Old 02-23-2013, 12:56 AM   #151
Jimbabwe
Jimbabwe's Avatar
Re: PB bagged 69 stepside-because Leon asked...
You could raise the entire floor (more than 4-5" on this) or you could cut the center section out. Mine just had a piece of plywood in the bed, so that's all I did because I'm not sure if I want it raised, or just with a notch cover yet.
Jimbabwe is offline   Reply With Quote
Old 02-24-2013, 12:49 AM   #152
jblaust
jblaust's Avatar
I want to keep my wood bed...I love that look. I want the shallow bed raised up looking like stock wood
jblaust is offline   Reply With Quote
Old 03-16-2013, 10:33 PM   #153
1lo67
1lo67's Avatar
l'm Loving the look of your StepSide,Very Cool. i have one that i'm about to get started on soon as all the porterbuilt parts get in. Has Nate told you what rear sway bar will work with your setup? Mine will be the inboard bag setup narrowed rear as well and I think a sway bar would help out alot. Keep posting!!!!!!!
1lo67 is offline   Reply With Quote
Old 03-16-2013, 11:39 PM   #154
Jimbabwe
Jimbabwe's Avatar
Thanks! I appreciate that. Nate did mention the possibility of adding a rear swaybar after the suspension install was completed, although I haven't asked him any more about it yet, but I do agree it seems like a good idea. You haven't ordered it yet with the rest of the dropmembered stuff?
Post 'em up once you get it going, I'd like to see the progress.
#TeamStepside!!
Old 03-16-2013, 11:56 PM   #155
1lo67
1lo67's Avatar
I need to give Nate a call this coming week and talk to him about a rear sway bar, i haven't seen one for the rear on his website.. my parts should be here in the next few wks as soon as i get started wrenchin on it i plan on starting a build thread. how is the
5" backspacing working out on the front? i talked to 'SPOT' a few times about his setup and he's runnig 6.25 on the front, just wounding how your 5" bs is workin out with PB DM, since i haven't ordered wheels yet.
Old 03-17-2013, 12:08 AM   #156
Jimbabwe
Jimbabwe's Avatar
Yeah, I didn't see the rear swaybar on their site either. It may be something they can build if you'd like one, not sure.
My front backspacing is actually 4.5". That's because those wheels were on my previous truck that was static dropped and when I ordered them that's what everyone running static seemed to be using. I notice on the bagged trucks that can be laid out 5.5" seems to be popular. I don't have any issues, except if the truck is almost on the ground the tires slightly rub the inside edge of the fender when trying to fully turn to lock. I may roll the fenders, but it's not really necessary. I'll go with more backspace if/when I get different wheels. I did run the CPP modular spindles which narrow the track width as well as the PB control arms, so that helps.
Did you talk to Spot recently? I haven't seen anything new on his page. I love that truck.
Old 03-17-2013, 12:21 AM   #157
1lo67
1lo67's Avatar
I plan on going with either 5.5 or 6.0 backspacing , i also ordered the CPP Modular spindels, D52 calipers and dimpled/slotted rotors. havent talked to Spot in awhile i think he's pretty busy at work. i love that truck also it's what got me thinking about puting a stepper on the ground. But i think yours is kickass to!!! tonight is the first time i've seen it.. it needs to be over in the build section it would get a ton of hits over there. I'l talk to Nate this week about the rear sway bar and let you know what he comes up with.
Old 03-17-2013, 12:39 AM   #158
Jimbabwe
Jimbabwe's Avatar
Yeah, it was his truck that made me pick up this stepper after looking for another one for a while, with the same intention of bagging this time around.
Thanks again for the positive words. Maybe I should have a mod move this over to the build section and go back in time and post a bunch of the many pics I have. I don't want to bore anyone with the same old sameold. Mine's got nothing on some of those trucks!
Yes, let me know what they tell you about the swaybar.
Old 03-17-2013, 12:57 AM   #159
1lo67
1lo67's Avatar
Man your truck is Sweet and you want bore anyone on this fourm with pics!!!!
POST AWAY I SAY...lol Start a build thread over in the build section i wanna see more..... what drive shaft you gonna run a one or two piece?
Soon as it talk to someone over at Porterbult about the sway bar i'l let you know.
Old 03-17-2013, 01:03 AM   #160
Jimbabwe
Jimbabwe's Avatar
Hah! Nice.
The driveshaft is a two piece.
