Old 04-28-2016, 04:27 PM   #151
burnitg
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
Originally Posted by ryanroo View Post
How goes the struggle? The piping continues to please the eye
Thanks for the compliment, Ryan. I haven't made much progress lately. I have been busy plowing snow (it stops being fun after plowing 2X/day for 3 days), working on my outside project (a shed to store my equipment :-)) and family trips.
I'm working on the hydro boost brake master cylinder now. The brackets supplied in the "kit" left it at a very odd angle and attaching it to the OEM brackets doesn't look good either. It will take some time to get it looking good and functioning correctly. For this spring and summer, I will be concentrating on the shed...
burnitg is offline   Reply With Quote
Old 04-29-2016, 12:55 AM   #152
chosn 1
fabricator of anythng not wood
chosn 1's Avatar
WOW, just came across this thread and gotta say it's like a dejavu, this is alot like the route I wanted to go! Awesome build man!
chosn 1 is offline   Reply With Quote
Old 02-13-2017, 08:36 PM   #153
burnitg
I'm baaacccckkkkk! I finally finished a building to store my equipment and projects; both completed and in the works. It's not a truck; but, I am posting a photo of it anyway. It took me a year to build.
Name:  Screamer's Future Home.jpg
To get back into my project, I decided to get the gear shift lever right. Here it is before I started. It is straight and quite a reach from the driver's seat.
Name:  Shift Lever - before.jpg
Here it is after some heat and force was applied. I welded on a bolt at the top and added the shift knob.
Name:  Shift Lever - after side view.jpg
Rear view:
Name:  Shift Lever - after rear view.jpg
It is now ergonomically correct.
I admit to sitting in the seat and going through the gears making engine noises. I had forgotten how much fun it is for me to work on this truck.
Maybe I'll install the clutch pedal and linkage next so I can practice my double clutching...
Old 02-13-2017, 11:14 PM   #154
nsulacountry
We thought you died!! Like people thought Detroit Drippers died!!
Moving on... Like the custom, ergonomic shifting device...
Nothing wrong (In my mind) with sitting in a no running vehicle, pretending to drive and make engine noises. Really, it's OK!
I understand the pain, built a 70x60x16 this past year. Time and money!!
Looking good. Get back on the DripTroit!!
CT
nsulacountry is offline   Reply With Quote
Old 02-14-2017, 09:11 PM   #155
burnitg
Brake master cylinder mounting problem - solved.
Before I started working on my shed project, I purchased a hydroboost "kit" for the truck. The bracket that they supplied in the "kit" left me disgusted. As an engineer, I would be ashamed of the way it looked and fit. Here's a photo of it mocked in place.
Name:  Master Brake Cylinder - kit mounting bracket.jpg
Needless to say, I was looking for a better way. I found a mounting plate on this forum made by CaptainFab. In my opinion, it is the perfect solution. Here's a photo of it mocked in place.
Name:  Master Brake Cylinder - CaptainFab mounting plate.jpg
While I was working on the master cylinder, I also worked on the clutch. I needed a switch on the clutch to disengage the Jacobs brakes and the cruise control. I made this little bracket and installed a double switch in it.
Name:  Clutch Switch.jpg
I also noticed that the hole in the clutch arm (the one at the end of the clutch pedal shaft) had been wallowed out after many thousands of strokes.
Name:  Clutch Arm - before.jpg
A little welding, grinding and drilling later. Here's what it looks like.
Name:  Clutch Arm - after.jpg
I used 70ksi rod so it should last a long time. Also, I plan to float the gears so the clutch won't get a lot of use.
Old 02-14-2017, 10:25 PM   #156
OutlawDrifter
Glad to see you posting again. I'm in the process of putting up a new shop also, which has halted all of my automotive therapy!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-15-2017, 10:51 AM   #157
Lemield
Lemield's Avatar
Beautiful work as usual! Glad to see you back!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 02-15-2017, 08:05 PM   #158
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice building and more great work on the truck! I can't wait until I can build a big building to fill up!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-16-2017, 02:27 PM   #159
ryanroo
ryanroo's Avatar
Awesome! i shift mine all the time. engine noises included. the new building is fantastic too!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-31-2017, 06:23 PM   #160
burnitg
Inner fenders - done!
I decided to tackle the inner fenders since I need them in place to design and fabricate the battery tray and air filter brackets.
Both had to be modified since I have a 2" body lift and the turbo to intercooler and intercooler to blower piping interfered with them. I never imagined that it would take me so long to finish them.
Here's the driver's side inner fender with the new metal tacked into place. I didn't need to modify it much.
Name:  Drivers side inner fender tacked.jpg
Here's the driver's sided inner fender installed.
Name:  Drivers side inner fender finished.jpg
Here's the passenger side inner fender with the new metal tacked into place, I had to custom build the lower half of this one. The turbocharger to intercooler piping interfered with it in a major way.
Name:  Passenger side inner fender tacked.jpg
Here's the passenger's side welded up.
Name:  Passenger side inner fender welded up.jpg
Here's the passenger's side completed.
Name:  Passenger side inner fender finished.jpg
Now I'm on to the battery tray.
Old 04-05-2017, 04:15 PM   #161
Dieselwrencher
Nice work. Those look great!
Ryan
Old 06-12-2017, 06:27 PM   #162
burnitg
Another DIY project...
Space is getting tight under the hood of the old GMC. As always, I work down in size starting with the big things and working down to the small ones. The next two big things are the air filter and the batteries.
I decided that I would use two starting batteries. Detroit Diesels do not have any glow plugs or intake heaters and they MUST use single viscosity SAE 40 oil, so I will need some serious battery power to start on cold days. I have installed a block heater so I can get it going from home on cold days; but, that won't help if it has been sitting all day in a parking lot on a cold day.
