03-06-2012, 03:07 PM | #151 |
Re: 67' C10 Build V8 Conversion & 700r4 trans
I Bought New, but found a bad Lower A-arm Tube bearing, the threads were bad.
I called and talked to Stan Yesterday at ECE, he said they would get another one out right away. In the mean time i can work on either the Power Brakes or Power Steering, till i get that part from ECE, good thing is that ECE is only 2 days away from me so i should have it this week.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, |
03-06-2012, 03:12 PM | #152 |
67cheby
looking great !
03-15-2012, 11:26 PM | #153 |
lookin good
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-16-2012, 12:03 AM | #154 |
Sorry guys, iam away visiting in-laws and out of state for at least another week.
Once i get back it will be full speed ahead
03-22-2012, 07:40 PM | #155 |
I'm back,
Got back yesterday here's what I did today. 1. Painted and Installed new heater core. 2. Checked the brake master booster for fit i will need to cut the booster arm to the correct length. Here's a few pics
03-22-2012, 07:41 PM | #156 |
wow that previous shot I was rolling the truck
Here is some more
03-25-2012, 09:45 AM | #157 |
Just checking up on some builds,i'm taking a break on on my project so i can see what everybody doing on there build.I have to say you have came long ways on your build & it's looking good.Love the wheels & hope to them soon on your truck.Keep up the hard work & keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
03-29-2012, 02:03 PM | #158 |
I did i little bit more work on the 67'.
I shortened the brake booster rod to the brake pedal. and then mounted the brake booster & Brake Master. Of coarse the Brake lines did not match up, I was hoping , but did nto think i would be that lucky. Mounted the steering linkage Here are some pics
03-29-2012, 02:06 PM | #159 |
I am waiting on rubber bump stops they should be here Friday.
I should have the front suspension back together by Monday
03-29-2012, 02:08 PM | #160 |
Motor & Trans then goes together, and will be installed
03-29-2012, 02:11 PM | #161 |
a couple more pics
03-30-2012, 12:15 AM | #162 |
Looking good buddy!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
03-30-2012, 09:58 AM | #163 |
67cheby
Super nice !
04-07-2012, 09:55 AM | #164 |
Ok just as suspected i let it sit for a couple of weeks and no one else works on it during my two weeks off.
I guess i better get back to working on it. I have the parts back from the powder coater. I did get some of the steering parts back on I need to torque the front end bolts. I pressed in all new bearings on the a-arms, and had some torqued. Now it is time to install the a-arms Whats the saying; Apart FAST, Together SLOW It's time to turn up some speed, I hope
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 04-07-2012 at 10:11 AM. |
04-12-2012, 11:04 PM | #165 |
Today put the front Control Arms on,
Springs are on, Brake rotors and wheel bearings are on. Pictures to follow
04-13-2012, 10:46 PM | #166 |
Here are some pictures of the front suspension assembly that I promised.
04-13-2012, 10:47 PM | #167 |
and more pics
04-13-2012, 11:05 PM | #168 |
Very nice job!
Dustydog 1940 Ford 2D SDN 1970 GMC SB 2004 C5 Vette |
04-13-2012, 11:29 PM | #169 |
looks fantastic did you have the rotors P coated?
04-14-2012, 12:12 AM | #170 |
VA72C10
looks awesome!
Looking for a 67-72 swb or blazer project in or around VA. |
05-15-2012, 02:43 AM | #171 |
Been a while what's up .....update
QUOTE=zicc1835;5312419]looks fantastic did you have the rotors P coated?[/QUOTE] Posted via Mobile Device
05-15-2012, 11:00 PM | #172 |
I made three 1/4" thick spacer plates on the plasma cutter, and mounted my power steering Gearbox.
been riding/modding motorcycles need moto vation to get back to the 67 pickumup
05-15-2012, 11:04 PM | #173 |
I also mounted the 1-1/4" dia front sway bar.
I will post some pics
07-07-2012, 10:01 PM | #174 |
Me too
04-13-2016, 10:13 AM | #175 |
Any update on this build? Just spent the majority of my morning at work reading up on this one - very inspirational!
I am in the midst of planning a basic build myself - 67 c10 with a straight 6/ 3 on the tree. Hoping to see a finished product - great, great work! |
