Old 02-11-2013, 02:37 PM   #151
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
I have some Bad news.
Apparently the truck that the Vortec came out of was hit so hard that it damaged the engine and they werent willing to warranty it, so I got my money back and now I'm looking for a engine and transmission again.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-11-2013, 02:43 PM   #152
gdavis
gdavis's Avatar
keep looking you will find it yet.
gdavis is offline   Reply With Quote
Old 02-11-2013, 04:45 PM   #153
Xeen
Xeen's Avatar
I stopped by Bobs Vintage Truck and picked up a few things.
A pair of chrome wing windows.
A pair of 15x8 Rally's.
I need to find someone who won't charge me $25 per wheel to sandblast them, when the time involved is 5 minuites per wheel, talk about a rip off, I would love it if I could make $300 per hour wouldn't you?
Old 02-12-2013, 10:11 AM   #154
Xeen
Xeen's Avatar
Steering column rebuild on hold for the moment while I wait for parts to arrive.
1) Shift Bowl special service tools.
2) Upper Inner bearing Retainer.
I now have the tools and know where to get the parts to repair 1971-72 GM truck tilt columns.
It took me roughly 20 hours worth of research to track all this down, it felt like I was researching for a big College paper, I might write a complete walk through for this to put in the FAQ section.
You got questions about the 1971-72 GM Truck tilt column? I got answers!
Old 02-12-2013, 02:40 PM   #155
gdavis
gdavis's Avatar
A small 30 pound sand blaster is only 90.00 at harbor frieght. But you need a 12 to 15 CFM air compresser to make it work. I bought one and I have saved a ton of money doing it my self. But it does make a mess.
Old 02-12-2013, 05:12 PM   #156
Xeen
Xeen's Avatar
I installed my Liscense Plate Panel, and Liscense Plate Lamp today just for something to do.
I couldnt help myself I used Stainless Steel Carriage bolts, no crummies on this truck!
I also modified the Lamp housing to accept 1/4" grade 5 bolts, and used nyloc nuts to lock it down.
Overkill? No such thing!
Old 02-14-2013, 03:25 PM   #157
Xeen
Xeen's Avatar
For all of you guys who have a GM tilt column partially torn apart with broken parts that dont seem to be available atleast for some of you I have good news.
Long story made short, I broke the upper Inner bearing retainer while cleaning it because it was 42 years old and brittle, now most of the time they are broken when you remove them from the get go which causes slop, well today there is an answer for this broken part you just have to know what to look for.
Saginaw who makes the 1971-72 tilt for the c10 pickup used that bearing retainer for the tilt mechanism clear up untill 1999 but they used it for the Upper Outter bearing, same part different application, but obviously the good news here is they made millions upon millions of them over the last 42 years and you can still get them.
Also if you lose any of the balls don't freak out, your local ace hardware store and probably others carry ball bearings of all sizes so they can be replaced, just take your caliper with you and measure to find the replacement at the store win/win.
Here is a picture of the bearing retainer.
Old 02-14-2013, 03:28 PM   #158
67cheby
67cheby
67cheby's Avatar
thanks for sharing !
67cheby is offline   Reply With Quote
Old 02-14-2013, 04:14 PM   #159
Vic1947
Vic1947's Avatar
Excellent research, will likely save someone down the line!
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 02-14-2013, 04:20 PM   #160
Bomp
Bomp's Avatar
Thanks for the great news.
I know of guys that have bought whole columns for that there part.
Bomp is offline   Reply With Quote
Old 02-14-2013, 06:11 PM   #161
gdavis
gdavis's Avatar
I know that thia will come in handy when i start to rebuild a tilt colum keep me in mind. If anyone knows where a good tilt for a 68 semd me a PM
Old 02-14-2013, 06:33 PM   #162
darkhorse970
darkhorse970's Avatar
[QUOTE=Xeen;5868648]
Stainless Steel Coolant Overflow Tank.
Stainless Steel Radiator Cover.
Stainless Steel Core Support Filler Panels.
QUOTE]
What supplier did all this stuff come from? I like it.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-14-2013, 07:07 PM   #163
Xeen
Xeen's Avatar
Everything is from LMC Truck.
Old 02-15-2013, 11:33 AM   #164
Low Elco
Good research! You oughta write up a small thread with pics on just that in the appropriate fourm and have it added to the FAQ list.
Low Elco is offline   Reply With Quote
Old 02-15-2013, 11:36 PM   #165
Xeen
Xeen's Avatar
I had to make several repairs to the tilt column.
Here is a picture of the tilt housing with the bearings repaired lubed and installed.
The leading edge of the turn signal lever access cutout on the housing cover was caved in so I repaired it using various metal working dollys, a #3 flat blade screwdriver and a metal working hammer.
Old 02-17-2013, 12:49 AM   #166
Xeen
Xeen's Avatar
I spent the day in KC at Vics house rebuilding my GM truck tilt steering column.
Vic went all professional restoration on it and it looks like it just rolled off of the assembly line.
He has lots of pics of the process so I will let him post them up.
