Old 12-06-2010, 12:22 PM   #151
eagleuh1
eagleuh1's Avatar
Re: '67 5.3L Build Thread
I was lucky on the wiring. Mine looked in excellent shape. Never touched, butchered. No cracking or anything. And everything worked good. I am going to do the headlight mod for brighter lights though.
eagleuh1 is offline   Reply With Quote
Old 12-08-2010, 06:37 AM   #152
67C10BUB
67C10BUB's Avatar
Walter,
Here is that list of parts from Shifty's thread about his build that I was telling you about. I am putting it on my thread just in case anyone else wants it as well. This is a list of all of the Summit parts that I used to build my fuel system.
(1) Stock Corvette fuel pressure regulator/filter unit, GM P/N 10299146 $119
(1) 20' spool of -6AN braided steel hose, Summit P/N: SUM-230620 ($74)
(1) Russel Fuel rail adapter 10mm->3/8", Summit P/N: RUS-640850 ($16)
(1) Custom aluminum tank build by board member Boyds.
(2) Earl's -6 AN to 1/4 in. NPT 90º swivel adapter, Summit P/N: EAR-829006ERL ($25/ea) This would be different since the Boyds tank I got uses 3/8" NPT.
(4) -6 AN hose ends (hose to -6 AN female), Summit P/N: SUM-220690 ($5/ea)
(1) S&P Corvette Fuel Filter adapter 3-piece adapter kit (compression to -6 AN fittings) $100 at www.hotrodlane.cc ->
I opted to buy the fuel pressure reg/filter from Pace Performance. It came in a kit with all of the -6 adapter fittings. Hope this helps.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 12-08-2010, 06:47 AM   #153
67C10BUB
67C10BUB's Avatar
Here are a few pics of the Thermotech sound and heat barrier I am using. It seems like good stuff and at a really good price through Summit. The adhesive is excellent and it follows the contours of the floor nicely.
67 5.3L Build
Old 12-08-2010, 06:50 AM   #154
67C10BUB
67C10BUB's Avatar
Here are a few pics of how I wired up the 2003 Avalanche power seat. I just installed a 2-pin weatherpack connector on a wire designated for the power seats on the AAW accessory harness and then hooked that up to the black and orange wires on the seat. Out of all those wires those are the only ones needed to make it work.
67 5.3L Build
Old 12-08-2010, 06:51 AM   #155
spike38
spike38's Avatar
How much did it take to cover everything
Spike
spike38 is offline   Reply With Quote
Old 12-08-2010, 01:25 PM   #156
smokinstang70
smokinstang70's Avatar
IT was great talking to you yesterday... I appreciate the advice. Thanks for the info on the fuel system setup - will definitely be investigating that.
Can you give me some more info on the fuel filter / regulator you got from Pace?
Thanks again
smokinstang70 is offline   Reply With Quote
Old 12-08-2010, 03:05 PM   #157
67C10BUB
67C10BUB's Avatar
Thanks again
Here is the info from their web site:
PAC-9926 - Pace Pac EFI Fuel Filter with Regulator Package $118.95
This package utilizes an OE 99-03 Corvette fuel filter with a built-in bypass regulator. We've added all the fittings you need to convert this filter to 6AN. This works great with OE high pressure fuel pumps and regulates fuel pressure at 55-60 psi (key on engine off). Works very well with GMPP LS3 fuel injected crate engines.
And below is a pic of what you get except for the Summit fittings on there. Just run the -6 line from the pump in the tank to the offset fitting, run a -6 line from the center fitting to the tank return, and a -6 line from the center fitting (all by itself on the other side) to the fuel rail. This takes care of the pressure (regulates to 58 psi) and the filtering.
67 5.3L Build
Old 12-08-2010, 03:10 PM   #158
67C10BUB
67C10BUB's Avatar
Spike
It took a little less than 2 rolls (36x60) to do the floor and up the fire wall. I bought a third roll to do the back wall of the cab and the doors.