I spent several hours on the air filter manufacturers' websites looking for an OEM filter that would meet my air flow and space needs. Everything that I found was too big in at least one dimension. So, I decided to make my own air filter housing. Because I was able to fit it in a relatively small space, I could use the stock battery tray and a stock auxiliary battery tray to mount the two batteries.
I found a rectangular K&N filter that would flow enough air and patterned the housing off of it. It is the same filter used in my '99 F-250 Powerstroke so I know it will flow enough air and I love parts interchangeability.
Here's the cardboard template for the base:
Name:  Air filter housing cardboard template.jpg
Here are the sides in steel:
Name:  Air filter housing sides.jpg
Here's the top view with the filter:
Name:  Air filter housing with filter.jpg
Here's the auxiliary battery tray modified and installed:
Name:  Auxiliary battery tray.jpg
I'll post more photos in the following post.
Old 06-12-2017, 06:34 PM   #163
burnitg
Another DIY Project - Part 2
Got anger issues (I don't, I'm retired )? Here's a way to get them out - pounding the crap out of a piece of sheet metal. I decided to make the top of my air filter housing curved so I got out the hammer and sand bag and started pounding on the top. Here's what it looked like about half way through:
Name:  Air filter housing shaping the cover.jpg
Here's what it looked like when I finished:
Name:  Air filter housing cover welded.jpg
Here's the completed filter housing on the bench:
Name:  Air filter housing complete on the bench.jpg
Here it is installed in the truck:
Name:  Air filter housing complete installed.jpg
I'll install some flexible ducting between the inlet and core support so I will have a cold air intake.
Old 06-12-2017, 08:14 PM   #164
Dieselwrencher
Kudos to you! That is a very nice looking air filter box and top! Did you use a regular type tube sand bag?
Ryan
Old 06-12-2017, 08:25 PM   #165
OutlawDrifter
Fine job sir!
1991 Z/28, 6.0L/T56
Old 06-12-2017, 08:37 PM   #166
burnitg
Thanks for the complement. I used a regular sandbag and teardrop hammer. You can see the bag in the lower right of the photo. I rolled the dents out with an English wheel.
Burnett
Old 06-12-2017, 08:49 PM   #167
Dieselwrencher
Burnett
Very nice! Isn't it amazing how many hours go into doing all these fabricated pieces that a lot of people will never know. I need to get some different shaped hammers and start messing up some sheet metal. An english wheel would be nice too.
Ryan
Old 06-13-2017, 10:22 AM   #168
burnitg
I agree that making parts takes a lot of time. I'm glad it's my hobby and not my job. I'd starve to death trying to make a living this way...
Old 06-14-2017, 09:14 PM   #169
Average Joe
Average Joe's Avatar
That air box is amazing. Quality work!!!!!!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-20-2017, 08:12 PM   #170
burnitg
Cruise Control Servo - mounted!
Another under hood item to scratch off of the list (it's still a long list...).
When I finish this truck, I plan for it to become my cruising vehicle. CO is a big state and there are lots of things here that I haven't seen. I decided that cruise control would greatly enhance my driving experience while I am driving in the flat half of the state.
I started by installing the throttle cable & stop cable and then the business end of the cable from the cruise control servo. It is a Dakota Digital CRS-2000. Unfortunately there is no way to shorten the CC cable, so my mounting options were limited.
I made a bracket to organize the cables and welded it to the valve cover. That set the path that my CC cable would have to take. Here's a view of the cables at the governor end:
Name:  Throttle cables front view.jpg
Here's a side view:
Name:  Throttle cables drivers side view.jpg
I then attached the servo to the driver's side fender well:
Name:  CC Servo front view.jpg
Now that the servo is installed, I can start looking at the coolant recovery and windshield washer reservoirs.
Old 07-08-2017, 06:00 PM   #171
burnitg
It's enough to make a grown man cry!
I was working on mounting the electric vacuum pump today. I had picked a location very close to the driver's side hood hinge so I decided to mount the hinge to see if it would interfere. I mounted the hinge and then looked across to the passenger side and my new air filter housing - my heart sank. With the hinge down, it looked like the end of the hinge might interfere with the housing. A few minutes later, I had installed the passenger side hinge and confirmed that it does interfere. Ouch! I have often been in the "one step forward, two steps back" mode on this project but this is a new low. I have >40 hours into the air filter housing - it was done...
Here's a photo from the passenger's side:
Name:  Hinge-air filter interference side view.jpg
One from the front:
Name:  Hinge-air filter interference front view.jpg
One from the driver's side:
Name:  Hinge-air filter interference drivers side view.jpg
I had mocked up the hood to make sure that the filter cleared underneath; but, I did not think about the hinges. They fold down much farther to the front than I thought. Back to the drawing board...
Old 07-11-2017, 04:09 PM   #172
Dieselwrencher
This might be an expensive solution, but are any of the billet hinges shorter? GSI I believe makes them and they can be gotten black anodized to not stand out so much if you wanted. Maybe they would fit and you can retain the nice air box?
Ryan
Old 07-11-2017, 04:19 PM   #173
AnotherWs6
AnotherWs6's Avatar
This thing is awesome.
What kind of power figures does that motor put out?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 07-11-2017, 04:24 PM   #174
burnitg
Thanks. New hinges are one of the options that I am considering. I think that I will leave it alone for a couple weeks. After some time has passed, I will be able to evaluate the options more objectively.
Old 07-11-2017, 04:31 PM   #175
burnitg
175 Hp @ 2500 RPM
420 ft-lbs @ 1800 RPM.
I'm going to keep it stock for now.