Old 02-17-2013, 12:52 AM   #167
Low Elco
Glad it came out good! Tried to get up there, got hung up. Hope y'all had a good day.
Old 02-17-2013, 02:02 PM   #168
Vic1947
Vic1947's Avatar
Ran into a few snags during the column build, but nothing that couldn't be fixed. First order of business was to finish disassembly of the column. Brian had a tool that for that purpose, but the tang on the end of it had snapped off during the first attempt. We cleaned up the leftover carnage and then welded a new tang on the tool. We were then able to finish removing the liner tube. Next we bead blasted the old chipped paint off and sprayed gray primer on the bare metal.
At that point everything was ready for reassembly.
Victor
Old 02-17-2013, 02:18 PM   #169
Vic1947
Vic1947's Avatar
First order of business was to draw the liner tube back into place using the installer tool. With this done, the threaded retainer for mounting the tilt pivot assembly was inserted. To do this, you have to first rotate the cast aluminum housing all the way clockwise and insert the ear on the ring as far left as possible. Then rotate the housing counter clockwise while working the retaining ring into the slots. A bit tricky, but with a little patience, it will drop right into place. Just don't forget the wavy tensioning washer behind it! Speaking of forgetting a step, before you draw the inner liner tube into the cast housing is a good time to route the wiring. We didn't, so later on we had to use a pin removal tool to separate the wiring from the plug in order for it to fit thru the housing. Duh!
Victor
Old 02-17-2013, 02:27 PM   #170
Vic1947
Vic1947's Avatar
Next, the bottom shaft bearing was installed and the tilt pivot assembly was installed. There are four bolts that require a torque of 35 in/lbs. Since there were no locking washers, we used a drop of blue loctite on each of them to insure they stay put. Probably overkill, but better safe than sorry. If you forget to install the rubber pieces on the outer column tube like we did, not to worry. A little bit of dishwashing soap will allow them to slide over the shift arm and onto the tube. Next step was to install the other half of the tilt pivot assembly and insert the pins.
Victor
Old 02-17-2013, 02:51 PM   #171
Vic1947
Vic1947's Avatar
Once the pivot pins are in place, the long tensioning spring and its retaining cap can be installed by pushing the spring in with considerable force and rotating the cap CCW. The fine thread nut was installed on the shaft and drawn up carefully until just the right amount of drag was present when turning the shaft and there was no play. With clean, re-packed bearings it felt smooth as silk.
All that's left to do at this point is to fit the signal canceling / hazard flasher assembly into the housing cover and bolt it into place. It's worth noting that the routing for the wiring is important and needs to go under the L shaped hook on the signal assembly so that it exits the housing in the correct location. We had to remove and reassemble the signal assembly several times to get the wires situated to where they didn't bind up. We also discovered that the signal assembly was made such that one of the mounting pads was too thick and caused the assembly to fit at an angle. We filed it down to match the length of the shoulder on the retaining bolt.
And one other caution... The retaining bolts are 12-24 and are three sided instead of round. As such, they act like a tap when going in and out of the hole threaded into the soft cast aluminum. Because the shoulder was unable to come in contact with the housing due to the aforementioned problem with the mounting pad, the threads on that hole stripped. Brian is currently tracking down a help-coil kit to repair the damage. Otherwise it would be a done deal right now.
Lastly, the recessed slot on the signal assembly where the turn signal lever mounts was too narrow. So we had to carefully sand a little off each side of the lever to get it to seat correctly. Those are some of the things we found during reassembly, so hopefully anyone that sees this will be forewarned.
Victor
Old 02-20-2013, 06:40 PM   #172
Xeen
Xeen's Avatar
My new Boyd Welding Aluminum Stealth EFI fuel tank was delivered today.
I decided to have them send it with an optional EFI cover plate just incase I decide not to go with a EFI engine.
Old 02-20-2013, 07:26 PM   #173
gdavis
gdavis's Avatar
That tank sure looks sweet. I like. There is a company near me that makes tanks I am going over to see what one will cost. I need to take the measurments with me.
Old 02-21-2013, 10:05 PM   #174
Xeen
Xeen's Avatar
It looks like Vic and I are going to work out a deal on his 67' Stepside bed because he wants a fleetside bed on his truck.
Although it's a pretty solid old bed it's got some issues like the P.O. tried to french in some tail lights so we are going to cut them out and restore the original contour of the fender, then hand dolly/pull out any dents in the fenders, straighten out the bedsides, and header panel, primer it and seal it with some krylon rust tough and call it a done deal.
The bed needs a couple of cross sills and the tailgate is shot so I will head to LMC and buy those.
With Vics metal working skills that bed will be awesome when hes done with it.
Vic doesn't know this yet but hes going to have to patch the front fender marker light holes to match the 67' rear fender surprise!
Old 02-26-2013, 09:39 PM   #175
Xeen
Xeen's Avatar
Here is a look at the Backup Lights installed into the brackets Vic machined, the wide part of the original bracket profile will be hidden by the bed.
Vic did a great job and I think the results were worth the trouble.
1968, chevrolet, restomod, stepside, swb
