05-14-2011, 12:42 PM | #151 |
Re: Post Your Straight Six Pics!
thanks
Some progress is better then no progress |
05-14-2011, 09:45 PM | #152 |
Here's what I've done lately to my 250 in the green '68:
Power brakes and HEI Here's a few more sixes waiting their turn for rebuilding. The twins. Two 292's. I'm going to take both to the machinist and have him tell me which is the best. I'll build them both, but only the best for my Panel: The cleanish one is the 230 that was in my Panel when I bought it. It would start up today, but it has suspect pistons. One was broke when I got it, which I replaced, and I broke another one, which I also replaced. The dirty one is a 250 that has a hole in the top of the number five piston. The V-thingy is a '68 327 that I pulled out of a donor 'Burb. I bought it from the original owner and he swore that the motor had never been apart. BUT-it's hard to see in this picture, but it has mis-matched heads. The one on the left (driver's side) has mounting holes and the other one don't. Thing is, nothing was ever mounted in the holes-they what looks like 40 years of build-up in them!: Parts and more parts: So many motors. So little time. And money.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green Last edited by pritch; 05-14-2011 at 09:47 PM. |
05-14-2011, 10:32 PM | #153 |
the casting marks on the heads on that 327 are EXACTLY the same as my mismatched heads on my 66K 327 in my 68 C30... I wonder if they were short of the new alt. hole small block heads and needed to use some of the old powerpak heads on the side that didnt need 'em???? And I LOVE all those 6's... im gonna try to pull a 292 out of a 65 C60 tomorrow!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
05-14-2011, 11:25 PM | #154 |
That's pretty wild! I have a better picture of it somewhere around here. I'll see if I can find it.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
05-14-2011, 11:34 PM | #155 |
Well, I thought I had better pictures
This one shows how the alt. was mounted: And this one is with the alt. removed-see the mounting holes in the head? Looks like nothing ever was in them. Maybe we should work out a trade, then we would both have a matched set! I never have taken off the valve covers to see just what heads they are. The motor is promised to my friend's kid, who is building a '67 chevelle.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green Last edited by pritch; 05-14-2011 at 11:35 PM. |
05-15-2011, 02:53 PM | #156 |
Heres the 250 heart that drives my 69
_____________________________________ Dennis 1969 C10 250 w/3 on the tree - project/weekend warrior 2010 Subaru Impreza - daily driver |
05-15-2011, 11:32 PM | #157 |
I have two cars with engine six cylinders.
Chevrolet Veraneio 1967 - engine 261 - turbo The Pick Up Chevrolet Caravan 1976 - 250 (original) changed the piston engine increasing to 268 The car Note: Engine 250 is the most common and used in Brazil ... Great topic!!!!!
# Chevrolet - Veraneio 1967, engine 4300cc (261) 6-cylinder turbocharged. http://67-72chevytrucks.com/vboard/s...=1#post4632834 # Chevrolet - Caravan 1976 http://www.hotcampinas.com/nuke/modu...=696826#696826 # VW - Santana 1987 http://www.hotcampinas.com/nuke/modu...104&highlight= |
05-17-2011, 07:30 AM | #158 |
Love that turbo rig in the Veraneio. Gives me an idea about resurrecting my longtime-downed '67K/10 Suburban with a 292 on turbo, w/TH700R4//NP205 thru to military surplus 3.08 axles . Used to run w/ a 454 BBC/TH350//NP205 to 3.73 posi Corp 12 bolt.
Obviously, with gas at more than $3.60/Gal a bigblock with 6-8MPG is not a good bet. Maybe a lump-ported L6 head. Maybe rigged for propane as fuel. Propane pistons. It would be nice to see that old white whale rolling again.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-17-2011 at 07:32 AM. |
05-17-2011, 12:28 PM | #159 |
Six in a row makes it go...
Painted my 250 with the POR-15 stuff:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
05-17-2011, 02:06 PM | #160 |
Grandpa in the rustmobile...
How ya like POR15 paint shifty?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-17-2011, 02:12 PM | #161 |
The paint itself is very tough. I put it on according to the directions - it was a lot of work and it didn't "self-level" as much as I thought it would.
My buddy sprayed his engine with epoxy primer and then used the POR-15 color coat on top. He thinned it and sprayed it using thin coats. It looks great.
05-17-2011, 04:04 PM | #162 |
Scrapper 1
Here on the west coast every one pulls out the inline 6 engines and its a shame I feel if you build it and gear your truck right with a 250 or a 292 with a th350 or 400 and then use a gear vender One that i do like is the guy that used the 700R4 with a gear vender made a good runner with a 410 rear gear last gear came out to being a 2.73 for the over drive
05-22-2011, 07:18 PM | #163 |
update. It should be running very soon!
05-28-2011, 02:25 PM | #164 | |
06-12-2011, 03:30 AM | #165 |
Got it running again today and back together!! Just waiting on my radiator mounts to finish it up. Well, I guess it'll actually never be done, but you know what I mean!
The before, just as a reminder!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 Last edited by 72BlckButy; 06-14-2011 at 07:54 PM. |
06-12-2011, 03:13 PM | #166 |
slick copper.......... the glass fuel filter is not a good idea above the exhaust manifold.
06-13-2011, 12:39 AM | #167 |
Huh.....I never thought about it. Don't really know where else to put it though. Any ideas?
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
06-13-2011, 06:15 PM | #168 |
Here is my set up out of my 1968 Chevy LWB Step Side. I think it is a 292 and my trans is an automatic, but I don't know what it is for sure yet. Just picked the truck up recently.
R/
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 06-13-2011 at 06:17 PM. |
06-13-2011, 07:30 PM | #169 |
KEEP ON TRUCKIN'
My Dad's '57 pic-um-up.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
06-14-2011, 06:37 AM | #170 |
Looks like a 292 L6. The Longbed was rare on 1/2 ton stepside models.
06-14-2011, 10:44 AM | #171 |
Definitely a 292, the fuel pump is behind the motor mount and the lifter covers are 6" tall.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-14-2011, 03:34 PM | #172 | |
My before pics are similar.....Maybe I'll try that. What paint did you use and anything else you lend for advice would be great. Again nice job!!!! |
06-14-2011, 07:52 PM | #173 |
Tot Roddin'
Any update? Inquiring minds want to know.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-14-2011, 07:54 PM | #174 | |
Tot Roddin'
Would you mind posting some up close pictures of the powersteering setup you have? Would like to see some shots of the brackets, pulleys and the overall setup. Thanks for any help you can provide.
06-15-2011, 12:38 AM | #175 |
>>Got it running again today and back together!<<
I'd like to see pictures of that PS bracket as well. Is that an existing setup that you have some run-time with. I would expect belt slipping and squealing with that setup. The belt contact on the Alt has to be less than 40 degrees of the circumference. The water pump pulley has less than 90 degrees, but it does have two belts. You may want to consider having one belt on the PS pump as it is now. The other, shorter belt around the HB, Alt and water pump would make greater contact on those two pulleys. With AC I have the Alt belt by itself. The other water pump groove is used by the AC belt. You can see that the PS belt makes insufficient contact on the Alt pulley. A friend of mine had a long water pump extention and flex fan on his '67. At rpm when the flex fan straightened out, it was out of balance. He let it go and the fan flew out through the hood. Cut through it like butter.
'67 GMC 2500, 292, 4spd, AC |
