Old 10-04-2010, 01:43 PM   #151
sgaylord
Project collector
sgaylord's Avatar
Re: Project "Jezebel"
Next I need to find a place for my fuse block since I removed it from the firewall. I decided to put it in the void behind the seat where the gas filler was located. To make this work I need to fab a panel with a door that when opened would expose the fuse block. I'm not finished with it and I have not made up my mind exactly how I am going to route my wires but I will enclose pics when I get it figured out. I have a couple options, just waiting to see which one works best.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 10-04-2010, 03:17 PM   #152
sgaylord
Project collector
sgaylord's Avatar
This was a nasty mess of a task (the initial stripping part). I needed to remove 40 years of road gunk and old undercoating from the bottom of the cab. I tried everything from chemical strippers to paint scrapers. I found the best tool by far is a wire wheel on a 4 1/2 grinder. You need the heavy duty twisted wire ones. Be careful though, if you hit yourself it will rip your skin off down to the meat. I was lucky not to have a run in with it but be careful all the same.
This was dusty and nasty but it took off the old gunk down to shiny metal. I then bodyworked the weld seams where I replaced the floor portions and then shot on a good coat of etch primer. The last task was to coat the entire bottom with truck bed liner. I used Al's liner, I was skeptical at first that a DIY kit wouldn't provide enough texture but I was pleasantly surprised. I used the entire gallon on the underside of the cab so I could get a nice thick layer that would seal out the elements. I will use the same on the underside of the bed when I get to that stage.
Lifting the cab with my cherrypicker helped me cover the entire cab floor. Otherwise I could not get the gun low enough to obtain complete coverage where the cab corner wraps around the back of the cab.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-04-2010, 03:35 PM   #153
VA72C10
VA72C10
VA72C10's Avatar
very nice work! Firewall and cab floor look GREAT!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-04-2010, 04:27 PM   #154
mcbassin
Still Learning
mcbassin's Avatar
Man! that is an awesome idea with the fuseblock relocation! Can't wait to see the finished product. Hope you don't mind idea stealing. The cab looks great!
mcbassin is offline   Reply With Quote
Old 10-04-2010, 08:20 PM   #155
mjensen
mjensen's Avatar
That looks awesome!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 10-04-2010, 10:04 PM   #156
spike38
spike38's Avatar
Man! That looks fantastic!
I'm planning on using the "HERCULINER" brand myself, On the floorboards,
And underneath. They make there's in four colors.
Spike
spike38 is offline   Reply With Quote
Old 10-05-2010, 08:24 AM   #157
sgaylord
Project collector
sgaylord's Avatar
VA72C10
Thanks, more bodywork needed on the firewall and dash and she will be ready for primer.
mcbassin
Thanks for the compliment. I expect to be back working on that soon. I think I know how I want to run the wires but I have to make sure my theory works. As for idea stealing, the way I look at it is, as the old saying goes, "imitation is the fondest form of flattery" . I post things in case other want to try them. Good luck!
mjensen
That looks awesome!
spike38
Spike
Thanks man. With Al's you can tint to whatever color you want. There's directions in the box to show you how to do it. I thought I would use the body color but decided against it because I only had 1 gallon of paint and didn't want to have to mix more considering the fiasco I went through when I painted my burb hood.. Good luck!
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-05-2010, 08:21 PM   #158
Willys47
Willys47's Avatar
I am subscribing to this thread
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 10-05-2010, 08:26 PM   #159
gearys 5600
gearys 5600's Avatar
Lookin good..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-07-2010, 04:01 PM   #160
sgaylord
Project collector
sgaylord's Avatar
Willys47
Thanks for your interest. I will try not to disappoint....
gearys 5600
Lookin good..
Thanks, I'm digging your build also. That is going to be one fine truck! I really like the wheels. I use to have a 67 Chevelle that was originally Butternut yellow.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-14-2010, 09:23 AM   #161
sgaylord
Project collector
sgaylord's Avatar
OCD kicked in again... :-) Not being able to leave things well enough alone I couldn't get over the different look of the two sides of the firewall. It just looked like something was removed and left unfinished. I like to have people who don't know these trucks to look at things and not realize they were changed. I know I'm weird but I get my kicks in having people not notice changes, and to have some "experts" not being able to put their finger on what changed (Although this change is pretty obvious when you see the slick firewall).
Here is where I started
Closeup of the area that bothered me
The plan
The implementation Decided against covering that small section of original firewall.
This is what I was replicating from the passenger side.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-14-2010, 09:32 AM   #162
sgaylord
Project collector
sgaylord's Avatar
Continued.....
The patch.
