Old 04-06-2015, 04:51 PM   #151
Joe Pass
Joe Pass's Avatar
Re: 1965 C20 fleet side longbed DD low budget build.
Originally Posted by mattbert56 View Post
What's the cas lift and duration? Just stock
I will need to get that....The cam is out of a 290HP crate motor with break-in time + 20 miles or so. I kept the cam and lifters in order to be used in some project down the road...Its supposed to be the 300HP/327 cam from yesterday's factory muscle car design. The 290HP crate motor is a turd because the heads don't flow or even develop any compression to make power so the cam couldn't really work right. It might be right up your ally with a mild build and better heads.
Joe
Joe Pass is offline   Reply With Quote
Old 04-06-2015, 05:34 PM   #152
mattbert56
mattbert56's Avatar
Hmm. I'll give it some thought. I was looking for a cam with around .460 lift and 290 duration but I'll take whatever. are they roller Lifters?
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 04-06-2015, 06:11 PM   #153
Joe Pass
Joe Pass's Avatar
Its a flat tappet cam. ...remember you just wanted to keep it simple....haha
Old 04-06-2015, 06:30 PM   #154
mattbert56
mattbert56's Avatar
Hahah fair enough.
Old 04-06-2015, 07:21 PM   #155
Joe Pass
Joe Pass's Avatar
OK...fresh off the Summit website
Camshaft lift is .450 intake / .460 exhaust. Camshaft duration at 050 is 222 degrees intake and exhaust. Lobe centerline is 114 degrees. Normal engine manifold vacuum for the 350/290 HP engine is 10-12 in
I think the vacuum stated is low...this one had about 15-16" on idle
Joe
Old 04-06-2015, 07:30 PM   #156
mattbert56
mattbert56's Avatar
hmm. What'd it run?
Old 04-06-2015, 07:35 PM   #157
mattbert56
mattbert56's Avatar
Well got the grill masked and shot with primer and then layer a bit of color. Just finished hand brushing in the edges of the letters needs a little bit of cleanup on the C and the H mainky. But turned out nice. Finish touch up then some semi gloss clear Coat. And time to install
Old 04-06-2015, 08:16 PM   #158
Joe Pass
Joe Pass's Avatar
hmm. What'd it run?
Around the block just fine...?
Old 04-06-2015, 08:26 PM   #159
mattbert56
mattbert56's Avatar
Hah. Price wise. I'm sure it ran amazing. Is that the cam in your 63?
Old 04-06-2015, 08:30 PM   #160
Joe Pass
Joe Pass's Avatar
OH!, you youngins with that fancy spellin....."Free" dude, its yours if you will use it...and we can dig through the SBC drawer for more gold
Old 04-06-2015, 08:55 PM   #161
mattbert56
mattbert56's Avatar
THANKS MAN!! shoot Alright. Sounds like I will owe you a favor. When's a good time to stop by? Maybe this weekend perhaps?
Old 04-06-2015, 10:42 PM   #162
Joe Pass
Joe Pass's Avatar
Weekend is great...call or text when you are in the area and we'll hook up.
To answer your question on my 62 cam size,
Edelbrock 7102 cam kit-.486in and .510ex with a 303 duration combined with a set of Blueprint heads 64cc-195 intake runners, 2.02in and 1.60 ex valves PN-H8002k
Old 04-07-2015, 01:06 AM   #163
mattbert56
mattbert56's Avatar
You got it man I'll shoot you a call
Old 04-07-2015, 01:46 AM   #164
mattbert56
mattbert56's Avatar
Befor and after photos of the same motor. 292 inline 6. sooooo I put the carb and headers on because I couldn't wait. but layed some color on the engine Tonight. Everything fit together perfectly. Chose Detroit diesel alpine green. Always loved the Detroit motors and how they look. So made mine look like it. Plus chevy orange is what everyone does. I like different. on the flip side, the 4 speed and my steering knuckles are chevy orange anyway
Old 04-16-2015, 04:11 PM   #165
mattbert56
mattbert56's Avatar
Well found an air cleaner for the Carb. Thinking of changing it to an oval one. goes With The Long motor Look. But just to keep things updated. I bought a can of alpine green to finish the engine... that's about all... hoping to get it tied together a bit more this weekenD. Have one solid day to work on her maybe Saturday my goal is may 9th for the annual all American car day show in my town.
