Closed Thread
Old 01-30-2015, 07:16 PM   #1701
sKnNyPpY
sKnNyPpY's Avatar
Re: What did you do to your truck today? Chapter II
New PUI door panels and OER arm rest/door pulls. Going back in black replacing original but red painted split panels and pulls. I liked the older look, so didn't do '71 panels.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 01-30-2015, 07:31 PM   #1702
67Slider
67Slider's Avatar
I installed my fire extinguisher. Fit pretty good on my seat rail. Attached it with stretchable fabric and velcro so it releases quickly and is easy to grab. I also took her out for a nice cruise and filled her up with gas.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-30-2015, 08:07 PM   #1703
BugzC10
BugzC10's Avatar
Attachment 1356947
Attachment 1356948
I like your door panels. Did you by the PUI Skins or Pads?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 01-30-2015, 08:12 PM   #1704
sKnNyPpY
sKnNyPpY's Avatar
I got the full wrapped 'pads' from Summit. Off and on easy peasy. My only issue is there are no screw holes to affix them at the bottoms, I will either use some emblem tape like I did with the matching headliner or make my own holes. I did have to get longer machine screws for the passenger side armrests, they wouldn't quite bite. Ace Hardware solved that for .30 cents. Can't wait to put in black carpet, too. Thanks!
Name:  Headliner and Wheel.jpg
sKnNyPpY is offline
Old 01-30-2015, 09:27 PM   #1705
Possmguts
Possmguts's Avatar
Attachment 1356972
Snap clips cant be used with the screw holes in the door?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-30-2015, 09:34 PM   #1706
sKnNyPpY
sKnNyPpY's Avatar
That is a good option, I would need to figure a way to attach to the back of the panels without going through the vinyl or if they had a large enough base glue them on...ideas?
sKnNyPpY is offline
Old 01-30-2015, 09:48 PM   #1707
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
This wouldn't be for *everybody". But because I wanted it to be an easy on/easy off, I drilled holes in the panels and installed plastic "christmas tree" connectors.
It's a commitment (), but they'd not show up at all on that black.
Oh! Were you talking about the arm rests? If so, sorry.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-30-2015, 09:54 PM   #1708
Possmguts
Possmguts's Avatar
Something like this would only require a small slit in the backer and not going through the vinyl.. http://www.cjponyparts.com/door-pane...dNGhoCotzw_wcB
Old 01-31-2015, 12:24 AM   #1709
70CHEVYBB
70CHEVYBB's Avatar
Shortened my steering column by 2 inches. Losta more room
70CHEVYBB is offline
Old 01-31-2015, 01:07 AM   #1710
ElKotze
ElKotze's Avatar
Replaced my rubber fuel line with a braided one. Also organized my spark plug wires a little bit with some of those fancy-shmanzy wire separators. I just don't like them touching valve covers and headers....
ElKotze is offline
Old 01-31-2015, 01:13 AM   #1711
magwakeenercew2jh
Pics and tricks?
I know we have threads on this, but I'm interested in doing it while the truck is sitting on jacks in the garage.
During my build, I didn't shorten the column (crash sliding bar). I have the tank in the cab. And, I had late model
buckets in at first. Now, with the bench seat, it's too snug in there for me.
Yeah, I could lose some weight. I keep trying.....
Right now I have the column dropped in the cab and the dash out for a amp:volt gauge changeover.
So, I figured this would be a good time to get some more er, "tummy room".
-Did you shorten it while the column was still attached to the rag joint?
-Did you move the reverse switch to the engine side of the fire wall?
-If you pulled the whole column to do the mod, how tough was it to get to the
bolts on the rag joint from underneath?
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 01-31-2015, 08:40 AM   #1712
BugzC10
BugzC10's Avatar
Nice clean look...I did the same with the wires
BugzC10 is offline
Old 01-31-2015, 08:49 PM   #1713
hardwaycooke
hardwaycooke's Avatar
Well..I finally put a 7 qt Moroso oil pan on my stroker. Only had to remove engine mount bolts, tranny mount, and drive shaft, then lift and move it all toward the rear 2 inches so the pan would fit...wow!!
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline
Old 01-31-2015, 10:18 PM   #1714
70CHEVYBB
70CHEVYBB's Avatar
Originally Posted by magwakeenercew2jh View Post
Pics and tricks?
Thanks.
I pulled the column out and cut 2 inches out. I did this 4 inches before the nut switch mine is not working anyway. I used a pipe cutter for nice straight cuts and cut the shaft with a cut off wheel. I then ground the ends almost to a point and used a piece of angle to hold everything straight to weld it back up. I will post a pic tomorrow. It does give a lot more room but I would not go more often Han 2 inches as it makes the steering wheel closer to the seat. I do have a grant 13.5 inch wheel on it
Old 01-31-2015, 11:05 PM   #1715
cooperhw
cooperhw's Avatar
Cut the roof and cab back off my 68 C30 and a donor cab today. Hopefully get them both cleaned up tomorrow and welded back together. Hang the doors back in place and maybe get started getting her running next.
