01-16-2017, 01:17 AM | #151 |
Re: 1949 Chevy 3100 Build Thread
Got the accessory drive situation figured out. All this discussion and contemplating when the solution is simple. Just move the radiator forward duh!!! My aluminum radiator mounts to the stock core support I grinded the aluminum mounting tabs off and will attempt to re weld them back to the radiator. I have a tig welder but have never welded aluminum. Got some alimunum scrap and filler rod and will practice before I make my attempt. That will give me a couple extra inches required to run the truck accessories. Got the mini Sanden bracket from ict billet thanks for the video Curt from TN! The truck alternator and power steering accessories fit without cutting into the frame. I'm pretty happy with how everything is looking so far and will be finishing the frame welding soon. My goal is to have frame and some other parts to powder coat by the end of the month. Mounted the wheels to check stance everything looks good. Drop down battery is going to be tight between the tank and roll pan. I will need some bed components before I mount since I want to tuck it up as high as possible.
01-16-2017, 03:13 PM | #152 |
Formerly- 1972SuperCheyenne
Very very nice!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-16-2017, 06:43 PM | #153 |
01-16-2017, 06:58 PM | #154 |
I just re-read this whole thread.
Very nice work! I'm really impressed with the pace of this build. It is quite a milestone getting it back on wheels.
53 Chevy Pickup |
01-23-2017, 06:55 PM | #155 |
Congratulations on your restoration, it's getting really good.
I have a chevy 3100 but I have difficult to construct the radiator support, in my country don't have parts to substitute, regards this I need construct. I's possible this forum post the correct dimensions, height, width, anything to help me construct this parts. Thanks so much Sabadini |
01-24-2017, 07:25 AM | #156 |
Post Whore
Nice to see it on all 4s..looking good
02-04-2017, 10:31 PM | #157 |
Everything is torn apart again in preparation for powder coat. Frame is boxed and flipped over for final welding. Ran out of welding wire on a Saturday so I spent a few hours grinding down the welds on the boxing plates instead. I'm pumped that I'm almost done with the welding and grinding. Can't wait to deal with newly powder coated frame and start the final assembly of the rolling chassis. Been 1.5 years of rust, dirt, welding, grinding so I'm def ready to have a clean garage again, free of the damn grinding dust!
02-13-2017, 10:47 PM | #158 |
Frame and a ton of other stuff is off to powder coat. I've got my garage back for a while. Cab is back on the rolling cart. Just double checking everything such as wiper motor, a/c condenser, just making sure everything fits in harmony before I send cab off for paint. Not quite sure how I will juggle everything. I'm thinking of getting some parts painted now and others after installed. For example, the cab needs to get painted before it's installed on frame for the final time but the hood needs to be installed before paint I think. I'm afraid I will damage the paint on the front end sheet metal trying to line everything up. Anyway there isn't much to see since I mock things up then put them back in boxes. Waiting on my harness from PSI then I can find a place for everything. Here is a pic of how I mounted the wire harness to firewall. I think the PCM and Dakota digital brain will bolt to the top of my brake booster bracket. The PCM fuse block should fit on firewall with fuses accessible.
02-13-2017, 10:57 PM | #159 |
The frame looks great. Yes think of how much more fun it is to assemble clean painted parts....I feel the same about my project.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-22-2017, 01:29 AM | #160 |
Got the frame and a bunch of other stuff back from powder coat today. I also got a box from psi which was the last thing I needed to finalize cab mock up. PCM fit nicely on top of my brake booster bracket and fuses on firewall. Since everything fits harmoniously the cab is basically fully mocked up and ready for bodywork. I'm going to farm out the bodywork and paint. I have someone coming by on Sunday to give me an estimate. Next plan of action is to seam seal the cab and spray rhino liner under the cab and on the interior floor. Then I will have taken the cab as far as I can before I need to hand it off to the body shop.
02-22-2017, 01:31 AM | #161 |
02-22-2017, 01:47 AM | #162 |
Your truck is looking great. Huge congrats!
What wheels and size are those? I'm having to make wheel & tire decisions now and I'm struggling a bit.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-22-2017, 10:49 AM | #163 |
Frame and parts look great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-22-2017, 12:53 PM | #164 | |
I'm was torn betweeen billet and smoothies. I almost bought wheel vintiques which are also an American made local product. I recommend you take a look at hotrodsbyboyd.com Chris Coddington makes all his wheels here in the USA and they are really nice. You can get a set of wheels for 2K (cast series) and up. But for me knowing it's a local made product i can pick up feels better than mail order from a big box store. |
02-22-2017, 01:47 PM | #165 |
Looking good.... final assembly is the best feeling !!!!
My Build: 57 Chevy Pro-Street |
02-23-2017, 12:26 PM | #166 |
02-23-2017, 12:40 PM | #167 |
The frame looks great. How fun is it bolting up freshly coated parts? I look forward to the final assembly process.
Thanks Marc
02-23-2017, 09:36 PM | #168 |
A320 Pilot/USAF Retired
Slick!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-23-2017, 10:15 PM | #169 |
It all looks SO good.
Do you plan to have it done for the Brothers Show in the summer? I hope (fingers crossed) mine will be there.
02-23-2017, 10:19 PM | #170 | |
I like everything I see in your build but I am trying to hold the line on my tendency to spend more than I should (too late I suppose, lol).
02-25-2017, 03:03 PM | #171 |
Thanks for the encouragement guys. There is no way this truck will be done this summer. More like September or October. It depends on how long paint will take so it might be sooner but probably late fall. I ordered my bed from mar-k should arrive in 2 weeks or so. In the meantime it's chassis assembly time!!!
02-25-2017, 03:08 PM | #172 |
Post Whore
That gloss black frame is slick...powder looks like its a inch deep
02-28-2017, 12:02 AM | #173 | |
It's nice to be wrenching again. Rear end has been installed. Motion gear 370 posi third member is in. Went with moser 31 spline axles which will be installed tomorrow. Going to order my driveshaft when I put weight on the rear wheels so I can properly measure. But looks somewhere in he neighborhood of 54". Think I will go with inland empire driveline 3" aluminum up to 500hp. I want to stay local whenever possible. As for bodywork and paint I'm going to have the pros do it. But it's gonna be expensive! Had a guy come by and look my stuff over on Sunday. Very good body shop does some awesome paint jobs. As of now I'm leaning towards precision red. |
02-28-2017, 12:43 AM | #174 | |
02-28-2017, 12:50 AM | #175 |
love the red, looks like a cinnabar I had on a bmw years ago. hell I love anything red.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