Old 04-20-2015, 11:29 PM   #166
mattbert56
mattbert56's Avatar
Shot some color on the oil pan. And found a small hole in the bottom of it. The motor didn't leak at all when I looked at it. Turned out there was 1/2 inch of sludge in the botto.. some spots where so thick it was the consistency of Hard clay. sheesh but welded it right up and it's good as new.. and also made another attempt at tackling the brakes again. Been having a hard time with them due to the fact of stripped Bolts. Lost parts. Springs that cannot be found at any parts store. lord give me patience haha. Ended the night with installing the rear dumb seals. Went so smooth decided to call it a night.
Old 04-21-2015, 01:24 PM   #167
61K10
61K10's Avatar
Matt--what springs are you missing?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-21-2015, 02:00 PM   #168
mattbert56
mattbert56's Avatar
In the picture. The blue one on the top right. The 1/8 rod behind it. The parking brake spanning bar. the the two slotted steel pins that stick threw the rubber boots on the wheel cylinder. And the swinging arm that interacts with the adjuster that I believe is pinned up on the top or the rear brake shoe.. I'm worried they may have been thrown out. :/
Old 04-21-2015, 02:03 PM   #169
mattbert56
mattbert56's Avatar
Oh and the small red spring that's a return for that adjuster arm. That one happen to be new ish from when I ulcer it apart but shouldn't be difficult to figure out a replacement. I found that a 1971 C20 had 90% of the correct springs. And only a few are a tad shorter. This is the closest Iv found for a "complete hardware kit"
Old 04-22-2015, 10:57 AM   #170
b.sharp
b.sharp's Avatar
Sorry didn't get the picture uploaded until now. It needs a lot of TLC but the drivetrain is all original and seems to be in working order. I have a '65 ton that will take the place of this mangled sheet metal. The '65 has 66K original miles on it. Also will give me a spare 292 and 4speed for the K20. Your truck is coming along nice. I hope to get to this project one of these days. I have several on my plate towork on.
b.sharp is offline   Reply With Quote
Old 04-22-2015, 11:52 AM   #171
mattbert56
mattbert56's Avatar
Trucks looking good. Awesome start. Are you planning on keeping the 292 in it?
Old 04-24-2015, 08:58 PM   #172
mattbert56
mattbert56's Avatar
Well today was a parts picking up /ordering day. But got two engine mounts. Big bag of shinny new grade 8 bolts. two weld on D loops. A clutch kit. intake gasket. Oil pan gasket. And put the oil pump on order. It'll be in by 7 tomorw. this weekend tho went up to visit two friends in Sacramento foot hills region and felt the trip was worth it. For one kimbLe (better known as 61k10) is an awesome guy. Very old school And a good ol boy. You can tell. Very generous with some transfer case parts I have been long needing and looking for. But the Thursday trip was great caught some good size fish to.
Back to trucks.. got the motor ready to instal tomorrow if the rain clears any time. Pulled off intake&exhaust. Along with front grill and core support. Pulled the old 292 out with the cracked block. And found my long lost flywheel. so hoping to work outside a bit tomorw but if not. It's full speed ahead on that transfer case. That's thing is getting finishedif it likes it or not. Big thanks to 61 k10 tho. I do t think I would be finishing this case if it wasn't for him.
Old 04-24-2015, 09:48 PM   #173
mattbert56
mattbert56's Avatar
Oops forgot pictures..ok well pictures would t load other than 2. I'll post the rest whenever it loads again. Other than that. Enjoy the 2 that did haha
Old 04-24-2015, 11:06 PM   #174
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Hoping to see that thing in tomorrow. Dang, I'm gonna have to make a trip down there sometime and we can talk trucks. Got tons a family down there. lol And good news is your only a few hours from Clifford Performance....he's got some nice 6 banger parts. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-25-2015, 12:54 PM   #175
akaupp
Truck looks good.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