A little more finish work and you would never know.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-14-2010, 09:56 AM   #163
bgood70
bgood70's Avatar
Looks great!! Watch out for that OCD it can get out of hand
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 10-14-2010, 10:13 AM   #164
sgaylord
Project collector
sgaylord's Avatar
Next is more body work.... Here is how it stands at the moment.
And yes, that bump on the pass side firewall is bothering me too! I will disappear soon...
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-14-2010, 12:39 PM   #165
VA72C10
VA72C10
VA72C10's Avatar
GREAT job!!! I really appreciate the symmetry... We completely shaved mine and angled the driprail so it's one level all the way across...haven't seen anyone do exactly what you did and I like it a lot!
Keep up the good work
Old 10-15-2010, 01:48 PM   #166
sgaylord
Project collector
sgaylord's Avatar
bgood70
Thanks Brad, I will try and keep it under control. It gets hard because the more I hold it back the more I hear the voices.....
VA72C10
Thanks Jonathan for the complement. I have other ideas, lets see if they work!
Jezebel 3.0 NEW!!!
Roll Tide!
Old 10-26-2010, 05:17 AM   #167
packrat42
packrat42's Avatar
Steve, you do good work. That truck is gonna be awesome when completed. I'll be lookin for you at the turkey run this year.
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 11-01-2010, 11:16 AM   #168
sgaylord
Project collector
sgaylord's Avatar
packrat42
Thanks Derrick, it's taking a while but trying to make all the changes now instead of wishing I would have done something else later.
I am going down to the Turkey Run on Wednesday and will be there thru Sunday. See you there!
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-26-2010, 10:17 PM   #169
seldomseen65
spirit rider66
seldomseen65's Avatar
Location: pahrump, nevada, in the bowels of the Mojave desert
Originally Posted by sgaylord View Post
Now that I have this completed I need to set the new doors and install the rockers. Then finish welding in the filler for the wiring track on the firewall, weld up a few holes here and there, check the roof for little surprises, then go over the cab to see if everything is welded in completely and the cab will be ready for body work.... Steve
Patch to fill the gap
Attachment 598252
All welded in. Some of my best welding yet I think.....
Attachment 598253
Cab corner ready to weld. Notice the smaller gaps this time.
Attachment 598254
Cab corner and "B" Pillar extension all welded in.
Attachment 598255
Back view of cab corner.
Attachment 598256
great job on the cab corners Steve ,,and yes your welding is great !!
:Chevy: If you don't run your own life,, some one else will.
to our vets,, welcome home,, and thank you for your service.:Chevy:
seldomseen65 is offline   Reply With Quote
Old 03-15-2011, 10:11 PM   #170
Seventy Two
This is a fantastic build Sgaylord! Hope to see some updates soon!
Seventy Two is offline   Reply With Quote
Old 03-16-2011, 12:06 PM   #171
sgaylord
Project collector
sgaylord's Avatar
Thanks Seventy Two. I cant believe my last update was in November.. I have not done much work on Jezebel since then unfortunately. December and January was spent building a new shop. I have since moved in and more recently picked up a 60 GMC that has been taking most of my time. I will be getting back to Jezebel soon though.
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 05-30-2011, 11:37 AM   #172
mjensen
mjensen's Avatar
Do you have any updates on this? I'm missing my inspiration
Mike
Old 06-01-2011, 08:17 AM   #173
sgaylord
Project collector
sgaylord's Avatar
mjensen
Thanks for keeping me honest. I have a few updates but nothing jaw dropping at the moment. Mostly just body work, and we all know that's kinda dull.
I am finishing up a clients car this week and should be able to get more done soon. I need the the side work to fund my toys...
My goal is to get Jezebel complete by November for the Turkey Rod Run in Daytona. I see some long days in my future......
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-14-2011, 08:29 AM   #174
sgaylord
Project collector
sgaylord's Avatar
Recently I've been stripping paint from the cab and completing more bodywork smoothing out all the metal work that was done. Hopefully I can get the cab in its first coat of 2k this weekend.
I am debating on putting a 67/68 clip on the truck but who knows. One day I think, "yea, i'm going for it", the next I think, "just get the truck done". What do you guys think about not using the stock front end?
I did order my wheels and tires last week. Decided to go with 17" since I am not a fan of the big wheels unless the truck is really low and on air. Jezebel will have a static 4"-6" drop so I think the 17s will be about what I need. I will post some pick when the wheels and tires get here.
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-14-2011, 09:10 AM   #175
funkytechmonkey
funkytechmonkey's Avatar
Sgaylord, will you come to Atlanta and help me with my cab
I bought a 71 that I am putting a 67/68 front end on. To me the slant of the hood just makes the truck look soooo much better.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
