Old 03-10-2014, 10:08 AM   #151
FarmerSid
FarmerSid's Avatar
Re: 55 Wagon Progress
I plan on brushing it on over sand blasted metal. I know it's not from HOK. I will let you know the specs on it are when I get it. What I do know is it is to be mixed 3:1. Any advice or tips on mixing small batch's to be brushed on?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 03-10-2014, 11:53 AM   #152
MP&C
MP&C's Avatar
Your local paint stores or even the online versions should have the paint mixing cups with the graduated measurement marks on the side to make it easier to mix.. After going through a couple batches you'll get the hang of how much is needed.
Robert
MP&C is offline   Reply With Quote
Old 03-15-2014, 09:08 PM   #153
MP&C
MP&C's Avatar
My nephew Chris stopped by to help this morning so we decided to work on the roof a bit. Added a guide coat and skimmed across it with the vixen file to show the high spots...
To help keep inside and outside guys on the same page, some reference marks were added from the door opening back, on inside and outside of the roof.
Worked the highs and lows, and thought we'd compare it to the other side. Making a profile template to match the good side...
Shown at about 6, 12, and 18". We're getting close..
Robert
Old 03-16-2014, 05:22 PM   #154
duallyjams
duallyjams's Avatar
Do you ever permit a complete stranger to hang out to watch and learn.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-16-2014, 07:11 PM   #155
swamp rat
swamp rat's Avatar
Tips on making couture templates?? what tools you use? I tried making one out of cardboard but that was a total failure LOL!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-16-2014, 07:51 PM   #156
MP&C
MP&C's Avatar
James, I'd think Deale is quite a drive, but anything is possible!
I used a scrap piece of 18 ga steel, held it against the roof, and opened up a compass to make a parallel mark. Cut it out on the band saw, checked the fit again, remarked, cut again...
Robert
Old 03-17-2014, 10:22 PM   #157
MP&C
MP&C's Avatar
Just to clarify the process used for making the roof template....
Start with a profile "blank" and span the profile you need to copy.
Using a compass, open up the span to insure it is wide enough to make the mark on the blank on both ends ...
Don't rotate the compass as you move it, this will make the radius larger than the original. Keep it "locked" pointed in the same direction as you glide across the roof surface, leaving the profile to cut....
Cut with a band saw, jig saw, tin snips, whatever is easiest for you and most accurate. Test fit and adjust as needed.
Robert
Old 03-17-2014, 10:57 PM   #158
Bomp
Bomp's Avatar
Thank you for this tid bit of info. As obvious as it is I learned something.
Bomp is offline   Reply With Quote
Old 03-18-2014, 12:40 AM   #159
swamp rat
swamp rat's Avatar
Yep, I appreciate it too!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-23-2014, 02:12 PM   #160
Jeff La
Thank you for taking the time to show others like me how to do this. It's really appreciated and I've learned alot.
Jeff La is offline   Reply With Quote
Old 03-26-2014, 05:44 AM   #161
Swed
Swed's Avatar
Im sitting here looking at the blinking marker in this text box and trying to figure out something flattering to type.. I thought that I was starting to learn how to do metal work.. but.. I.. you are a true inspiration! That knowledge you have is priceless.. I hope there is someone in your surrounding that can inherit your skills
thanks for sharing your work!
Johnny G
-----------Vehicles--------------
* Chevrolet C-10 Stepside 1962
* Audi A4 Avant Quattro TDI 2008
* Sachs Compact 50cc 1967
Swed is offline   Reply With Quote
Old 03-27-2014, 11:09 PM   #162
Bomp
Bomp's Avatar
Well, I started working on my 5" stretch cab '66 pickup roof skin project.
This is my second attempt on the skin.
Before I read your thread my first attempt started well but crashed and burn.
After studying your spot weld,planish,grind repeat I have a great start. Something doesn't feel like its going with the flow you have supplied the info on what to do next to get things back on track. Priceless!
I have followed every step like you did on the '55 roof section.
It is turning out WAY better this time than last.
Planishing. I made some practice pieces like you did to show the full penetration spot welds. Learned how the metal is effected and studied how it moves.
The way you show gives a guy a lot more control working the metal.
Learned tons watchin. Thanks.
You Sir have some, if not all, Serious Skillz
Thank you again.
Old 03-28-2014, 07:55 AM   #163
MP&C
MP&C's Avatar
Glad to hear it helped! Thanks for all the comments guys!
Robert
Old 03-31-2014, 10:40 PM   #164
MP&C
MP&C's Avatar
Trying to finalize the rear end of this car.. The tailgate skin didn't align too well to the upper lift gate, the gap was way out of whack. I guess this is what I get for installing the skin based on the old tailgate.
Note to self, don't fold door skins unless adjacent panel is there to set gaps..
Time to break out the door skin removal tool....
Flange unfolded....
