Old 04-01-2013, 04:08 PM   #151
mcbassin
Still Learning
mcbassin's Avatar
Re: 69/72 Restoration/Rebuild (we ain't scared)
Great looking shop! You can never have too much room.
mcbassin is offline   Reply With Quote
Old 04-01-2013, 04:33 PM   #152
oldman3
oldman3's Avatar
Looks real good...Jim
oldman3 is offline   Reply With Quote
Old 04-11-2013, 11:16 PM   #153
weaintscared
weaintscared's Avatar
Change of plans!!! O well the T56 6 speed is gone,sold it so now it's time to fine an auto,, what's the best to run? 4L60E. Or the 4L80E ??
weaintscared is offline   Reply With Quote
Old 04-11-2013, 11:25 PM   #154
Xeen
Xeen's Avatar
Since you are mating it to a Gen 1 style Big block I would recommend a 700R4, you are going to have to either find a corvette version or have it built with corvette specifications to handle the power.
I'm guessing since you have a floor shift steering column you are going to run a floor shift auto now?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 04-18-2013, 01:27 AM   #155
weaintscared
Thanks,which shifter is best for these trucks ?
Old 04-24-2013, 08:40 PM   #156
68 TT
Still plays with trucks
68 TT's Avatar
Not a wise choice. I have broken far too many and spent way too much money on them trying to keep them together with a powerful engine in a moderately heavy vehicle. There are two failure points in the 700R4/4L60/4L60E that occur between 320 and 360 rwhp that even the Corvette version does not address. The sun shell and the forward sprag are weak links and are ticking time bombs anywhere in that power range. The typical trans shop rebuild is double or more to do a 4L60 vs a T-350 or T-400 too. That adds up fast when something new fails.
A T-400 is the least expensive option that will consistently live behind a big block. A performance rebuild kit and a 34-element sprag are all that is needed. No hard parts or special assembly is required. If you don't have too much cam a GM big block motor home spec torque converter is an inexpensive option that is strong enough to get by with a pretty strong big block in a truck. That plus a TransGo shift kit will make a good rebuilt T-400 live a long happy life behind a strong street driven big block.
A T-350 can be made to live with a big block as well but the cost isn't much less than a T-400. The big problem is the smaller output yoke of the T-350 isn't up to the task. The cost of an upgraded part negates any savings you had in choosing the T-350 over a T-400.
If you want overdrive then you have two common options. A Gear Vendor type add-on overdrive unit for the T-400 or a 4L80E trans swap. A Gear Vendor for the T-400 is the least expensive option, is well proven and has been around a long time. They are pretty easy to find used for around $1000 complete. I bought one new in 1987 for my Chevelle and loved it.
The trans controller alone needed to run the 4L80E will cost you more than a used Gear Vendor unit. The big factor with the 4L80E is that it needs a better torque converter. The stock one is horribly inefficient. A decent aftermarket one is right at $1000. Add in a quality rebuild to the 4L80E and you are close to double the cost of a rebuilt T-400 with a Gear Vendor overdrive. A 4L80E will also need an electric speedo or a cable-x device adding even more cost to the swap.
You can also run the T-400 now and look for/save up for a Gear Vendor overdrive unit while you are enjoying your truck. You would just need to have your driveshaft shortened when you install it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-28-2013, 11:40 PM   #157
weaintscared
I sold the T56, now I'm going with an auto,, I have an electric speedometer so I was told by a local guy he could build me a 4l60e that would work for me for $1400.00 with a 2500 stall,, he said it would hold 6-700 hp with everything he puts inside it, he was naming out a lot of upgrades and something about changing out the Solenoids too, Is this a good price?
Old 05-03-2013, 10:21 AM   #158
Comerz
man keep us updated on that truck bad ass!
Comerz is offline   Reply With Quote
Old 05-07-2013, 10:12 PM   #159
weaintscared
Will do,,,I'm getting ready to start back to work on it... I had bought a house about 4 months back and redone it from one in to the other and it caught fire and burned the back part out of it so I've been busy trying to get it rebuild,,, man I wish the Insurance would have been in effect I would be letting someone else do all this nasty work of rebuilding it,,,,but it almost done a few more days
1 more inspection and 1 more meeting with the insurance co. Hope it never happens again!!! It hurts when you don't have insurance !!!
Old 05-07-2013, 10:36 PM   #160
Xeen
Xeen's Avatar
It's a competitive price, make him guarantee it though.
Old 05-09-2013, 10:05 AM   #161
Comerz
ouch.... bet that hurt the pocketbook lol
Old 05-15-2013, 01:15 PM   #162
weaintscared
Hurt really bad,,, but it fixed and now it time to get back to my trucks
Old 05-15-2013, 03:56 PM   #163
nlped
nlped's Avatar
I read the whole thread. You're right, you have yourself a moneypit too.
I like the firewall and the gas door set-up. I may have to steal that one.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-15-2013, 06:11 PM   #164
weaintscared
Hope it's worth it when I get it done!!!!
Old 07-08-2013, 09:43 PM   #165
weaintscared
Well I put my motor in my Old Rusty Pantina truck for now while I'm working on my good truck,,, running me a sleeper for a while
Old 07-21-2013, 10:31 AM   #166
weaintscared
Well motor runs good had th change the headers out to a set of mids I bought a set of stainless steel and they look good
Old 07-26-2013, 11:19 PM   #167
weaintscared
What y'all think?
http://m.youtube.com/watch?feature=s...eature%3Dshare
Old 07-26-2013, 11:39 PM   #168
MarineChevyDriver
MarineChevyDriver's Avatar
What y'all think?
That's yours? Nice sleeper! You going to leave it that way?
MarineChevyDriver is offline   Reply With Quote
Old 07-26-2013, 11:45 PM   #169
weaintscared
O yea Old Rusty is keeping the Pantina look been sitting for over 10 year before I bought it.
I might tub the wheel wells a little to set some bigger meats under it.
Old 07-27-2013, 12:04 AM   #170
MarineChevyDriver
Looking good an sounding good man! Hopefully mine will work that well!
Old 07-27-2013, 09:51 AM   #171
weaintscared
I'm sure your will, I need to get back to work on my Money Pit and get it ready so I can have it on the road it will be a really nice ride,,, 2 years in the making
Old 07-27-2013, 10:05 AM   #172
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Nice work on both the truck and the shop.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 07-30-2013, 01:31 PM   #173
weaintscared
Thanks it all time and money,, that a lot of time to get a little money to put into them both..
Old 07-30-2013, 01:52 PM   #174
mcbassin
Still Learning
mcbassin's Avatar
Wow! that was a hell of a burn out.
Old 08-12-2013, 10:59 AM   #175
weaintscared
Thanks guys I'm still working on my build a little at a time. I guess i'm going to have to build myself another motor for my truck since the 502 ended up in Old Rusty,, Man it will turn some heads I can be rolling at 25/30 mph and kick it and smoke up the road,,, Its a Beast!!!
http://www.youtube.com/watch?feature...are&nomobile=1
