#151 | |
Re: 1955 12 Valve NAPCO Clone
#152 | |
![]() We got the engine in last night. The firewall has a bunch of spare room. I prolly could have made it about 1 or 2" shallower. Its ok though. If I ever wanna move the engine back more I could probably run a mechanical fan ![]() ![]()
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
#153 |
Its nice to see that eng in there . You were kicken butt before your "set back" . Ive been sidetracked on mine lately. Were going to FL for a week in March. Had to do full brakes on my 05 3500. As well as ball joints , front u joints and rebuild the front driveshaft. That broke my budget. Not too bad tho. It would have had to be done in April anyway for commercial saftey.
Anyone know of any cool car guy things to do in FL ? Staying in Kisseme . I will need a daddy day out for sure !!!
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#154 |
Y'all have fun down there! That's a long drive from Canada isn't it?! I hear on your budget killer. I just bought new tires for my 92 Chevy and I had to redo the front end also. Luckily my parts are warranted. Does that Dana 60 go through ball joints often?
#155 |
Good news! I got it cranked again but it seems super retarded. I am thinking about skipping the second tooth so I can keep the pump in the fully retarded position for easier tuning. What are y'all's thoughts? Who all is running two teeth advanced and what pump positions?
#156 |
I will be a honest 24 hr on the road. Longer if I see Shiney, rusty , cool ,old stuff i want to look at ! The dodge hasent used a d60 since 2002. Its a AAM axle thats under there now. Its not bad on ball joints , 3 in 300,000 km. Im wating till it needs 2 at the same time . Then I will buy the dynatrack ones . I have there free spin kit in the truck now. I like there stuff.
#157 |
I forgot about them swapping to the AAM. Is it a pretty big ring gear and no more CAD? I'm not gonna lie I had to look up KM to miles to see what that was for me! In engineering school we used SI which was much easier to work with.
Here are some pictures last night when I cranked it. ![]() ![]() ![]()
#158 |
Man the pump looks so easy to work on like that. I wish I could move mine. All that good cdn road salt made the lines look like twisting the pump like that would lead to a real leak. Bummer . I wonder if anyone has a affordable complete line kit ?
#159 |
6>8 Plugless........
![]() Join Date: Sep 2007
Do you need different lines? I bet we have a set.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#160 |
Good news two days in a row. I'm getting suspicious. I was right about the timing being retarded. I pulled the injection lines off tonight and timed it the proper way with the dial indicator. I didn't have the fancy dial indicator that actually threads in to the injection pump so I had to rig something up with my magnetic base. Pump lift at TDC is supposed to be 1.25 mm or 0.049". When I checked mine it was 0.030" so it was off a good bit. I loosened the pump and advanced it until I got it to 0.050" or 1.27 mm and called it good. Threw it all back together and re bled it. It's running good now. I am gonna mark this for reference and do an 1/8" bump here soon. Also gonna mess with the full power screw. I need to get a new fuel pin and governor spring while I'm at it. I'm ready to burn rubber!
#161 | |
Good to hear. I am loving this build. Can't wait to see a video of the ol girl driving down the road. |
#162 |
This will be us soon enuf.
![]() Im going to stop a Summit in Georgia on my way to Fl. Get some steering u joints. I just realised in your thread that you had to use a gm box to fit the astro van u joints. My dodge box is new so I want to use it. Summitt has there house brand joints for $50. Not that bad I guess.
#163 |
I drove it tonight under its own power! It almost killed me cause my door got stuck and the fumes were filling the cab so i ad to Bo Duke it out the tiny window. I hope to get a video up tomorrow.
#164 |
#165 |
Sounds great man!
#166 |
Do y'all remember how I was saying things are going eerily good? Well I have been brought back to reality. I got the radiator installed and the belt put on. Also got the power steering fluid hooked up. I backed it out side little it run for about 10 minutes and then all the sudden it started missing. Barely ran for a minute and then died. It was acting like ran out of fuel. So I checked the fuel filter and it was full. I then pulled the feed to the pump and it was flowing a lot of fuel. When I went to crank it again I cracked the fuel lines and airiated fuel was coming out and it didn't have near the pressure it should. It will normally squirt all the way onto the fender. Now it is just bubbling out. I feel like something in the pump is the problem. Also it is leaking fuel out the vent on the diaphragm body. Anybody got any clues? It is so depressing
![]() Posted via Mobile Device
#167 |
Sweet . Congrads ! Your real close to being done now .
#168 |
Check to make sure the fuel shut off solenoid isn't pulling the plunger half way up. If you remove the sol, you can remove a plunger that's below the sol. Then put the sol back on to seal the pump. You then have to use the mechanical lever on the side of the pump to shut it down. Maybe try that and see what happens.
#169 |
I posted the above just a sec before you posted your bad experience .
Just wanted to clear up that I didnt mean congrads on your truck quitting . Im not that much of an ass. lol.... Keep at it . If it was easy then everybody would have cool trucks....
#170 |
I removed the little plunger from the ful solenoid and reinstalled it and it is still doing it. I forgot to say that. Any other ideas?
#171 | |
#172 |
If I had an extra pump, I'd send it to you. If you needed a p-pump, I could help you out.
#173 |
Are the VE pumps hard to rebuild? And do you have a p pump setup?
#174 |
#175 |
I will try to repost it.