Spoon was slid between the skin and inner panel and body hammer used to flatten out the crease...
Right side flange is now a bit short, so added a strip of metal..
Flange re-folded, just needs some fine tuning and finishing the corners..
Much better...
Robert
Old 04-01-2014, 12:26 AM   #165
swamp rat
swamp rat's Avatar
I understand all you did right up to the folding it over.
The outer skin was originally rolled over against the inner panel correct? but the outside edges of the inner panel were probably a little low creating the gap between the gate, so i guess you just placed a back up dolly where ya wanted the new fold to be? or did you also extend the inner panel lip as well?
I hope that made sense..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-01-2014, 06:20 AM   #166
MP&C
MP&C's Avatar
The inner panel's lip was left as was. I'll get some pics this evening of the tools used to fold the flange...
Robert
Old 04-01-2014, 05:34 PM   #167
MP&C
MP&C's Avatar
Here's the tools used to re-fold the flanges. (don't mind the hammer marks)
A mark was used on the front to indicate the new fold line. This press brake die was placed against the back side, and the flange tapped over. A flush tap against the face every now and then keeps the folded edge crisp..
That took the flange over about 90 degrees, then this modified gooseneck die was used to take it over to about 135 degrees...
At this point the gate was closed to verify gaps. A door skin hammer on the inside and a dolly against the outside skin was used to complete the fold..
Robert
Old 04-15-2014, 11:05 PM   #168
MP&C
MP&C's Avatar
Worked tonight on building new mounting brackets for the 55's battery tray..
This bracket supports the battery tray, bolts to the core support..
This bracket spot welds to the bottom of the tray and bolts to the inner fender.
This bracket goes on the wheel side of the inner fender well as a backer to bolt through.
The tabs spot weld to the ends of the tray for the battery hold downs..
Now just need to finish drilling holes and weld the parts to the "new" tray..
Robert
Old 04-22-2014, 11:49 PM   #169
boonedogs72
boonedogs72's Avatar
Wow impressive metal working!
boonedogs72 is offline   Reply With Quote
Old 04-23-2014, 09:37 PM   #170
MP&C
MP&C's Avatar
Thanks!
Had a bit of time in the shop this evening, so I worked some more on the rear of the wagon... I had left the outer part of the lower repair patch's seam of the lift gate (going through the bead detail) un-welded until the flanges all got folded, so tonight I got one side of that finished up...
Then the welds were cleaned up and some more tweaking of the tailgate gaps....
Much better...
Robert
Old 04-30-2014, 10:16 PM   #171
MP&C
MP&C's Avatar
Got the tail gate and lift gate gaps done this evening.
Now on to some quarter panel weld planishing..
Robert
Old 05-06-2014, 05:09 PM   #172
Cape Codder
Cape Codder's Avatar
Looking nice good fit. A few post back someone asked about mixing small amounts of epoxy, I have a set of stainless measuring spoons from the dollar store that are great for small mixes to touch up with a brush. They are easy to clean too.
Cape Codder is offline   Reply With Quote
Old 05-07-2014, 12:21 AM   #173
MP&C
MP&C's Avatar
Thanks for the tips!
Spent this past weekend at Gatormeet for a metal shaping workshop.
The first day started with a tuck shrinking demo, and showing the basics of the process and how the metal reacts. We also had the tuck shrinking fixture to use.
Camaro quarter panels are being fitted with gills for installation on a Firebird. This included fit up, trimming, Tig welding, and planishing..
The International farm truck had returned, so we were able to see the finished fenders from last year..
The rear fenders need reproducing as well, so the wire edging this year used bead roller dies..
We also discussed using hammer forms, and various pattern methods to determine shape..
Our new attendee this year learning some shaping...
Some rear corners fabricated for a truck bed..
Some practice at fusion welding using the Tig, here's the front showing some slight undercutting..
The rear side shows some good weld penetration in some areas and needs more practice in others..
Just to show that slight undercutting on fusion welding was not an issue in the joint's strength, the seam was clamped in the apron brake and bent to 135 degrees, with no detriment to the weld..
Saturday afternoon we spent some time discussing tips and tricks to help productivity and also to help open up to new methods and ideas. Here is a rotisserie style mount for a door, helping to locate it for ease of welding or other panel repairs....
Another project that Gator just picked up was this Camaro. The previous owner's substandard welding attempts severely warped and damaged many of the panels where most of the exterior panels will need replacing..
Looks like a project for the next Gatormeet! All in all, an awesome weekend for sharing and learning methods and ideas..
Robert
Old 05-07-2014, 04:09 AM   #174
swamp rat
swamp rat's Avatar
I would love to be able to attend a metal shaping workshop some day, i don't even know if they have something like that around here. At least i have some experience with shrinkers and stretchers, although don't own any of my own.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-08-2014, 09:32 AM   #175
duallyjams
duallyjams's Avatar
How does one get a invite.
James
IG duallyjams
