Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-13-2012, 04:50 PM   #151
68burbanontherocks
68burbanontherocks's Avatar
Re: 540 BBC 68 Burb Dually 54" Boggers on Rocks
So had to cut out the rest of the floor in order to get the bottom part of the firewall in place, it is kinda a pain but now its all done and im pretty happy with how it turned out.
68burbanontherocks is offline   Reply With Quote
Old 07-13-2012, 04:54 PM   #152
68burbanontherocks
So to fix the rocker boxes and reinforce them for the floor i put a 1x3 1/8 rectangle tube parrallel to it for the floor to slide into place and the body mount cross bars to weld to. Should be pretty stout.
Old 07-13-2012, 04:58 PM   #153
68burbanontherocks
So next i cut the rest of the floor out, and slid the new floor in, no bracing yet so it sags pretty bad just wanted to make sure the track idea would work, plus wanted to see what it would look like!
Old 07-13-2012, 05:01 PM   #154
68burbanontherocks
So then it was time to trace out the piece for the bottom of the firewall as well as the kick pannels and get them put in so that i could burn em in to there final resting place!!!
Old 07-13-2012, 05:06 PM   #155
68burbanontherocks
Got all the diamonds to line up then burned it into place.
Old 07-13-2012, 05:09 PM   #156
68burbanontherocks
Got the top of the firewall all boogered together and then got all the little panels to contour the inside of the kick pannel placement, capping off the air vent.
Old 07-16-2012, 02:20 PM   #157
thor
thor's Avatar
Yeah buddy! That's a lot of work (massive understatement)! Gonna grind those welds down and smooth 'em out?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 07-16-2012, 02:31 PM   #158
68burbanontherocks
Haha ill eventually grind them down to dynamat the inside of the truck. Got the floor in ill have to throw up some pics!
Old 07-17-2012, 10:26 AM   #159
RatRod68
RatRod68's Avatar
wahoo! More progress! Are you going to be running A/C and all the good stuff too?
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 07-17-2012, 11:12 AM   #160
68burbanontherocks
Psh no way! Robs power!! Haha the burb used to have a vintage air kit in it but i ditched it and now all you gotta do is roll down the windows speaking of windows i found a kit to eliminate the little vent window so you can just run a one piece window. I was pretty dang stoked about that.
Old 07-17-2012, 11:34 AM   #161
RatRod68
RatRod68's Avatar
yes, those kits are awesome. I only asked because you closed off the side vents! Mine doesn't have A/C (because of money, not the power aspect. lol) and those little side vents are my best friend.
build Threads:
Leftovers 68 C20
Semper Fi
Old 07-17-2012, 11:51 AM   #162
68burbanontherocks
Haha yea i hear ya there man. I just didnt want any debris ect getting in the cab. Plus when i lay dynamat down it will make it that much easier lol
Old 07-17-2012, 12:00 PM   #163
68burbanontherocks
Ok so i got the firewall in and now it is time to get the first piece of the floor in place then start making my body mounts to attach the floor to the chassis. Heres what ive got so far....
Old 07-17-2012, 12:02 PM   #164
68burbanontherocks
Decided to put the diamonds going down since im gonna dynamat the inside it would make no sence to just cover them up!
Old 07-17-2012, 12:04 PM   #165
68burbanontherocks
Just more floor shots
Old 07-17-2012, 12:08 PM   #166
68burbanontherocks
bottom of floor showing the diamonds. I think its a cool idea...
Old 07-17-2012, 12:14 PM   #167
68burbanontherocks
So my body mounts are just competition engineering hard poly universal body mounts. I used 4" grade 8 1/2 bolts and welded the bottom side washer to the head of the bolt. The reason i did that was so i could make a piece of tube that would attach to the chassis with a bolt sticking up through the floor. So there will be a nut and a washer coming through the floor. The benefit of that is that any time since the head is welded to the tube, i just have to tighten the nylon bolt and its done. Also ill know if the body mounts are getting loose by looking down at the nuts in the floor. Now heres some pictures to explain my idea.
Old 07-17-2012, 12:18 PM   #168
68burbanontherocks
body mounts
Old 07-17-2012, 12:20 PM   #169
68burbanontherocks
Body mounts 2
Old 07-17-2012, 12:22 PM   #170
68burbanontherocks
Damn! who is that sexy beast welding up a storm? hahaha
Old 08-01-2012, 01:24 AM   #171
68burbanontherocks
So ive been really busy, it was my birthday, wife and i's anniversary, and i went to the NHRA drags in Sanoma. However i have some great news, my truck is offically sponsored by Monster Energy. They are providing me with a vynil wrap as well as a booth spot at SEMA this year. Very excited, humbled and blessed!!!
Old 08-01-2012, 07:08 AM   #172
DINS 1
DINS 1's Avatar
very cool build!! how did you get monster to sponser your truck and a spot at SEMA
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 08-01-2012, 11:29 AM   #173
68burbanontherocks
As vague as it may sound, just gotta ask. Sent in a portfolio of my truck matching my sponsorship needs with there perspective goals and hope for the best. In my case it worked out...
Old 08-01-2012, 03:50 PM   #174
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your firewall is sexy man! The floor idea was spot on too! Congrats on the wrap and sponsorship, that's awesome! SEMA 12???? You better get cracking!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-02-2012, 02:05 AM   #175
thor
thor's Avatar
Congrats on the sponsorship! With an unlimited supply of Monster, now you can work around the clock. Ha!
54" boggers, big block, dually, monster truck, suburban
