Old 01-29-2014, 11:59 PM   #151
Z10
Z10's Avatar
Re: 72 GMC Short Step Build
Steering Wheel installed
Got to install my steering wheel this evening. Brake lines arrived from Inline Tube, and some more Gates Power Grip heat shrink hose clamps which are very cool.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-02-2014, 09:36 PM   #152
Z10
Z10's Avatar
A/C Vents, Fuel Lines, Trans Cooler lines Installed
All I can say is that Car Boss is a great friend! I and Double E took the weekend off. I went to another wedding and he left town to visit a friend. I thought Car Boss was going to leave also and put some miles on his new truck, but instead he stayed behind and worked on the GMC.
He got the A/C vents installed, fuel lines competed and tested with no leaks and installed the trans cooler lines. When I found him around 5 this afternoon he was under the truck test fitting the new Magnaflow exhaust. What a guy!
Couple of pics of the A/C vents.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-02-2014, 09:43 PM   #153
sduckworth13
sduckworth13's Avatar
Everything is looking nice and clean.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-02-2014, 10:59 PM   #154
Z10
Z10's Avatar
Thanks Scott.
I just looked at your build again. You've got skills sir.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-02-2014, 11:31 PM   #155
sduckworth13
Originally Posted by Z10 View Post
Thanks Scott.
Thank you
Scott
Old 02-02-2014, 11:51 PM   #156
diceman50
While I was installing the trans cooler on Z10's truck yesterday a friend stopped by and asked me how I modified the ends of the 5/16" steel transmission tube to fit a 3/8" hose. As I demonstrated for him I took some pictures in case anyone else is interested.
I use my flaring tool tubing clamp and a modified swaging tool.
Name:  Tubing mods2.jpg
Name:  Tubing mods5.jpg
I then used my beading tool on the expanded end.
Name:  Tubing mods8.jpg
Name:  Tubing mods10.jpg
If you don't have a beading tool you can use the first stage of a double flare to make the retaining bead. However, you need to do that before you expand the tube with the swaging tool.
diceman50 is offline   Reply With Quote
Old 02-02-2014, 11:58 PM   #157
diceman50
Here's some pictures of the process using the first stage of the double flaring tool.
Name:  Tubing mods13.jpg
Name:  Tubing mods14.jpg
Name:  Tubing mods16.jpg
Old 02-03-2014, 12:04 AM   #158
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
z10 where can I get that steering wheel?
FRANKENSTEINC10 is offline   Reply With Quote
Old 02-03-2014, 12:28 AM   #159
Z10
Z10's Avatar
Here you go:
http://www.ebay.com/itm/Steering-Whe...3D151205916046
If you want my secret horn button overlay, you'll need one of these also.
http://www.ebay.com/itm/4PCS-GMC-CAR...#ht_1318wt_973
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-05-2014, 01:22 AM   #160
Average Joe
Average Joe's Avatar
Quality work!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-06-2014, 01:10 AM   #161
9teen69
9teen69's Avatar
Really nice build, love the custom work. You're some really talented dudes.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-08-2014, 01:29 PM   #162
Z10
Z10's Avatar
Stainless Magnaflow Exhaust with Cats installed
Carboss and Double E where busy this week, while I was back east working. Some more great progress this week. I decided to go with a Magnaflow stainless exhaust system with cats. This is a really nice system and fit's like a glove. Comes with an X-pipe cross over and fit very nice. Need to decide on some tips but it doesn't look bad with the bare stainless pipes exiting behind the rear tires.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-09-2014, 03:12 PM   #163
Z10
Z10's Avatar
Header Clearance
I had a request for pics of the header clearance, so here are a few pics.
These are Sanderson CC11.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-09-2014, 11:17 PM   #164
Z10
Z10's Avatar
Air Box Completed
Car Boss was busy this week! He also completed the Air Box. He's now just waiting on me to paint it and put it back in.
Double E, spent 5 hours routing the plug wires to his satisfaction and they look great! He also, finished wiring the power to the second fuse box and A/C evaporator, ran the battery connections to the starter and the main ground. I think the only thing left electrically is to mount and connect the horns.
We also, cranked the engine with Double E's computer hooked up, and every thing checked out. Also, we have oil pressure.
Car Boss fabricated the throttle cable and we started bench bleeding the master cylinder when we discovered we have a leak in one of the side plugs. We'll have to sort this out. Hopefully we'll wake up the beast this week!
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-13-2014, 11:22 PM   #165
Z10
Z10's Avatar
It's ALIVE!!!!!
Well actually we started the engine last night but my video didn't work. So here's day 2 after a little misc tuning.
Engine started on the first try and is running very smoothly, temps, pressures all look excellent and no liquid leaks. Tomorrow we'll get the airbox installed, horns mounted, bolt in the seat temporarily, bolt on the hood, and go get some fuel! This was a very good day.
Click on the photo to hear it.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-13-2014, 11:37 PM   #166
nds1968
nds1968's Avatar
Congratulations
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 02-14-2014, 10:42 AM   #167
knomadd
knomadd's Avatar
Sounds great!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-14-2014, 11:15 AM   #168
sduckworth13
Nice work, exhaust sounds great!
Scott
Old 02-14-2014, 10:11 PM   #169
Bomp
Bomp's Avatar
Congrats. Sounds great in the vid.
Gotta ask...... Will there be a burn out vid???
Bomp is offline   Reply With Quote
Old 02-15-2014, 12:44 AM   #170
65 Fuelie
65 Fuelie's Avatar
She sounds sweet.
65 Fuelie is offline   Reply With Quote
Old 02-15-2014, 12:58 PM   #171
diceman50
How about it Z10????
Old 02-15-2014, 01:52 PM   #172
Z10
Z10's Avatar
Hmmm? How about we brake it in for at least 5 or 10 miles?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-15-2014, 01:55 PM   #173
Z10
Z10's Avatar
Oh, Car Boss wanted me to let everyone know that the Shiny new Magnaflow system did not come with cats, but we did add Magnaflow cats. The cats are about 9" long, very small. Why cats? Not because I'm a greenie, but because the child bride doesn't like the smell of the exhaust in my 69 Camaro and I want her riding in this one.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-15-2014, 11:57 PM   #174
Z10
Z10's Avatar
First Drive
Another great day (for the most part). We got to drive the truck today. Double E hasd his computer hooked up and recorded about 10 miles of data, so I'm sure he'll be up tonight reviewing and making changes to the tune.
We did have some trouble though. The brakes were locking up, which cause the small burn out in Car Boss shop. This was corrected by adjusting the brake pedal travel and the new brake booster from CPP leaks, therefore we don't have any power assist. I don't think I mentioned that this week the CPP master cylinder leaked also, forcing me to buy a new one from a local parts house. I've had nothing but trouble with CPP on this set up. So, first thing Monday I'll have to call them and hopefully get a refund on the master and a new booster sent out.
Tomorrow I'll clean the truck up and see if I can sneak it back in Car Boss' shop to start the final A/C and Cruise hook ups.
Click on the photo to see the video
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-17-2014, 10:14 PM   #175
Z10
Z10's Avatar
Seat Installed
We installed the seat last Friday so that we could drive the truck, but will need to take it back out to install the carpet and seat belts. Truckseats did a great job.
And here's a pic of the truck in the Sunshine for the first time since October.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
