01-30-2011, 10:04 AM | #151 |
78K & 79C Jimmys
Re: Improve mileage 350 with Quadrajet
glad to see you got it all cleaned up
don't think those are the same rads in those pics lol on the right the cleaner one has a high solder drip i don't see in the other(middle right) and the outline of the metal contours of the rad don't look the same
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-30-2011, 02:23 PM | #152 | |
thank for the info. the dual curve product dont seem to be sold anymore. "Obsolete" says the website, just leaving the instructions. Where are those articles on dual fuel? ca you point then out to me?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
02-06-2011, 09:13 AM | #153 |
the thermostathouse is leaking. should I use teflontape or something on this plueg on top?
02-09-2011, 10:31 AM | #154 |
78K & 79C Jimmys
does it not tighten up and seal?
but the teflon should work
02-13-2011, 04:24 PM | #155 |
checked my cooling fluid again today and it is staying nice and clean...wich makes me very happy.
I usually get a mileage of 7,5 MPG today we got gas and I calculated a mileage of 8,2 MPG
02-13-2011, 08:17 PM | #156 |
somethingsw gotta be wacky, what gears are in the truck and what transmission?
my 80' was de-emissioned has 3 inch exhaust 350 q-jet 4 speed stick, and get 12-14 hwy. |
02-14-2011, 03:08 AM | #157 |
hi there, my Burb has a TH400 and 4.1 gear ratio. We drive about 55mph on the highway.
02-14-2011, 03:20 AM | #158 |
that would explain it mine was a 3/4 ton 4x4 4 speed with a 342 or something close rear gear. real highway friendly
03-29-2011, 04:27 PM | #159 |
connected a tach tonight...
my car makes about 2800 rpm at 55 mph. is that a lot or normal? I have 4.1 gears.
04-01-2011, 03:31 AM | #160 |
I also replaced the vacuum advance. I thought it wasn't working. So I checked. It did work, but the replacement I got from somebody had a longer path, so more advance at high vacuum.
could this improve the mileage on the highway at low throttle? I also replaced the front brakes that were old and rubbing the discs constantly because the brake cilinders were stuck. My mileage improved from about 6 mpg to about 7 mpg...still not very good...but improvement...I wonder if I'll see the same mileage when I get gas the next time.
04-01-2011, 09:44 AM | #161 |
78K & 79C Jimmys
hi kikkegek.I noticed the other day the 78
totally diff trucks but @80 km/hr(about 50mph) i was running 2000 rpms
04-01-2011, 10:27 AM | #162 |
Change out the tranny to a 700R4...the overdrive will help on the highway...
04-01-2011, 01:27 PM | #163 |
it is a 4WD is that even possible?
04-01-2011, 02:24 PM | #164 |
78K & 79C Jimmys
Yup i believe my gold burb had one
[size=1]Posted via Mobile Device[/size And so did my 87
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-01-2011 at 03:55 PM. |
04-01-2011, 03:13 PM | #165 |
Talking about being on a different playing field;
Yours has a 3 speed automatic with 4.10 gears and 2800 rpm @ 55 Mine has a 4 speed autom / overdrive and 2.73 gears.... no tach, but I guess 1.400 rpm or so at 55....... just a bit above idle. You need an overdrive and I'm better off keeping it out of OD with my gears erik
1972 GMC 2500 Sierra 350 1971 Pontiac LeMans Sport 400 GTO/Judge Clone 1970 Pontiac GTO 400 convertible restoproject 1970 Pontiac Bonneville 455 convertible Last edited by erikgto; 04-01-2011 at 03:14 PM. |
04-01-2011, 04:13 PM | #166 | |
04-01-2011, 04:19 PM | #167 |
78K & 79C Jimmys
may have to change a housing/tail
04-01-2011, 04:25 PM | #168 |
he John,
I am a complete noob for trannies, can you explain a little more on that?
04-01-2011, 04:41 PM | #169 |
78K & 79C Jimmys
what i understand is the tranny size is diff
the two wheeler has a longer tail housing,cause in the 4 wheeler it has the tranfer case to bolt up to and being computer controlled,you need some sensors..... not sure why erik,wouldn't want to use the OD My 87 i drove in it all the time
04-05-2011, 01:20 PM | #170 |
alrighty, here we go again.
Today I got my radiatorcap with thermometer in through the post from mr. gasket. really cool device. Now I can check the temp right at the core. And what do you know. It's exactly the same as my meter in the cockpit (of wich I wasnt certain). Just 150F....isnt that extremely cold for an engine to run well? The thermostaat is 195F....but I can drive on the highway or city for miles and the temp will not go over 150F... what to do? here's two pics of the cap:
04-05-2011, 01:55 PM | #171 |
Replace the thermostat...sounds like it's stuck open...
04-05-2011, 02:20 PM | #172 |
78K & 79C Jimmys
nice cap hadn't seen one like that
how cold out was it was the heat on he just changed it the stat if thats the case i would go back to your summer at this point i never change it i always just cover the rad incase we got a warm spell i can just rip it off
04-05-2011, 02:25 PM | #173 | |
I probably wanna check the thermostat...in a bowl of water and check when it opens....with a thermometer...
04-07-2011, 03:00 PM | #174 |
I took of the hose from the thermostat houding 2nite to feel if the thermostat is tight in position., And it is. no movement.
I also then checked with a cold engine if there was flow of coolant through the radiator with the cap of. I started the engine and looked, but when I raised the throttle a little, I definately saw water flow and when increased the throttle more it got more turbulent. shouldnt there be absolutely NO flowif the engine is cold? and the thermostat closed?
04-07-2011, 05:04 PM | #175 |
78K & 79C Jimmys
I'm guessin you have a small pipe from the intake to to waterpump or threw the heater core
(need pics) the pipe will bypass the stat = heat sooner inside