Sounds easy, right, ?????
We'll see.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 02-01-2015, 02:15 AM   #1716
Saclandman
Saclandman's Avatar
Finally found some 8mm HEI plugs wires that fit. Needed the long ones for a 75 Corvette 350. Also mocked up the fuel line to the carb. Getting closer.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 02-01-2015, 02:25 AM   #1717
Greasey Harley
Greasey Harley's Avatar
Installed a cd player, adjusted the lifters, cleaned the valve covers, installed new valve cover gaskets, replaced 2 "u" joints, topped it off with non-ethanol-premium, Drove it like I stole it.
Greasey Harley is offline
Old 02-01-2015, 08:25 PM   #1718
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
My friend in the local truck club is repairing and painting my console for me. So far so good. Before and after with primer.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 02-01-2015, 08:53 PM   #1719
85burb
85burb's Avatar
Fixed turn signals, stop lights, and figured out what was wrong with my wipers. Just got it yesterday. 67 c20. Factory 327/400 and ac. That's it. No power brakes or steering. Kinda a strange combo. Hope to get it registered and inspected in a few weeks.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline
Old 02-01-2015, 09:07 PM   #1720
cooperhw
cooperhw's Avatar
We'll see.
Well, Yesterday the roofs came off and today the new roof and cab back went into place. Still got a lot of welding and a bit of hammer/dolly work but "Homer got a new hat". Been wanting to tear into this thing for about a month and couldn't. That changed yesterday. Rock and roll.
Later,
Wayne
cooperhw is offline
Old 02-01-2015, 10:17 PM   #1721
Gobuffalo
Gobuffalo's Avatar
Got the fuel pump mounted in the tank for my LS swap.
Gobuffalo is offline
Old 02-01-2015, 11:38 PM   #1722
greywurm
Tightened up my headers and removed the AC compressor from the serpetine setup that I have. Installed the replacement pulley. One of these corrected the loud tapping noise. I suspect the headers.
Then took her out for a drive through wine country with the wife before the Superbowl.
Also organized all my tools during the quick tune up. I sure have a lot of extras.
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline
Old 02-03-2015, 11:38 PM   #1723
magwakeenercew2jh
Sunny day today in the California foothills. Ambled out and uncovered the truck. The dash is still out. Steering column was loosened to
drop down for dash clearance. Has been for a couple of weeks so I could make the amp:volt gauge change-over.
Popped the hood. Next thing I knew, a couple hours had passed and I had the steering column out. And the "crash link" and rag joint
were out on the bench for shortening.
Slides just right for the adjustment. It's all cleaned up and painted. Waiting for the paint to properly dry.
Maybe it'll be sunny tomorrow.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-04-2015, 11:16 PM   #1724
ReconDaddy
Well, I tore down the front end on Sunday. After changing hub bearings and seals, inner axle seals, spindle bearings, and axle u-bolts, I got everything put back together today. I used a black gasket maker, can't remember the brand, instead of a gasket. Since it was so cold today, I will let it set up over night before I add fluid. The ball joints and tie rods are the only things I have not replaced south of the steering column since I got the truck. I have already put new calipers, pads, frame to caliper brake line, steering box, tires and shocks. The only reason for not replacing ball joints and tie rods were they are solid and have no play. I also put a new set of Warn Hubs. I had a little trouble getting the driver side hub assembly in. The two differences I noticed about these hubs from the old ones are no spring on new ones, and was not able to see or get snap ring on grove of the end of the axle on both sides. Problem? I was able to get the large ring in. Lessons I learned on this project are when you are just starting, tools for a job can be more expensive than the parts for the job you are doing. Its better to have the right tool the first attempt to save time, money, and frustration. I did gain confidence to move onto something else. Not sure what is next yet. I am thinking maybe all new brake system. I want to say thank you to those that answered my questions.
ReconDaddy is offline
Old 02-07-2015, 06:03 PM   #1725
85burb
85burb's Avatar
After getting our 67 inspected and registered yesterday I figured it was time to do some mantinance. Removed cowl and installed new antenna and cleaned that area out. Fixed rear reveres light socket. Changed engine oil and filter. Flushed coolant and put new coolant in with a new cap. And let the wife and daughter wash it. Also ordered new tires and power disk brake set and rear lowering springs. Looks like maybe next weekend will be very busy.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
85burb is offline
Closed Thread
