Old 09-18-2016, 11:41 PM   #151
Rod Run
Rod Run's Avatar
Re: Project TLOW - 1971 stepside
And here are a couple before and after pics of my garage, with the work I did on it this week
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 09-19-2016, 12:38 AM   #152
swamp rat
swamp rat's Avatar
Someday i might get brave and try a gutter shave, i assume you only remoce a small section at a time and chase it with a few spots? And that Bird would be really hard for me to pass up as well.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-19-2016, 09:21 AM   #153
Rod Run
Rod Run's Avatar
After I had the body blasted and saw how solid that area was (especially compared to the rest of the cab), I had to shave them
As long as the area is solid, it's a lot easier than you would think. If the metal is corroded or thinned at all (as it was on one of my other cars), it becomes a much bigger headache
The new project is actually a 1969 Camaro. I picked it up so my other '69 could have a playmate. My better half said we can have "His and Hers" Camaros
Old 09-19-2016, 03:27 PM   #154
swamp rat
swamp rat's Avatar
Sorry, I saw the 3 lovers by the rear tire and made an assumption but I'd still want it. 😊
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-20-2016, 01:43 AM   #155
Rod Run
Rod Run's Avatar
Ha! I want it too. Hopefully I can get it home within the next few weeks. I'm also trying to get the bodywork finished on my C10 cab too, so I can get it back home before the snow flies
Old 09-20-2016, 02:44 AM   #156
jim-bob
..I see you made holes in that cross member for the tail pipes to come thru but I couldn't find your post showing how you did it..will you give me the post number showing this?
Also what size are those tires and your back space..Thanks Rod
jim-bob is offline   Reply With Quote
Old 09-20-2016, 12:06 PM   #157
Rod Run
Rod Run's Avatar
For the exhaust I went with 2 1/2" pipe, so what I did was use a 3" hole saw to cut the hole through the cross member and then used some 3" pipe and used it as a sleeve to finish it off. It is totally ok if the saw cuts a little oversize, because you will be filling that when you weld the sleeve in anyway.
The minor problem that you will run into, is that there is no "meat" to drill into in that area of the cross member. What I did, was just tack welded a small piece of scrap metal in in position that I wanted to use as the center. I hope I didn't over confuse that for you?
The wheels are Cragar Soft 8
17x8 front & 17x9 rea, with 4.5 " & 5" backspacing. I am also using CPP's modular spindles, so that's moving my spindle in a little more than a stock application
Old 09-21-2016, 12:45 PM   #158
jim-bob
ROD..Great great info..thank you so much!!
Old 09-21-2016, 08:07 PM   #159
Rod Run
Rod Run's Avatar
Just trying to help out anyway I can.
I know a lot of people look at tires and wheels, but have a hard time getting 100% of the info they were looking for
Old 12-29-2016, 02:21 PM   #160
Rod Run
Rod Run's Avatar
It's been a long, long time since I've updated this thread. I started looking at some older pictures and here are a few more from my garage cleanout weekend, before I post up some updates on Project TLOW
Old 12-29-2016, 02:35 PM   #161
Rod Run
Rod Run's Avatar
Since I last updated, there has been a lot of un-glorious work done on my truck. Mainly it's been ordering hundreds and hundreds of dollars in parts, finishing up the fabrication of my exhaust, replacing cab corners, rockers and lower a-pillars. I had a friend tack all them in before I finish welded them). I also finished the removal of my front drip edge (way to much work), amongst a bunch of other little things that aren't worth mentioning.
I'll post up some pictures over the coming days. The forum won't let me post them up from my phone (the regular attachment icon doesn't appear), so it takes me a little longer.
I'm really hoping to have the truck on the road before summer, so lots of progress and pictures should be coming over the next few months
Old 01-02-2017, 01:56 PM   #162
Rod Run
Rod Run's Avatar
Here are some of the parts I've been collecting for Project TLOW over the past few months
Old 01-02-2017, 01:59 PM   #163
Rod Run
Rod Run's Avatar
Here's a couple more goodies too.
I decided to switch out to a 69 grill so I ordered this one and after almost a two month wait on backorder, I finally received it last week. As you can see by the pictures though, it didn't come in exactly as it was supposed to.
I made a call to the seller and they were more than great with taking care of the situation. I should hopefully have a new one in by the end of this week
Old 01-02-2017, 02:01 PM   #164
Rod Run
Rod Run's Avatar
A couple pics of the front half of my exhaust after I finished fabricating it up and coating it. The pipe is made up of 3 cut pieces that I welded together and ground smooth
Old 01-02-2017, 02:07 PM   #165
Rod Run
Rod Run's Avatar
It took me a full Saturday to cut and weld the entire front edge (I welded it solid but have no pics of that), with only leaving the corners above the a-pillar to finish the next day.
Problem was that when I went back at it the next day, I didn't like how the transition was going to end up looking coming around the corner so I had to cut it completely apart again to get rid of that small step you can still see
Old 01-02-2017, 02:10 PM   #166
Rod Run
Rod Run's Avatar
What I ended up doing, was that I took a 3/16" cutoff wheel and split the whole edge right along the seam. The space that created, gave me a perfectly spaced gap, to be able to but the two pieces together and weld them up with a smooth transition.
After doing this, I really wish I had access to a TIG welder and had the knowledge of how to use one
I really wanted to go with flush mount glass after doing all of this work, but just for the rear window alone, it was about $240.00 (which I though was a very fair price), but to ship it to the east coast it was going to be another $234.00 and there is no way I was going to spend that much on shipping.
Old 01-02-2017, 02:14 PM   #167
Rod Run
Rod Run's Avatar
Doors have been stripped. Although they are VERY solid, the bondo was incredibly thick. Not sure how this is going to go yet.
The firewall is finally in a guide coat for a final block and sand before primer and paint
Old 01-02-2017, 02:17 PM   #168
Rod Run
Rod Run's Avatar
Had a friend fit the cab corners, rockers and lower a pillars before I finish welded them myself. I just don't trust myself on the fitting part of the job. He is also the one that will be doing all the final bodywork and paint for me.
Old 01-02-2017, 02:19 PM   #169
Rod Run
Rod Run's Avatar
Hopefully this gives all you guys a little bit to look at and chat it up about, before the next time I get around to updating this thread
Old 01-04-2017, 11:16 AM   #170
knomadd
knomadd's Avatar
Nice work! I just recently finished my firewall and seeing your pics reminded me of all the work I just did. Keep it up! It looks like the delivery guy was having a really bad day to have beat up your grille like that.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-04-2017, 12:15 PM   #171
Rod Run
Rod Run's Avatar
Making and welding in that filler strip for the top was tedious work.
Here is the radiator filler panel that came in the big brown truck today
Old 01-04-2017, 02:36 PM   #172
rob32472
Where did the radiator filler come from?
rob32472 is offline   Reply With Quote
Old 01-04-2017, 10:24 PM   #173
Rod Run
Rod Run's Avatar
Vannetta Fabrication. He makes some awesome stuff for our trucks. Over a dozen different parts
They actually just came out with a minimalist pro-touring type of spoiler for our trucks earlier today, if you're in to that type of thing
Old 01-04-2017, 11:54 PM   #174
rob32472
Do you have a web site or contact information?
Old 01-05-2017, 12:15 AM   #175
Rod Run
Rod Run's Avatar
I don't know how to do links, but the best way to get him, is to hit him up on Facebook with a PM. He's pretty active on there and he's on Instagram to a lesser degree.
He has 4 or five different designs just for the filler panel alone
I hope this helps you out
