Old 11-10-2016, 05:02 PM   #151
Sean1985
Sean1985's Avatar
Re: RideTech's New C10 CoilOver Kits
I have the level 2 on my 67. Total night and day difference. It rides and handles great. My question is has anyone successfully put a rack and pinion with this setup? My only concern would be clearance with the sway bar and possibly ground clearance?
Sean1985 is offline   Reply With Quote
Old 11-10-2016, 06:12 PM   #152
aod92
aod92's Avatar
I would like to know this too
aod92 is offline   Reply With Quote
Old 12-27-2016, 10:44 PM   #153
Trackman101
Trackman101's Avatar
Originally Posted by GMC Canuck View Post
I'm using this kit with the muscle bar and nolimit rack and pinion.
the sway bar interferes with the rack (or vice versa) Is there longer end links available or any suggestions as to the best way to safely lengthen the end links.
The links do come apart and it looks they are held together by a m12 -1.75 threaded rod. I'm not sure a longer threaded rod is the strongest / safest method. I need about another 2.5"
Did you come up with a solution? I have the same problem.
Trackman101 is offline   Reply With Quote
Old 12-28-2016, 10:06 AM   #154
GMC Canuck
Not yet, the project has stalled / moving very slowly. I want to get all the sheet metal on the front end and get the ride height set so I can see where everything is going to sit.
I'm thinking my solution will be a tube spacer with a threaded rod.
GMC Canuck is offline   Reply With Quote
Old 12-28-2016, 08:09 PM   #155
SCOTI
SCOTI's Avatar
You guys might need to try adding mounting tabs to the upper a-arms & run the sway-bar links to them to eliminate the R&P interference.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2017, 10:06 AM   #156
chase@ridetech
chase@ridetech's Avatar
We have not used a Rack and Pinion setup on any of our C-10 trucks in-house. I do have different lengths and styles of end links as well as some weld-on end link tabs. You could possibly relocate the end link.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 01-24-2017, 06:46 PM   #157
Trackman101
I added a coupler nut and a piece treaded rod to give me some clearance. Still needs to be road tested to confirm that there is enough clearance.Not sure why this site decided to turn my picture sideways.
Does anyone know what the suggested backspace would be for the fronts using this set up? I'd like to put a 8 or 9" wheel in there.
Old 01-24-2017, 07:05 PM   #158
SCOTI
SCOTI's Avatar
Pics getting flipped is usually from a cell phone setting....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2017, 10:04 AM   #159
JohnJ@RideTech
JohnJ@RideTech's Avatar
That's a really good idea. Looks like it turned out nicely!
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 02-13-2017, 04:30 PM   #160
Vandals909
Can everyone put in this thread what wheel and tire combo they are running with the completed coil over setup? Year of truck and if rear end has been modified? Backspacing of the rims would be nice also!!!!
Thanks!! Any rubbing issues?
Vandals909 is offline   Reply With Quote
Old 02-13-2017, 07:25 PM   #161
Hugger67rsss
Hugger67rsss's Avatar
18x11 front with 5" backspace- 315/30/18 tires
18x11 rear with 4.5" backspace-315/30/18 tires
Rear is narrowed but I forget how much
No rubbing but I'm not using the Ridetech sway bar. It's a splined Nascar bar with the Ridetech mounting tabs cut off the arms.
Aarik Gault
1966 GMC SWB, Ridetech Suspenion
1968 Camaro autocross/track car
Hugger67rsss is offline   Reply With Quote
Old 02-13-2017, 11:26 PM   #162
Vandals909
Thanks. I do have the Ridetech front sway bar. Looking for a recommendation for 20's front and rear
Old 02-14-2017, 08:20 AM   #163
aod92
aod92's Avatar
I'm running 15x7 up front and 15x10 in the rear.
Old 02-14-2017, 11:40 AM   #164
Sean1985
Sean1985's Avatar
I'm running 20 by 8.5 front and 20 by 10 rear. Have the slightest rub at full lock. I have a 255 35 in the front
Old 02-14-2017, 11:41 AM   #165
Sean1985
Sean1985's Avatar
Rubbing the sway bar.
Old 02-14-2017, 12:48 PM   #166
GAc10boy
GAc10boy's Avatar
I love both of these trucks!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 02-15-2017, 01:11 PM   #167
MCB Matt
MCB Matt's Avatar
It is great to see so many C10 owners are now finding out just how amazing Ridetech Suspension truly is! We have been selling it for years now, primarily in the muscle CAR market and have helped bring it over to the 67-72 forum here! We sell a lot here now, one at a time, we are helping you guys achieve a gorgeous stance and an incredible ride, two things that were almost nonexistent in this market not long ago! Coilover, Air or StreetGrip, one of them is guaranteed to float your boat!
We are here to take care of your Ridetech needs!
MCB
MCB - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
Email: forums@mcbparts.com
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
MCB Matt is offline   Reply With Quote
Old 02-21-2017, 10:35 AM   #168
Vandals909
Bought my kit for Matt everything went smooth!
Anyone else running 20's front and rear with this kit? If so what size tire rim and back spacing?
Old 03-11-2017, 04:08 PM   #169
Trackman101
5" backspace and my tires will rub the front sway bar at close to full lock.
Old 03-11-2017, 08:26 PM   #170
MCB Matt
MCB Matt's Avatar
Do you have the full Ridetech front system, with their sway bar?
Matt
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
Old 03-11-2017, 08:29 PM   #171
Trackman101
Matt
I do. Post 158 is a pic of my set up.
Old 03-11-2017, 08:31 PM   #172
MCB Matt
MCB Matt's Avatar
Thanks again for the business, we truly appreciate it!
When it comes to wheels, actually measuring once it's all in is the best way. We have the tool that we loan out free of cost when you are buying wheels from us. It's a $450 tool that grips the tire and bolts to the rotor face, just as a wheel would.
With the ride height chosen, you can then turn the wheels with the suspension at ride height (remove coilover's). This is not a difficult or very time consuming job and it will ensure your wheels fit properly.
Matt
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
Old 04-02-2017, 01:04 PM   #173
Trackman101
I have clearance issues with the rear shock bridge and a wood floor. It clears with a metal floor. I wasn't expecting that. A couple hours and I fixed the issue but was disappointed I needed to do that.
.....Before and after
Old 04-02-2017, 01:23 PM   #174
aod92
aod92's Avatar
I had the same issue. What did you exactly do to fix it?
Old 04-03-2017, 10:42 AM   #175
Trackman101
I cut 5/8" out of the bridge by the mounting pads and rewelded them up.
I am not sure how a detail like this could have got missed by Ridetech.
