Old 08-29-2011, 09:23 AM   #151
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 1990 GMC Suburban ... Cummins Powered
How far in from the ends? I have a spoiler and roof rack I want to take off and weld up the holes.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-29-2011, 12:22 PM   #152
greguw
Looks like its double from the jam up to about 6 inches then it goes to single layer ... you can get the all the wholes to weld them ... I welded all the screw holds on the ribs but then re-enforced all the mount points for the rack with 3/16 plates that are connected to the ribs .
If you look in the previous page there is a pick of the inside of the roof and you can see where the double ends .
I'm also going to apply more sealant to the rib roof area .
greguw is offline   Reply With Quote
Old 08-29-2011, 09:47 PM   #153
WarBeard
WarBeard's Avatar
I just posted a video of what the burb roof looks like.
http://www.67-72chevytrucks.com/vboa...65#post4871465
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 08-30-2011, 06:26 AM   #154
greguw
Great buddy , love the Camo , my headline is a mess and was kicking around the whole industrial look but either going the ABS plastic one or is I can find aluminum sheet wide enough I have access to a sheet metal shop with shears and brakes I may pattern off my old tattered one and go aluminum .
Old 08-30-2011, 11:29 AM   #155
WarBeard
WarBeard's Avatar
To bad your not closer My headliner is in perfect condition. I just like the stripped Shipping container look!
Old 08-31-2011, 02:05 AM   #156
Mr. 250r
Mr. 250r's Avatar
For the headliner incase you wanted a much cheaper route than the abs is like mine i just took broom and sweep it off the old glue comes off easy and i had a vinyl roof which was already basically fallen off then took it to an interior guy paid 40$ for both pieces and picked the closest blue i could find to my interior, just a thought though
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-06-2011, 06:47 AM   #157
greguw
Found some time over the holiday weekend to start laying out the roof rack ... getting the main deck rails in place . It's a little over kill but by the time I get offroad lights on the front and 42" spare on top should be just right .
Its going to have 1/8 diamond plate aluminum on the deck and going to do a rail above the the deck also .
Ran out of stainless fasteners so I will order some more today keep on picking at it .
Old 09-06-2011, 12:38 PM   #158
WarBeard
WarBeard's Avatar
What is that roof rack material called? Where do you get it and cost?
Since I moved here my shop and 99% of my tools are 200 miles away and I like that the stuff you have just bolts together since I don't have my welder.
The roof rack I want will hang over the windshield a little bit and hold some lights upside down and possibly some lesser lights on the side and back.
Old 09-06-2011, 01:45 PM   #159
greguw
Its a structural framing system ... I use it from building frames for machines but is great from a roof rack ...
The aluminum is pretty cheap it self , its when you get into the brackets and hardware is when it ads up .
http://www.mcmaster.com/#structural-...ystems/=dy31fd
I'm doing 1/8 aluminum as a deck on top of that and going with a side railing and mount brackets on the front of the rack for offroad lighting .
That rack is over 8ft long and dose not look it .
Old 09-21-2011, 06:54 AM   #160
greguw
Been busy with work and family stuff but have made progress on the roof area . I got most of the new rack finished up have some finishing touches to like the black in-cert that goes in the middle of the aluminum track .
The top deck is 1/8 aluminum diamond plate ... should be pretty strong .
Still have to add some more sealant between the ribs and roof for some added support , don't think GM had me in mind when they designed the roof ...LOL
It is pretty industrial looking , I also have installed adjustable mounts on the front and rear for offroad lights and CB antenna .
You can see behind the sub 2 tread plate rails ... there the future running boards , just have to make up some mounts and cut them down a little .
Also finished the rain gutters , they were blasted and painted , for some reason gm never sealed the inside edge where all the rust would start . I used a white sealer and just but a nice coat to keep the water out ... can't even see it .
Next will be the body panels but might install all the new window regulator motors first .
Old 10-05-2011, 07:55 AM   #161
greguw
I'm into the body work now so its not that exciting , once I make some progress getting the body stripped down and new primer I will get some pic's up .
Seems like everyone likes the new roof rack including the shop cat .
Old 10-05-2011, 03:55 PM   #162
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Dude Love The Build!!!! Wish I had Your Talent....... I'm Getting There...
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 10-05-2011, 06:25 PM   #163
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great job on the roof rack. It's awesome!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-31-2011, 06:47 AM   #164
greguw
Hey Guys ... The Build is still alive and I have been picking at the truck , got the truck all stripped down and just finished epoxy primering the tailgate on saturday .
I have do some final blocking of areas on the panels and then get it prepped for the paint process .
I'm pretty impressed that the whole truck only took less than 1 quart of all metal and that was for small dents and the roof was the worst of it .
I also cleaned and prepped the insides of the door boxes and took Por-15 and a squeeze bottle and put a nice bead of the paint down the inside of the seam ... just enough to seal out any chance of rust down the road ... stuff worked great and just put enough but not close up the end drains in the doors .
I still have to decide on the flares , I have bought the best flares in my opinion ... Xenon flares are great compared to the crappy bushwacker junk .
I'm going to decide if I am going to cut in the area around the wells and the then mount the flares to be painted with them in place so there is no chance of them being stressed and paint peeling over time and I think that is going to be the best way .
I also just ordered the last of the finish parts , mostly seals and gaskets . I still have to track down some headliner material and my buddy owns a glass company so I will have him out for a few beers while we install at new windshield .
Old 10-31-2011, 10:56 AM   #165
Davidmichael
Davidmichael's Avatar
For the flares, just add a flex additive to the paint. cheap insurance IMO.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-11-2011, 07:06 PM   #166
iroc12valve
Updates PLEASE !!!! this is an amazing build thread
better quality than extreme 4x4 would have done
p.s. if you ever want to sell il give you everything I own as trade
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 11-11-2011, 08:50 PM   #167
Dieselwrencher
Greg, it's looking great!
Ryan
Old 11-12-2011, 01:12 PM   #168
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
The shop cat just had an idea!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 11-12-2011, 02:27 PM   #169
WarBeard
WarBeard's Avatar
That's funny right there!!!!
Old 11-14-2011, 11:36 PM   #170
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sweet burb, that thing is massive!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-16-2011, 07:38 AM   #171
greguw
I did get a chance to do some painting ... Looks ok for a go truck ... I have moved on to the jams , and start putting her back together . I'm going to hold off on the seats I just want to get the truck on the road and I need a break .
I have a commercial consew sewing machine forsale so I am trying to work a trade out for a shop to redue my seats and they get the machine , so will see how that goes .
Only parts I have to paint are the new Cowl induction hood and the cowl vent .
I had a few sliders and they seemed to sand out ... I'm going to let all the paint harden up for a few weeks then knock everything down and wheel it up then all my glass can go in .
Old 11-16-2011, 11:18 AM   #172
Dieselwrencher
Greg, it looks sweet! Nice job!
Ryan
Old 11-16-2011, 12:40 PM   #173
greguw
Thanks Buddy , its not bad for a in the middle of the shop paint job ... Now I have to come up with a strip combination after I rub the truck ... I was looking at my 96 cummins and it has a dark aqua with a light aqua and that looks pretty good .
Old 11-16-2011, 07:32 PM   #174
y5mgisi
Second Chance Program
y5mgisi's Avatar
Looks real nice! About the stripe, is it to separate the silver from the black? I think the light/dark aqua would look real good! Also, are you leaving the roof white?
y5mgisi is offline   Reply With Quote
Old 11-16-2011, 09:20 PM   #175
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It looks pretty darn good man!
A white stripe would look good.
Tony
