Old 10-26-2011, 08:25 PM   #151
litew8
litew8's Avatar
Re: Project "My Happy Mess"
Seems others have had the same problem. Looks like we will have to modify. See post #24, but I think my circumstances are more severe.
http://67-72chevytrucks.com/vboard/s...d.php?t=485705
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-26-2011, 08:38 PM   #152
litew8
litew8's Avatar
My older Brother (thanks!) is suggesting this -
"This bracket is low profile for vehicles with little hood clearance. Short water pump small block Chevy. Tall valve covers are ok."
http://www.nostalgicairparts.com/air...r-side-237.php
or this one (but I don't think it'd clear the frame) -
We'll try and mod the heck out of the original first!
Old 10-26-2011, 09:12 PM   #153
litew8
litew8's Avatar
^ Not to mention, PS wouldn't be able to bolt up with the last pic.
Old 10-26-2011, 09:18 PM   #154
JDeere550
JDeere550's Avatar
you should try a longer belt, and push that top bracket piece down, that's what i did with mine lol.
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
Old 10-26-2011, 09:19 PM   #155
litew8
litew8's Avatar
Originally Posted by litew8 View Post
I've got the valve covers and spark plug wire loom kit tonight.
The wire loom kit turned out to be a BIG POS and I am returning it.
They threw all the crap in a small bag and called it good. This was a kit from GMPP.
Old 10-26-2011, 09:22 PM   #156
litew8
litew8's Avatar
Can't because the top bracket is too short to even reach the alternator - even when the alternator is pressed up against the valve cover.
It's hitting the valve cover in this pic. The bracket not reaching the hole by about an 1"
Then take into consideration for tension, and it's just way too far off.
Not sure the freeze plug caps will remain, some are giving me grief over them. lol
Old 10-26-2011, 09:50 PM   #157
litew8
litew8's Avatar
I think this is the one you recommended VA, looks like it'd work, for $139!!!
http://www.jegs.com/i/March+Performa...20133/10002/-1
PDF http://www.marchperf.com/instruction...structions.pdf
Old 10-26-2011, 09:59 PM   #158
VA72C10
VA72C10
VA72C10's Avatar
This is the one I was thinking of (39.95 shipped) but it's passenger side. LWP
http://www.ebay.com/itm/SBC-Chevy-Bi...f#ht_755wt_905
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-26-2011, 10:13 PM   #159
litew8
litew8's Avatar
Okay, thanks. Don't want to get into changing much else. We'll see how a modification works first then I guess go from there if nobody has any other suggestions. Wow, why they make this stuff so incompatible is beyond me.
Old 10-26-2011, 10:39 PM   #160
litew8
litew8's Avatar
Just noticed, the March product, same numbers - different diagram in PDF
Old 10-26-2011, 10:42 PM   #161
litew8
litew8's Avatar
My older Brother also suggested this one...
http://www.classicchevy.com/chevy-al...1955-1957.html
Chevy Alternator Bracket Kit, Small Block, Short Water PumpExtra Clearance, 1955-1957
Mounts Alternator On Driver's Side
Requires Use Of 1969-Up Cylinder Heads
Extra Clearance For Tall Valve Covers, Multiple Carburetors & Fuel Injection
Mounts High Over Valve Cover
Also Works With Vortec Heads
Will Not Work With Power Steering Pump P/N 53-28
Old 10-26-2011, 10:46 PM   #162
litew8
litew8's Avatar
PICKUPMAN posted the different styles for our trucks (longer = 72' ?)
That longer one looks like it might actually work.
Old 10-26-2011, 10:58 PM   #163
litew8
litew8's Avatar
This engine has the longer bracket from a 72' I think.
Look how much more movement it could have to the right.
Old 10-26-2011, 11:07 PM   #164
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Why don't you just cut that upper bracket and add 1.5" more steel in there?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-26-2011, 11:21 PM   #165
litew8
litew8's Avatar
Hence the "modification" I've been mentioning. Pay attention Ryan!