Old 03-18-2013, 04:21 PM   #161
1lo67
1lo67's Avatar
Talked to the guys over at Porterbuilt, they DO NOT sell a rear sway bar for the rear Dropmember....
Old 03-18-2013, 04:40 PM   #162
Jimbabwe
Jimbabwe's Avatar
Damn them!!
Ahh, but would they make you one if you asked nicely?
Old 03-18-2013, 05:04 PM   #163
1lo67
1lo67's Avatar
Doubt it....LOL
Old 03-18-2013, 07:42 PM   #164
Bennett68C10
Bennett68C10's Avatar
1lo67 if your running the Extreme front dropmember I know Porterbuilt recommends 5.25-5.5" BS for the front on a 8.5" wide wheel. The dropmember already narrows the trac width 1.25" per side. I went with the touring front dropmember on mine which narrows the trac width .25" per side and had to use 1" narrowed arms for my wheels which are 20x8.5" with 5.25" BS. Nate said this is what I need to lay out. I went with the touring so I would have more clearance for my BBC. Nate assured me it would lay out with my 2.5" drop spindles and 28" tall front tire. I can't wait to get it in and installed so I can find out.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-18-2013, 08:12 PM   #165
1lo67
1lo67's Avatar
X2 on Can't wait to get it installed!!!!
If my stance turns out as nice as Jimbabwe's i'l be a happy camper...
5.5 BS sounds like a perfect number.
Old 03-18-2013, 08:27 PM   #166
Jimbabwe
Jimbabwe's Avatar
Here's a shot of what it looks like from outside with the 4.5" bs. Not as pulled in as the increased bs most are using, and I really like that more narrowed track width look a 5.25" bs gives (besides the clearance) which some hate.
It doesn't hit anything, thankfully, aside from that slight rub I mentioned. Maybe the tire being a hair under 27" helps. I had ECE 2.5" dropped spindles, but I got the modular CPP 2" ones because they also narrow the track width and I don't have the money for new wheels right now, otherwise I'd have 20/22's on there.
I await both of your progress pics!
Old 03-18-2013, 08:29 PM   #167
Jimbabwe
Jimbabwe's Avatar
When I got an alignment, the guy put a crapload of spacers on there to get it right, and that was set at 5" because the truck couldn't go lower with the tools on the wheels!
Old 04-18-2013, 12:27 PM   #168
Jimbabwe
Jimbabwe's Avatar
I think the truck officially has a name now.
Old 04-18-2013, 10:06 PM   #169
Rochlow
Damn, I love this truck
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 04-18-2013, 10:16 PM   #170
Jimbabwe
Jimbabwe's Avatar
Thanks!
But do you think "Chimp Knuckles" is better than "Ground Cover"?
BTW, that's not actually painted on the truck, just a p-chop for my amusement!
Old 05-28-2013, 05:33 AM   #171
jamesrussell26
nice truck and build
jamesrussell26 is offline   Reply With Quote
Old 05-28-2013, 08:41 AM   #172
cericd
cericd's Avatar
Any updates on this build?
As far as the name goes, I don't know what "Chimp Knuckles" means but I do know I like it better than "Ground Cover".
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-28-2013, 10:37 AM   #173
Jimbabwe
Jimbabwe's Avatar
Thanks! I recently installed power steering and power brakes. Now the truck is a pleasure to drive. The Porterbuilt suspension is excellent; highly recommended if you're thinking of dropping your truck. I'm getting lot's of snapped-neck double-takes driving around. Just a few bugs to still figure out like blown compressor fuses and a slow leak up front. After adding check valves it no longer airs out overnight. Hell, this isn't even the "build" section, I hope people aren't getting bored or annoyed seeing this here, which started as a few suspension pics posted for Leon!
I was thinking "Ground Cover" as in: it's green and spread out low on the ground, but I did a pchop of someone's truck for them and another member said to go lower, it should be dragging on the ground like chimp knuckles, and it stuck.
Here are some pictures...
Old 05-28-2013, 10:40 AM   #174
Jimbabwe
Jimbabwe's Avatar
Wilwood master, CPP dual 8" booster, CaptainFab bracket with holes added for cool factor. Painted over gold iridite and matched the firewall patina on the bracket.
Old 05-28-2013, 10:40 AM   #175
Jimbabwe
Jimbabwe's Avatar
Taking it for a spin to test the brakes...
