Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 07-01-2013, 05:37 PM   #1626
jserrato714
jserrato714's Avatar
Re: SoCal checkin' in
City of Orange in the house...Are you guys taking that cruise to Sd on the 20th? Keep me posted in so down...I which I still had my Sb 68 chev but I guess my 77 blazer will have to do.. If that's kool...
jserrato714 is offline
Old 07-01-2013, 06:14 PM   #1627
vegadesign
vegadesign's Avatar
more than likly, im hoping to gear my rearend before then to save some gas.
the more the merrier!!
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline
Old 07-03-2013, 08:14 PM   #1628
VDOG
Grand PooBaa Member
VDOG's Avatar
Yes its still on for the 20th. I will work up a flyer or something tonight and post it up tomorrow.
VDOG is offline
Old 07-03-2013, 11:26 PM   #1629
hopped up
hopped up's Avatar
found this pic of me and john and a couple other gud i dont know thier names. helping push tootsie into the brothers show[IMG][/IMG]
hopped up is offline
Old 07-04-2013, 02:22 AM   #1630
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
From left going counter clockwise..
Andy "hopped up"
John Oro
Eric Superflystieny
David "Wildf4wheels"
In the back is I believe travis "truckmanloco"
JOHNORO is offline
Old 07-06-2013, 01:23 PM   #1631
69Rumbler
69Rumbler's Avatar
Any one on here know a good mechanic ?? I found some one but dude not to reliable and really don't know as much as he says he dose lol .. But I guess that what happens when you have a 350 every one can fix it lol
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline
Old 07-06-2013, 02:30 PM   #1632
vegadesign
vegadesign's Avatar
me but i dont think you wanna drive 2 hours to have it worked on lol
Old 07-06-2013, 04:06 PM   #1633
Dano69c10
Dano69c10's Avatar
Hey VDog!
Do you still want them 15"x8", 6-lug rallys?
Let me know.
Thanx
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 07-06-2013, 04:50 PM   #1634
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by Dano69c10 View Post
Hey VDog!
Let me know.
Thanx
Dano
Kinda, but I really only need one. So im going to pass. Dang I was just talking to someone that needed a set.
VDOG is offline
Old 07-06-2013, 04:56 PM   #1635
VDOG
Grand PooBaa Member
VDOG's Avatar
San Diego GTG Cruise
July 20th, Lets get a show of whos interested.
http://67-72chevytrucks.com/vboard/s...d.php?t=587224
VDOG is offline
Old 07-06-2013, 06:06 PM   #1636
dlh760
dlh760's Avatar
I'm in on the San Diego gtg/cruise. Hey Dano69c10 what are you wanting for those rallys?
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go
dlh760 is offline
Old 07-07-2013, 12:41 PM   #1637
jserrato714
Hey 69 try craigslist...there are knowlegable dudes there..just ask them some questions and depending on there answer you can weed out the good,the bad, and thee ugly..lol
I will look for my old mechanic...dude was a beast..plus he was mobile...good luck
Old 07-07-2013, 12:52 PM   #1638
69Rumbler
69Rumbler's Avatar
You have his number maybe he not to far from me
Old 07-07-2013, 02:02 PM   #1639
JOHNORO
JOHNORO's Avatar
What are your issues ?
JOHNORO is offline
Old 07-07-2013, 02:06 PM   #1640
69Rumbler
69Rumbler's Avatar
Cylinder issue one of them is not firing ... I check the order ... Timing ... Just out all new wires cap and rotor .. So I have no clue what to do ... And now it starting to back fire when intake my foot off the gas ( some times ) noting to bad but it still dose it
Old 07-07-2013, 02:42 PM   #1641
Lee H
Lee H's Avatar
HEI or Points? Use the timing light to find which cylinder is not firing, then swap a wire to see if that changes anything.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 07-07-2013, 02:48 PM   #1642
VDOG
Grand PooBaa Member
VDOG's Avatar
How are the plugs? Right gap, fouled out, still sounds like timing to me.
VDOG is offline
Old 07-07-2013, 03:31 PM   #1643
hopped up
hopped up's Avatar
sounds like timing to me too. do you have a holley carb? could be a power valve issue
Old 07-07-2013, 09:14 PM   #1644
jserrato714
Its been a while since i contacted him....but i agree its your timing..move your dizzy around ...what exactly is it doing?have you checked compression? I had the same problem with my 350..timing was dead on but i had a cracked valve...motor had a cam and other goodies that it ran but had no power...
Old 07-08-2013, 02:45 PM   #1645
69Rumbler
69Rumbler's Avatar
it an HEI ... i just changed everything and adjust the time and now im changing the intake gasket then going from there you can heard a leak from it .. then going to set the timing again its Cylinder 2 thats not working
Old 07-12-2013, 03:26 PM   #1646
C0UCH
I'm having similar troubles with mine. About two months or so ago I replaced the fuel pump, carb (Edelbrock 1405), fuel filter and air cleaner, plugs, wires, cap/rotor. Ran solid after up until about a week ago. Rough idle when in drive/reverse (running right around 650 rpm in drive). Sluggish acceleration but once going it runs strong.
I replaced the fuel filter but no change. Pulled the idle screws and blew everything out but I'm thinking I'm going to have to pull the carb apart and clean it completely out. I can't find any vacuum leaks.
C0UCH is offline
Old 07-13-2013, 03:44 AM   #1647
VDOG
Grand PooBaa Member
VDOG's Avatar
Thats a timing issue. Could be your vacuum advance. I had to go with an adjustable vacuum advance to correct my timing issues.
VDOG is offline
Old 07-16-2013, 02:55 AM   #1648
Nitroblood
Nitroblood's Avatar
It's possible that either the cam and crank gears are not lined up, dot to dot or the distributor gear is off the cam gear by a tooth. Just a thought(s)
1972 C / 20
Nitroblood is offline
Old 07-16-2013, 11:44 AM   #1649
VDOG
Grand PooBaa Member
VDOG's Avatar
Nitro, where you been bro? Hows the family?
VDOG is offline
Old 07-17-2013, 09:13 PM   #1650
69Rumbler
69Rumbler's Avatar
got everything working just trying to figure out the kick down switch on my th400 .. i got an edelbrock Carb .. anyone have any pictures of some connected ? i seen the B & M one but i have no idea how it would work are to hook it up ..
Thanks in advance