67 5.3L Build
Old 12-08-2010, 09:29 PM   #159
eagleuh1
eagleuh1's Avatar
Looks good.
Old 12-15-2010, 04:56 PM   #160
67C10BUB
67C10BUB's Avatar
I bought the Grand Slam lowering and brake kit from CPP. I got it home and found that the billet tie rod adjusters were missing. I called up Bari at CPP and I received them the next day. I have heard some bad things about their customer service, but so far they seem pretty good to me. Hopefully I won't have some of the install issues that I have also heard about. Just a note...I found that this kit will not hook up to the factory hard brake lines, so you also have to buy a line kit to go along with the Grand Slam to complete the install. I will post pics once installed.
67 5.3L Build
Old 12-16-2010, 12:51 AM   #161
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
glad to hear they took care of you. couldn't you modify your brake plumbing ends? but then again...if you're talking about the "old" brake lines...you're better off starting out with new ones with all new brakes.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-16-2010, 06:27 AM   #162
67C10BUB
67C10BUB's Avatar
That's kinda what I was thinking. I think I will go with the stainless set, just so I don't have to worry about them ever again.
67 5.3L Build
Old 12-27-2010, 11:30 PM   #163
67C10BUB
67C10BUB's Avatar
Here are a few pics of the final engine install. I think it came out looking like a factory install.
67 5.3L Build
Old 12-27-2010, 11:32 PM   #164
67C10BUB
67C10BUB's Avatar
Here is a pic of the CPP brake setup (upgraded to 73-87 parts) with 2.5" drop spindles and 2" drop coils. I purchased the CPP "Grand Slam" so I still have the back to do and install the new master cylinder/booster.
67 5.3L Build
Old 12-28-2010, 12:14 AM   #165
messer007
messer007's Avatar
what kind of vehicle did the motor come out of
1970 C-10 CST
2003 Silverado
2004 Avalanche LTZ
messer007 is offline   Reply With Quote
Old 12-28-2010, 12:47 AM   #166
spike38
spike38's Avatar
It is a 2008 5.3L with a 4L60E trans out of a Silverado "post#4"
Spike
Old 12-28-2010, 12:53 AM   #167
nibs
JRods Garage
nibs's Avatar
You sir have a very beautiful truck. Its cool to see you live in Alta Loma, Im right over in Rancho close to Baseline and Vineyard. I hope to see you and this truck out about!
nibs is offline   Reply With Quote
Old 12-28-2010, 01:20 AM   #168
kvn1011
Kvn1011
kvn1011's Avatar
that came out great!!
i agree with nibs!!
very beautiful truck with a younger heart!!
kvn1011 is offline   Reply With Quote
Old 12-28-2010, 01:25 AM   #169
VA72C10
VA72C10
VA72C10's Avatar
very nice job! Does look factory!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-28-2010, 01:30 AM   #170
mcbassin
Still Learning
mcbassin's Avatar
Totally agree it does look factory. Super install. I hope my turns out close to that clean.! Awesome
The brake and suspension looks great too.
mcbassin is offline   Reply With Quote
Old 12-28-2010, 01:37 AM   #171
67C10BUB
67C10BUB's Avatar
Thanks for everyone's kind words. It is nice to see someone else in Rancho building a C10. Perhaps we'll have a 2 person truck club when I'm done.
67 5.3L Build
Old 12-28-2010, 02:16 AM   #172
nibs
JRods Garage
nibs's Avatar
HAHA, yea we could do that! That is, when Im home and not going around the world... :/
Old 12-28-2010, 08:14 AM   #173
mrhino
Yes, it looks very good, nice and clean.
mrhino is offline   Reply With Quote
Old 12-28-2010, 02:56 PM   #174
67chevy1series
67chevy1series's Avatar
great build i always wondered if i should put a new engine in mine
67chevy1series is offline   Reply With Quote
Old 12-28-2010, 10:12 PM   #175
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
love your build, looks super clean, nice work
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
