have no idea what it's purpose is. Advice and help appreciated. Thanks as always.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
09-19-2015, 06:47 PM | #1613 |
meowMEOWmeowMEOW
I wiped the '66 down with some detailing spray....
...then went and beat on a Ferrari 360 Spider for a while
09-19-2015, 08:51 PM | #1614 |
I didn't unload my spare 10si alternator from the vacation car so it came along for the ride to Seattle, BC's sunshine coast, back to Seattle and finally home to Calgary again. This upsets me that I didn't have a place for it so on to the 66 C10 today it went. It only took about an hour and a half including the conversion from externally regulated. The bearings in the old one feel a bit rough so that's a good excuse to drop it off for recycling at a local alternator shop.
09-20-2015, 01:50 AM | #1615 |
I rebuilt my first carburetor but by the time it was done I was out of day light . So never got to test it and see if I did it right or not lol
09-20-2015, 02:04 AM | #1616 |
Since switching jobs. I now work in the town I live in so I took my new daily driver to work so pumped to be driving it consistently now.
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
09-21-2015, 01:24 AM | #1617 |
Officially bolted the '82 C30 front suspension into my '62 temporarily. Installed Hydro Boost onto bracket. Mocked up steering shaft. Stared at rear of frame for an hour contemplating brackets for new fuel tanks. I guess you could say I now have power steering and disk brakes!!
09-21-2015, 06:59 AM | #1618 |
09-21-2015, 02:37 PM | #1619 |
Paul Y wins. Truck, chopping wood, beer can never be beat.
All I did was load a small block and th400 into my s10 and brought them home. Small block needs to be rebuilt, so that will be my life for awhile.
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
09-21-2015, 08:07 PM | #1620 |
Almost done with the inside of a bedside, gotta finish welding up the outside Sean from the long to short conversion, the smithing about what coating it's going to get. Rust run is on it now to prevent rust u till I figure out if it's getting por15 and bedliner or...
Posted via Mobile Device |
09-22-2015, 12:39 PM | #1621 |
Dry fitting the tanks.
09-22-2015, 06:04 PM | #1622 |
I likr those tanks...Are they the standard Blazer style tanks?
09-22-2015, 06:11 PM | #1623 | |
Possibly one of the best posts iv seen on this forum in a while. Well don't amight
09-22-2015, 06:24 PM | #1624 |
Thank you Matt, appreciated.
P. |
09-22-2015, 11:17 PM | #1625 |
Got the motor and trans out today. Good thing my boys came to help out. We had a tough time pulling the hoist back into the garage through the gravel. lol
66 shorty |
