Old 12-08-2012, 02:25 PM   #151
slepysal
slepysal's Avatar
Re: My 1962 C10 Build Thread "Grandpa's Truck "
Man Brian great work ! Can I get some more info on your transmission cross member? Also what did you use for your fuel tank?
I appriciate the tips you have posted in your build thred !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-08-2012, 08:45 PM   #152
Bugeyev8
Bugeyev8's Avatar
The trans x member I made, its 1x3 rectangle and I sleeved for all the bolt holes, my fuel tank is stock behind the seat tank with a return line added for the efi
come see it any time !
Bugeyev8 is offline   Reply With Quote
Old 12-09-2012, 02:09 AM   #153
Captainfab
60-66 Nut
The exhaust does sound good. I didn't see any mufflers. Are you running any?
It seems I have seen an exhaust X like that before. What is it from?
Old 12-09-2012, 01:00 PM   #154
Bugeyev8
Bugeyev8's Avatar
Its an x pipe from a 2010 Cadillac ctsv, and there are 3 chamber flowmasters under there, sounds good for a stock engine !
Old 12-10-2012, 06:43 AM   #155
CURSED GEARS
Read your whole thread, and was sad when I came to the end. I'll have to keep an eye on it, neat stuff!
CURSED GEARS is offline   Reply With Quote
Old 12-10-2012, 11:15 PM   #156
Bugeyev8
Bugeyev8's Avatar
Thanks for the compliment ! Hope I will have some updates soon !
Old 03-24-2013, 03:44 PM   #157
Bugeyev8
Bugeyev8's Avatar
got some work done on the 62 today, I cut 1 inch out of the motor mount towers, just a little more bending to make them fit perfect
Old 01-24-2014, 02:40 PM   #158
Bugeyev8
Bugeyev8's Avatar
Gone ls !
Old 01-24-2014, 02:42 PM   #159
Bugeyev8
Bugeyev8's Avatar
filled all unused holes in firewall and flus mounted the vintage air unit,no bolts thru firewal !l
Old 01-24-2014, 04:22 PM   #160
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Just ran across this build! Great work so far!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-24-2014, 11:05 PM   #161
Bomp
Bomp's Avatar
Slick work on the firewall !
Bomp is offline   Reply With Quote
Old 01-25-2014, 01:44 AM   #162
Captainfab
60-66 Nut
Just what I thought you were doing after having seen your ads in the classifieds. What size LSx are you going with?
Old 01-25-2014, 12:06 PM   #163
Bugeyev8
Bugeyev8's Avatar
I got a deal on a 2006 5.3 with 38k miles so the choice was easy
Old 01-25-2014, 12:09 PM   #164
Bugeyev8
Bugeyev8's Avatar
Smile Re: My 1962 C10 Build Thread "Grandpa's Truck "
Thanks ! I have been following your thread for a while too, seeing the progress on your truck and a few others here gives me some motivation to work on mine
Old 02-21-2015, 01:14 AM   #165
64jmb
64jmb's Avatar
Hello,
I have a original 1962 C10 Custom Cab Long bed also that is pretty much a 1 owner truck since 1962 other than me getting it recently, with a great story also. But I was very curious, you mentioned that your grandpa ordered his with a corvette 283. Mine is very original also and it has a 4 barrel and a cake dish snorkel type air cleaner similar like on the C30 C50 series that has the 327. Did your grandpas engine look like that also? Let me know. I think mine is all original like the way it came possibly.
64jmb is offline   Reply With Quote
Old 05-16-2015, 12:08 AM   #166
Bugeyev8
Bugeyev8's Avatar
got back to work on the 62..got the suspension all test fitted to frame ...next the LS engine and trans test fit
Old 05-16-2015, 12:11 AM   #167
Bugeyev8
Bugeyev8's Avatar
more pics
Old 05-16-2015, 12:47 AM   #168
slepysal
slepysal's Avatar
right on !! looks great
Old 05-17-2015, 01:01 AM   #169
Captainfab
60-66 Nut
Looks great
How did you mount the rack and pinion?
Old 05-18-2015, 09:09 PM   #170
Bugeyev8
Bugeyev8's Avatar
Looks great
its a No Limit r&p kit I modified for the 62 frame, very nice kit and great customer service
Old 05-22-2015, 01:09 AM   #171
Bugeyev8
Bugeyev8's Avatar
more progress
Old 05-22-2015, 07:21 PM   #172
hotrod66
hotrod66's Avatar
Come along way keep it up!
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 05-24-2015, 01:35 AM   #173
Bugeyev8
Bugeyev8's Avatar
thanks its been way too long since I've worked on it, good to be back to it
Old 06-05-2015, 08:43 PM   #174
hjmags62
hjmags62 is offline   Reply With Quote
Old 06-05-2015, 08:50 PM   #175
hjmags62
Originally Posted by hjmags62 View Post
Hi...new to this blog. Read your all your threads. AWESOME!!! What a great job you're doing. I have a 62 factory automatic deluxe custom cab BBW shortbed. She's a little rough around the edges but complete. I'm in the process of restoring her. You have inspired me to start working on her again. Reading your threads just gave me a lot more motivation. Thank you and keep up the great work!!
1962, lsa supercharger, rust repair, tuned port
