Old 03-20-2010, 12:21 AM   #151
tommys66
Re: Tommys66 Build
Originally Posted by ruffrida2005 View Post
Do you think you will have any problem with only running that external cooler?
Don't know for sure. I seen where others have used these and I asked them, they said it works fine.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 03-21-2010, 07:30 PM   #152
tommys66
Re: Tommys66 Build
I tried to use the stock plug wires with the headers. The drivers side has plenty of clearance, but only one wire on the pass side clears. Do they make these wires with a 90 on the plug end?
Old 03-21-2010, 09:07 PM   #153
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Tommys66 Build
You could always buy some custom wires and make your own to fit. That's how my mallory set is.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-21-2010, 09:31 PM   #154
rcrahn
rcrahn's Avatar
Re: Tommys66 Build
Originally Posted by tommys66 View Post
I purchased some fittings from Doc's Blocks, for the A/C compressor. These allow room to hook up the hoses without notching the frame.
Awesome! Just the information I needed. Thanks so much for sharing it.
rcrahn is offline   Reply With Quote
Old 03-22-2010, 10:48 AM   #155
TimE
Hey Y'all!!
TimE's Avatar
Re: Tommys66 Build
Wow! Those headers do fit nicely Tommy. Looks reeaaaalllyy nice. Can't wait to get back to "laying hands" on mine. Keep it up!!
As for your question on plug wires, I found this...
The first link is to Hart Rods Suburban build. In post #412 he stated "Check out the Doug Thorley headers!!!!! Youll need to use a set of plug wires:
MSD Connector wires 8.5mm 32819 "
There may be a pic of the plug wires on the motor in a later post...didn't get that far.
http://67-72chevytrucks.com/vboard/s...artrob&page=17
Here is a link to a pic of the actual wires...
http://www.summitracing.com/parts/MSD-32819/
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 03-22-2010, 08:26 PM   #156
tommys66
Re: Tommys66 Build
if I tried to make my own, my luck I would mess up just enough to not have enough!
Old 03-22-2010, 08:26 PM   #157
tommys66
Re: Tommys66 Build
no prob
Old 03-22-2010, 08:27 PM   #158
tommys66
Re: Tommys66 Build
thanks, I will check it out
Old 03-25-2010, 10:41 PM   #159
tommys66
Re: Tommys66 Build
http://www.summitracing.com/parts/MSD-32819/[/QUOTE]
I purchased these wires and they are too short! apparently there are two different length wires on the vortec, depending which coil they have. I happen to have the longer wires on my motor. But I am kinda confused, because I checked the length of the truck wires at the local parts store with a stock set from a camaro, and they were the same length
Old 03-26-2010, 12:09 AM   #160
muddpile
muddpile's Avatar
Re: Tommys66 Build
I can't believe I missed 7 pages of this build thread. Looks great!
muddpile is offline   Reply With Quote
Old 03-31-2010, 10:22 PM   #161
Strodder
Daring to be Different
Strodder's Avatar
Re: Tommys66 Build
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-04-2010, 10:23 PM   #162
tommys66
Re: Tommys66 Build
I got some ss front brake hoses, but Im not sure they're installed correctly. I can't remember how the others were on there.
Old 04-04-2010, 10:24 PM   #163
tommys66
Re: Tommys66 Build
thanks
Old 04-04-2010, 10:25 PM   #164
tommys66
Re: Tommys66 Build
Old 04-05-2010, 12:04 AM   #165
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: Tommys66 Build
Wow Tommy, that's some great work. Subscribing to see how it turns out, and bookmarking because you gave me a few good ideas for my own '66. Thanks for taking the time to document your progress and for sharing it.
fryer1979 is offline   Reply With Quote
Old 04-05-2010, 11:59 PM   #166
tommys66
Re: Tommys66 Build
glad i could help
Old 04-06-2010, 12:12 AM   #167
tommys66
Re: Tommys66 Build
Got some gauges in. Theyre from www.speedwaymotors.com Omega Gauges. They are all electronic and the oil and temp gauge came with sending units. I chose to put the oil sending unit in the oil bypass chamber above the oil filter. simplist place to put it, just drill and tap for 1/8" pipe. As for the coolant temp sender, Im going to put it in the right head. There is a plug near the back of the right head, prolly get an adaptor for that.
Old 04-11-2010, 12:07 AM   #168
tommys66
Re: Tommys66 Build
I returned the LS1 wires and ordered the correct MSD wires for the 5.3L These wires have multi-angle boots on the spark plug end, so they can be formed to fit various applications. just plug them on then form the boot to fit where needed. there is a metal sleeve in the boot that helps to retain the form.
Old 04-12-2010, 04:17 PM   #169
structures
structures's Avatar
Re: Tommys66 Build
Tommy thanks for the updates you're really helping me with my LS1 install dude!!!
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-12-2010, 11:00 PM   #170
tommys66
Re: Tommys66 Build
I take so much information from this site, I try to give back as much as I can. Glad it's helping, thats why I post what I think will help someone.
Old 04-12-2010, 11:27 PM   #171
ruffrida2005
Re: Tommys66 Build
Looks good Tommy. I ended up putting my sending unit right at the Dizzy on my 350, but I'm probably going to move it down to the oil filter.
Paul
Old 04-12-2010, 11:32 PM   #172
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Tommys66 Build
Those plug wires look really nice.
Alan's Classic is offline   Reply With Quote
Old 04-12-2010, 11:48 PM   #173
daverod
SSN 706
daverod's Avatar
Re: Tommys66 Build
I like the mass of wires above the spark plug wires.
daverod is offline   Reply With Quote
Old 04-14-2010, 09:33 PM   #174
tommys66
Re: Tommys66 Build
yeah, seems like a good spot
Old 04-14-2010, 09:35 PM   #175
tommys66
Re: Tommys66 Build
well, it was that or black, I think I made the right choice
