Old 04-20-2010, 10:05 AM   #1651
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
As for the A/C, I decided I would take it to another friend to have him pull a vacuum on the system first to be sure there are no leaks. And while it's hooked up to his machine, he just a well go ahead and charge it too!
I drove him to work today, and he was very happy to get out on the interstate and stretch his legs!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-20-2010, 10:20 AM   #1652
glock35ipsc
Just got off the phone with Chris (Powell72), he is going to come over and get the truck in the morning and charge up the A/C.
Bob
Old 04-20-2010, 11:00 AM   #1653
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I think Bobs next vendor sale should be LS swap A/C hoses for those of us using the LS compressor in the stock location...Everyone agree? I know I would like a set....
--Josh
Old 04-20-2010, 11:25 AM   #1654
glock35ipsc
Hmmm, that might be possible....
And for those that are planning on using the stock LS compressor, here's the finished install. It's a little tight, but very do-able. The A/C hoses are the two coming out on either side of the lower radiator hose with the split loom on them.
As soon as I can figure out what my techno-wiz son did with my camera battery charger, I'll get some better pics.
Bob
Old 04-20-2010, 12:23 PM   #1655
6772owner
Gearhead
6772owner's Avatar
Looks awesome Bob, glad you finally figured out all the hoses, connections, compressor, etc... Now theres no excuse to stay cool!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-20-2010, 01:34 PM   #1656
glock35ipsc
Now theres no excuse to "not "stay cool!
On another note, I just got off the phone with a guy in Denver that answered my Craigslist add looking for an LS block. He has an aluminum LS1 block with holes in two cylinders that he is going to give me. Hopefully I can start working on a swap kit in the near future.
Road trip to Denver this Saturday!
Bob
Old 04-20-2010, 02:42 PM   #1657
Jhogan830
Jhogan830's Avatar
bob! im diggin EVERYTHING you have been doing with your truck...and ive stealin some of you ideas =P keep on keepin on!
84 chevy LWB-350 vortex heads and longtube headers baby blue...will be black soon...
Jhogan830 is offline   Reply With Quote
Old 04-20-2010, 02:43 PM   #1658
Jhogan830
Jhogan830's Avatar
just hard to wrk on you truck when u have a GF skewl and parents...and dnt rlly have alot of know how...hahahahah
Old 04-20-2010, 02:56 PM   #1659
glock35ipsc
Concentrate on your skewl work my man!
Bob
Old 04-20-2010, 03:16 PM   #1660
STOCKISH
STOCKISH's Avatar
Definately. The trucks will always be there. Get a good education or you'll wind up like me turning wrenches for a living. While it's a pretty darn good living it's very hard on the back. Use your head for work. Work smarter, not harder.
--Josh
Old 04-20-2010, 03:17 PM   #1661
STOCKISH
STOCKISH's Avatar
Bob, I'm glad to know I'm not the only anal one who turns all the hose clamps in the same direction to make them look nice!
--Josh
Old 04-20-2010, 05:45 PM   #1662
glock35ipsc
Yep, busted!!
Something else that made me smile a few minutes ago...... my two pesky little leaks that I had are now gone! The lower trans cooler fitting on the radiator was leaking just enough to make the tank wet. A few wraps of teflon tape cured that.
And the temp sending unit doesn't leak anymore either. It was leaking between the sending unit itself and the adapter Mcbassin made for me. I pulled it out, cleaned off all the teflon tape and replaced it with pipe dope. Good and dry now. I'm most happy about this one, because I hate the smell of anti-freeze burning as it drips on the manifold!
Bob
Old 04-20-2010, 05:55 PM   #1663
JohnC
JohnC's Avatar
A trick my cousin did on his Camaro was to get a larger hose clamp that had the solid band instead of the little holes in it. He then cut it down so that it was small enough to use on smaller hoses. Then he turned the actual screw part to the bottom side of the hose. So all that is left to see is the solid look of the band, and the little holes and the screw tightener is on the bottom out of sight.
JohnC is offline   Reply With Quote
Old 04-20-2010, 06:06 PM   #1664
glock35ipsc
I like that idea!
Bob
Old 04-20-2010, 06:16 PM   #1665
6772owner
Gearhead
6772owner's Avatar
Bob, if you are around the Arvada area, drop by and help me wrench.
Old 04-20-2010, 06:18 PM   #1666
glock35ipsc
Whatchya got going on? I have to run down to Littleton Saturday morning, but I need to be turned around and back home pretty quickly.
Bob
Old 04-20-2010, 07:39 PM   #1667
bigdnew
Never Satisfied
bigdnew's Avatar
thank for help and allowing all of us to glean from your wisdom. so if the motor doesn't need a return line where is the return line going.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 04-20-2010, 07:50 PM   #1668
glock35ipsc
The return line will go from the Vette filter/regulator back to the tank. On the sending unit, there will be three ports: feed (largest), return (middle bear), and vent (smallest).
Bob
Old 04-20-2010, 07:53 PM   #1669
bigdnew
Never Satisfied
bigdnew's Avatar
no the port that says return line from engine, did you just block it off.
Old 04-20-2010, 07:59 PM   #1670
glock35ipsc
I've talked to sooooo many people the past couple of weeks regarding fuels systems, I'm starting to get all you guys mixed up!! Your engine has only one line on it that needs to go to the tank, and that is a feed line, the silver line that has duct tape on the end. That one runs to the single port side of the Vette F/R. On the other side of the F/R, the outer/offset port if the feed that goes to the outlet of the tank, and the center is the return that goes to the return port at the tank.
Where are you seeing "the port that says return line from engine"? I'm not sure what you mean by this.
Bob
Old 04-20-2010, 08:08 PM   #1671
bigdnew
Never Satisfied
bigdnew's Avatar
let me look at my diagram when i get home. i swear on the switching valve there is a port for a return line from engine that we do not need. i am probaly mistaken. sorry to confuse.
Old 04-20-2010, 08:15 PM   #1672
glock35ipsc
OK, my bad, I forgot about a switching valve. I'm with you now. Like I said, I've been talking to a BUNCH of people!
Your return line setup will go like the: A line from the sending unit to the switching valve, then the switching valve to the F/R. That's where the return line's job ends.
Your feed line setup will go: From the sending unit of each tank to the switching valve, switching valve to the F/R, the F/R to the engine.
Blue lines = feed
Black lines = return
Left side of pic is front, right side is rear.
Bob
Old 04-20-2010, 08:57 PM   #1673
bigdnew
Never Satisfied
bigdnew's Avatar
oh we were on the same page.
Old 04-20-2010, 09:12 PM   #1674
glock35ipsc
Phew! Was I able to answer your question then?
Bob
Old 04-20-2010, 09:14 PM   #1675
bigdnew
Never Satisfied
bigdnew's Avatar
look i rebuilt the rear end today but the wiring and plumbing confuses the crap out of me. got me head wrapped around the underneath side of the fuel, now gotta figure out how to wire the dash switch.
