Old 07-22-2009, 02:00 PM   #151
Keith Seymore
Keith Seymore's Avatar
Re: Intro from an old Assembly Plant guy
Yes - I lowered it when it was new (had about 1500 miles on it).
That was 22 years ago so I don't quite remember how far but it looks like about 2 in front and 3 in the back. I'm thinking of going one more all the way around while I have it apart.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-22-2009, 03:27 PM   #152
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Originally Posted by Keith Seymore View Post
I'm thinking of doing a flip kit and adding drop spindles while I have it apart.
I fixed your post.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-22-2009, 03:28 PM   #153
JohnC
JohnC's Avatar
JohnC is offline   Reply With Quote
Old 07-23-2009, 07:50 AM   #154
Keith Seymore
Originally Posted by smashingchuck View Post
I fixed your post.
Lol! Thanks; I must have "fat fingered" it when I was typing...
1979-1986
1986 - 2019
Old 07-27-2009, 07:07 AM   #155
Keith Seymore
I have a grille!
This thing fought me the whole way, but I managed to git 'er done this weekend.
With the installation of the grille that means that everything forward of the b pillar on the exterior is done!
Next, it's off to the paint shop for the box, hopefully within the next day or two.
K
The grille itself was used, purchased from ScottH (thanks again, Scott). I sprayed it with Duplicolor Argent silver (FM149), along with the headlight bezels. I reused his parking lamps and stainless, with the exception of the center bars (new) and I also replaced the stainless around the grill opening.
I repainted my original bowtie while I was at it, retouching the black border around the chrome and then the "gold/yellow" in the center
This shows the center bars, painted body colored (Duplicolor red WA 7475, code 72).
1979-1986
1986 - 2019
Old 07-27-2009, 08:24 AM   #156
JohnC
JohnC's Avatar
Looks good man!
Old 07-27-2009, 09:22 AM   #157
menace121978
menace121978's Avatar
wow, nice job keith looks like a new one!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-27-2009, 12:26 PM   #158
3r!c84
Badass
3r!c84's Avatar
looks good
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-27-2009, 08:47 PM   #159
bumslie75
bumslie75's Avatar
Did you repaint the center trim also and what kinda paint did you use on the gray
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 07-27-2009, 09:17 PM   #160
Keith Seymore
Yes - I painted the red inside the grille center pieces with Duplicolor GM388 (WA7475, code 72).
The silver in the grille and on headlamp bezels is Duplicolor FM149 Argent Silver, which is the same as the wheels.
K
1979-1986
1986 - 2019
Old 07-29-2009, 09:07 AM   #161
Keith Seymore
Back to the paint shop for the box....
1979-1986
1986 - 2019
Old 07-29-2009, 09:43 AM   #162
menace121978
right on keith!!
hey, i was wondering when you had the cab and front clip painted you left them attached to the chassis right? how hard was it to not get the chassis and fender skirts w/ overspray? i'm just brain storming here... i'd like to get the underside of the cab w/ a fresh coat of paint on mine but i know i'll have to do some assembly in the paint booth for the clip, cab, and bed to get an even spray w/ the metallic flake paint i plan on using...WA-301N Red Jewel Tint Coat (Tri-coat Red)
i'm thinking about doing the work to the fire wall, floor boards, and door jams, spray and reassemble the cab to the chassis... and go from there.
"Dennis the Menace"
Old 07-29-2009, 09:51 AM   #163
Keith Seymore
Thanks, Dennis.
Yes - cab and front clip remained on the chassis. The fuel tank (and shield) caught the most overspray (pretty much full blast), in the vicinity of the cab corner. Across the back of the cab and the front bumper brackets caught just a little bit; very little inside the wheel houses. I wasn't too concerned because I knew I was going to hit them with chassis black when done, anyway.
I recommend you do the interior and door jambs first (before exterior paint), because it is easier to mask off. I didn't get it done in time but - on the other hand - I now know what (exterior) color I need to match on the interior and jambs. I don't foresee any problem if you were to do the firewall and floorboards before exterior paint.
K
1979-1986
1986 - 2019
Old 07-29-2009, 09:54 AM   #164
Keith Seymore
I'm now a two time member of the "Removed my Pickup box by myself" club...
x3, btw....
1979-1986
1986 - 2019
Old 07-29-2009, 09:57 AM   #165
menace121978
thanks for the input keith!
"Dennis the Menace"
Old 07-29-2009, 10:02 AM   #166
menace121978
rough way to go... try doing a fully assembled cab w/ 1 other guy and a wife!!
"Dennis the Menace"
Old 07-29-2009, 10:21 AM   #167
87Bob
Pulled the turn lamps, windshield wipers, door locks and door handles and "off we go"....
It's supposed to be done in a week, so I will check back in and let you all know how it went.
K
I'd love to know how you got that ding on the left side of your box? There is an identical one on the side of mine. Since I can't get to it from the back side I guess I'm going to have to use a slide hamer with a screw end on it to pull out the dent.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 07-29-2009, 10:33 AM   #168
Keith Seymore
It wasn't there in 1991 when I sold it to my Father-in-law...
Poor little truck - there wasn't a straight panel on it when I got it back. There were even dings in the hood and roof (...either it went through a hail storm or he tied a deer up there. Stranger things have happened).
K
Edit: I think he slid into a post, btw.
1979-1986
1986 - 2019
Old 07-29-2009, 10:34 AM   #169
menace121978
there is also a gun that welds a rivit type head to the sheet metal then attach a slide hammer for the pull. leave all the rivits on until the end and grind them off w/ no holes. just a heads up...
"Dennis the Menace"
Old 07-29-2009, 10:40 AM   #170
Keith Seymore
I think that's how the body shop fixed my doors (judging by the little weld spots that you can see from inside the door).
K
1979-1986
1986 - 2019
Old 07-29-2009, 10:44 AM   #171
S10Fan
Old Heap Driver
Stud Welder, Harbor Freight sells a nice one good for the home repair guy.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 07-29-2009, 10:57 AM   #172
SBTork
Garage wrench
SBTork's Avatar
That does not sound fun.
Right on Keith, you're doing an awesome job. I know it's just going to be a nice driver but im still impressed with it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-29-2009, 11:05 AM   #173
menace121978
thanks s10fan i couldnt think of the correct name to save my life!
X2 on keiths build!
tork, it didnt go very well... we got it to the back tires and i seriously thought that my fingers were cut off from the sheet metal!
"Dennis the Menace"
Old 07-29-2009, 11:21 AM   #174
SBTork
Garage wrench
SBTork's Avatar
X2 on keiths build!
I think you made it further than I would've
-Adam
Old 07-29-2009, 10:45 PM   #175
lowchevytrucks8503
Nice truck. I'm always happy to see another box being put back together.
I have a question and I may be in the wrong spot, but is there anyway to figure out the old MSRP or get another sticker for the glove box????
lowchevytrucks8503 is offline   Reply With Quote
