Closed Thread
Old 05-19-2010, 01:44 PM   #151
8mpg
8mpg's Avatar
Re: What did you do to your truck today!
Replumbed the fuel cell... Went from -8 to -6 bulkhead...had to make a couple of aluminum washers to fill the 3/4" hole in the fuel cell.
Also started making some fuel line brackets out of aluminum flat stock. They hold 2 3/8" aluminum fuel lines from the notch back to the fuel cell. Then the ones in front of the notch will be 2 3/8" fuel lines and a 3/16" brake line.
Originally saw how to build these on the HAMB forums...but someone has a write up here in the FAQ.
Pics later
Kinda hard to get the 3/8" holes right in center of the 2 pieces of aluminum. But they will work fine. The long bracket needs to get cut down. It was the first one...trying to get the spacing right.
8mpg is offline
Old 05-19-2010, 02:35 PM   #152
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Went to the body shop to tape out the separation for the two-tone paint scheme and the colored stripe that runs between the two colors the inside is painted, the jambs are done, and the gaps are set in stone! The guy doing all the body work is incredible! I had some pretty good rust issues on my (top) lift-tailgate... enough to have me lookin for another one. He cut it all out, treated the inside of the tailgate with rust arrest liquid... and then welded all new metal in there, and prepped and painted.... looks better than new!
I am stoked it comes home this weekend!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline
Old 05-19-2010, 04:14 PM   #153
lovnthe70
lovnthe70's Avatar
Threw an entire demolished bathrooms worth of sheet rock, tile and concrete in the back! Love those extra leaf springs.
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline
Old 05-19-2010, 06:30 PM   #154
67Slider
67Slider's Avatar
Painted Front front clip and rear fenders, busted my knuckles and the lower bolt trying to lower the rear end, toook off the old bed and removed the old rusted fenders.
[IMG][/IMG]
Took off the old bed,
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 05-19-2010, 08:48 PM   #155
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Got my blower hole cover in the mail! Just need to fix a spot where old blower seal started to rust the firewall a little... didn't go through, just a little flakey. Then, my plan to get rid of all options will be complete.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline
Old 05-19-2010, 10:14 PM   #156
Hubscrub
Cruzin
Hubscrub's Avatar
finally finished painting my wheels
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 05-19-2010, 11:47 PM   #157
1968CHEVYC10
1968CHEVYC10's Avatar
installed new tie rods
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline
Old 05-21-2010, 12:30 AM   #158
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Stuffed the '71 in the garage and jacked/blocked it up. Sprayed everything with PB blaster that I think I needed to for the axle removal. Chased a wiring issue with backup lights. Keeps popping fuses.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 05-21-2010, 02:10 AM   #159
CSGAS
optomistic ah-so
CSGAS's Avatar
This took longer than a day but I had "help" from Mother Nature
Anyone who saw my truck at GotG knew I was catching up with a "parking lot" water pump change and leak...chased it through a few quickie attempts until Sunday I took everything off the front of the motor, then the rain started falling hard and drove me inside. I cleaned, prepped and spray painted everything (not show quality, just better and lighter without the crud) and suffered through primer up my sinuses as well as nothing drying under the humidity then when it stopped raining I cleaned, prepped and sprayed the front of the block before reassembling everything on Tuesday.
No leaks finally and I identified my next project--the balancer needs to properly removed and reinstalled. Also discovered the replacement radiator I have to go in, has been a 4-row all along. Maybe I shouldn't do things to the truck anymore, I keep finding more things to do!!!
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 05-21-2010, 09:43 AM   #160
TomJohnston
TomJohnston's Avatar
I let my daughter take a friend of hers out in it. They made it back in one piece. whew.
Dad's 1970 Chevy C10 Custom
350, auto, armstrong power windows and doorlocks
"My carbon footprint is bigger than yours"
TomJohnston is offline
Old 05-21-2010, 11:37 AM   #161
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
mINE IS GETTING THE FULL ATTENTION TODAY FROM ME AND HOPEFULLY THE NEW HARNESS WILL BE FINALLY INSTALLED.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 05-21-2010, 02:26 PM   #162
48richard
48richard's Avatar
Evacuated and charged my new A/C system with R134a. Outlet temperature was about 40F when outside temp was about 90.
1971 C10 Longbed, 350/TH350
48richard is offline
Old 05-21-2010, 06:54 PM   #163
Hubscrub
Cruzin
Hubscrub's Avatar
got me a 3/4 ton junkyard sway bar for $25
Proverbs 3:5,6
Hubscrub is offline
Old 05-22-2010, 01:51 PM   #164
GKsport67
GKsport67's Avatar
Added a door logo!! (bling)
GKsport67 is offline
Old 05-22-2010, 09:44 PM   #165
67Slider
67Slider's Avatar
Installed the new Jeep spring to lower the rear.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 05-22-2010, 09:52 PM   #166
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I took the laundry out of the dryer and set it on the hood...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline
Old 05-22-2010, 10:06 PM   #167
kev0519
cut out floor got ready for new
kev0519 is offline
Old 05-23-2010, 01:49 AM   #168
oldiron
Designated Grumpy Old Man
oldiron's Avatar
After NickP51chevy wired 98% of the complete rewiring I installed the headlight wires and installed the new dash gauges.
Thanks Nick. It wouldn't have got finished without you.
oldiron is offline
Old 05-23-2010, 02:11 AM   #169
Old Bluey
Old Bluey's Avatar
Kev0519, That looks sick!! Nice work!
Today was the day my Offy intake finally went on, swapped the throttle assemble from rod to cable, ripped off the water intake and recent power steering project parts off to get them all painted and ready for re-install.
Should be able to get the new gas pedal set up and fire it up on monday (Long weekend!)
Old Bluey is offline
Old 05-23-2010, 03:38 AM   #170
c10seconds
c10seconds's Avatar
Put in a new powdercoated axle with a new diff cover, Big brakes, and a detroit locker
c10seconds is offline
Old 05-23-2010, 03:24 PM   #171
Marc33
Marc33's Avatar
started removing the front clip. Pulling out the old tired 350 and installing a 450 hp big block next week.
Marc33 is offline
Old 05-23-2010, 03:31 PM   #172
scooterskoolkustoms
scooterskoolkustoms's Avatar
Talking Re: What did you do to your truck today!
Man that looks sweet.would like to see more pic's of it.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 05-23-2010, 03:32 PM   #173
vectorit
What?
vectorit's Avatar
Replaced, regapped the spark plugs, and adjusted timing.
Replaced the glove box emblem.
Piddly stuff today...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 05-23-2010, 03:51 PM   #174
ricks71pu
ricks71pu's Avatar
ok, this weekend i put all new rims on 71 gmc longhorn, put in headliner, took my tonneau cover to have an additional 7.5 inches added on (it is a longhorn) so it had to be customized. oh yeah, took it fishing too!
ricks71pu is offline
Old 05-23-2010, 04:48 PM   #175
rogergodding
rogergodding's Avatar
Got my butt handed to me trying to do a valve lash adjustment
rogergodding is offline
Closed Thread