Though, not certain the structural/aligning integrity would be adequate if we extend it.
That 72' bracket looks like candy! Meaning I might have to find me one.
Old 10-27-2011, 02:01 AM   #166
litew8
litew8's Avatar
Update, "The Fixer" had/has taken care of the bracket fitment issue... Relocation
Old 10-27-2011, 03:21 PM   #167
litew8
litew8's Avatar
Spoke too soon.
Updated today, the relocation of the bracket still did not extend enough to clear the valve cover. This option may have worked for another build, without the E-Tec heads - but not for me. So we decided to mod the bracket and extend it out. To do that, the furthest we could extend the bracket would require a 54"+ v-belt to work. 55" is too long because pivoting the alt. that far would end up loosening the belt past adequate tension needed/required. Therefore, we need a 54"+ belt - which NOBODY has.
Old 10-27-2011, 04:04 PM   #168
Dieselwrencher
Yep, that sounds like my kind of luck.
Ryan
Old 10-27-2011, 04:30 PM   #169
JDeere550
JDeere550's Avatar
ahh i see, i have that long one. i didn't know they made two lengths for em. so alls i did was buy a longer belt that's why it must have worked for me.
Old 10-27-2011, 06:10 PM   #170
litew8
litew8's Avatar
^ Guessing you don't have the same setup as I do.
Update - Found a 54.5" Goodyear V-Belt at Midwest Wheel on the East side of town.
Will try tomorrow and see if I can still get away with using Stock brackets.
Also painted the steering gear box.
Old 10-27-2011, 08:38 PM   #171
litew8
litew8's Avatar
If all else fails, supposedly these brackets for Corvettes are interchangeable with ours.
The lower bracket pushes the alt. out towards the driver's fender (what I'd need) - per forum member Tx Firefighter.
Copyright ©2011 Corvette Central All Rights Reserved
ALTERNATOR ADJUSTING BRACE (UPPER)
Description 1975-1976
Corvette Central #: 303360
Original GM #: 460754
Corvette Central .com
ALTERNATOR SUPPORT BRACKET - 327 / 350 (LOWER)
Description 1964-1971
Part# 302016
Unless there's a different LOWER bracket than pictured above - this is the one shown in the diagram above.
Not sure if the LOWER bracket is what TX Firefighter was referencing (no part number provided for LOWER).
Maybe he'll be kind enough to show up and provide details.
Old 10-28-2011, 03:36 PM   #172
litew8
litew8's Avatar
Friday Update -
Got the Goodyear 54.5" belt this morning.
Fits PERFECT! Alternator extends to the brink of no return,
belt tention is just right. But, the alternator still comes
into contact with the valve cover just a little. We're going to shave
the alternator a little bit later.
The driver's side valve cover also comes into contact with the
ram horn exhaust manifold. We shaved the exhaust manifold down
a little bit, and will shave some more later.
Got the fuel line bent, installed inline filter. Fuel line
runs up underneath intake manifold, to the carb.
Time to shave the exhaust manifold a little for valve cover clearance.
Relocation of the upper alternator bracket - does work with 54.5" Goodyear Gator belt.
Still considering the Corvette brackets, as they'd extend the
bottom position away more. Will look into at a later date.
Just noticed the writing on the new belt says "Hencho en Mexico",
just like the block. SOB! And the valve cover
made in Taiwan. Great, just great.
Old 10-28-2011, 08:19 PM   #173
litew8
litew8's Avatar
The LOWER bracket mentioned above in my post is not correct.
Please see below for the correct version. Much more expensive
Part# 303044
Price 115.95
Description 1979-1982
No image. Click link to see.
Old 10-31-2011, 01:02 PM   #174
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
cool build great idea on the fuel line
John
1999 Toyota Tacoma 4x4
Old 10-31-2011, 07:44 PM   #175
Dieselwrencher
Nice work.
Ryan
