Old 01-28-2019, 03:08 PM   #151
whitels1
whitels1's Avatar
Re: 79 K20 Custom Deluxe - Goldy LS1
Originally Posted by Greenlee View Post
Looking good! Awesome videos!
You mentioned possibly capping off the vent line that goes to the charcoal canister. For what it’s worth, I did that and had an issue with the truck dying occasionally. It would start right back up. I think it was some kind of vapor lock issue. After I hooked up the vent line it stopped happening. I’m running the stock TBI. Just a word of warning on that. I’m still not 100% sure if that’s what the problem was.
Thanks! I plan on running a vented gas cap. I haven't had issues with the K10, but I'll have to keep it in mind.
Originally Posted by daddyjeep View Post
Why would you willingly put the fuel filler on the wrong side? A couple of my vehicles have it over there and it is a pain. The majority of vehicles on the road have them on the drivers' side. The auto makers really should get together and standardize that.
For me it didn't matter what side it was on, because I'll have to modify the bed / fill anyways. Mostly it was how it clocked the fuel pump module line output.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-29-2019, 01:23 PM   #152
daddyjeep
daddyjeep's Avatar
Maybe it is just a small town problem for me. I live in a town with two gas stations and there is often a line. It really screws things up when your filler is on the "wrong" side.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-30-2019, 04:04 AM   #153
whitels1
whitels1's Avatar
Copy that! It's never really been an issue so I didn't think much about it.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-08-2019, 02:24 PM   #154
whitels1
whitels1's Avatar
Brake line time on Goldy! I'm really digging this brake line kit from S.U.R.&.R it made it easy to do the brake lines, and had all the fittings necessary. I went a bit further by going with an adapter at the front port of the master which reduced the 1/4" 9/16 -18 to 3/16" 3/8 -24. It probably would have sealed without the reducer but I got one anyways. I'm going to run the same one at the back of the proportion valve.
Link to kit: https://www.summitracing.com/parts/urr-br-ez316
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-11-2019, 01:48 PM   #155
daddyjeep
daddyjeep's Avatar
Is the brake line that Ni Cop stuff? I have heard that it is really nice to work with.
04 1500 crew cab
Old 02-13-2019, 09:02 AM   #156
Greenlee
Greenlee's Avatar
Nice job on the brake lines! That flexible line looks like the way to go if I ever have to do something like this.
Greenlee is offline   Reply With Quote
Old 02-15-2019, 12:51 PM   #157
whitels1
whitels1's Avatar
It nice, if you make a bend the wrong way, just bend it back. The line in the kit was thick and it would be hard to kink!
Thanks brother! I probably could have used most of the old stuff, since it looked ok, but figured with the age I might as well.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-17-2019, 01:52 PM   #158
COS399
COS399's Avatar
You made it look easy to work with. I like the new Live chat format and my only comment is that you get too far from your microphone at times. keep up the good work.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-18-2019, 05:03 PM   #159
whitels1
whitels1's Avatar
Thank you sir, and thanks for watching. After the last one it bugged me how quiet I was, I will correct it!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-05-2019, 12:34 PM   #160
whitels1
whitels1's Avatar
Well, I suppose it's time for an update! I took a little break from the truck, and then got back on it hard, because the weather was nice, and I didn't want to wait till it was 110 outside. The goal was to get it running and driving and then worry about cosmetic stuff. So I pushed hard on it, finished the brake / fuel lines, interior, engine wiring etc. Drove around for a bit and then installed vintage air. She was a bit sluggish with TH400 and stock converter so I decided to throw a Hughes 2500 in there and wow, then I got it tuned and she is woke for sure. Here are a few videos of the progress.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-14-2019, 11:16 AM   #161
Greenlee
Greenlee's Avatar
Goldy turned out great! The videos are awesome as usual. I’m glad you made it a tow rig. It looks too clean for a rock crawler! Do you still have the white flatbed for towing?
I’m interested in how you like the LS with the TH400. I have the same transmission. Maybe some day I’ll do an LS swap!
Old 07-15-2019, 01:28 PM   #162
whitels1
whitels1's Avatar
Thanks brother! I do have the flat bed, but it's just sitting around. I don't mind the TH400, I can roll 70-75 with no problems. In fact I've never had overdrive with one of my swaps.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-17-2019, 12:03 PM   #163
drmatera
drmatera's Avatar
sub'd. I've been watching your youtube videos now for a couple of months. Just came across this post.
drmatera is offline   Reply With Quote
Old 07-18-2019, 02:28 PM   #164
whitels1
whitels1's Avatar
Awesome, thanks brother!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-18-2019, 02:31 PM   #165
whitels1
whitels1's Avatar
Can't believe the paint actually buffed out!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-28-2019, 11:51 PM   #166
COS399
COS399's Avatar
Great work Dave! Thanks for another great video and sharing it with us.
Old 07-30-2019, 11:33 PM   #167
Zoomad75
K5Camper
Zoomad75's Avatar
I didn't realize you were on here Dave. Good to see it towed the jeep well! Might look cooler if it was towing the K10 Crawler, but I'll give you a pass. Wheeling is wheeling. It's just cooler in a squarebody!
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-02-2019, 12:06 PM   #168
whitels1
whitels1's Avatar
Thanks brother!
I'm everywhere Jeep wheels better!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-02-2019, 12:09 PM   #169
whitels1
whitels1's Avatar
I got Goldy, wired up with a brake control, and charge line, borrowed my buddies trailer and hit the road. I was very happy with the way the K20 handled towing the Jeep.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-02-2019, 01:14 PM   #170
drmatera
drmatera's Avatar
whitels1, Did you keep the original TH400 when swapping to the LS engine? If the 305 in my '81 K10 is no good I'm thinking of dropping a 5.3 in there but don't want to disturb the transmission/transfer case and driveshafts.
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
Old 08-02-2019, 03:54 PM   #171
whitels1
whitels1's Avatar
It's not the original, but you should be able to drop in an LS without moving any of that stuff.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-03-2019, 11:39 AM   #172
Greenlee
Greenlee's Avatar
www.youtube.com/watch?v=ezN0Nae7B9Y
Sweet video! Looks like your boy had a good time! Not many people have a tow vehicle that’s 40 years older than their rock crawler. You still got the k10 crawler?
Old 08-26-2019, 04:29 PM   #173
whitels1
whitels1's Avatar
Thanks Greenlee, the boy loves the old truck, and crawling around in the Jeep, I wish we could do it more! I love to do things backwards, if you didn't know I still have the K10, I told the boy it's his and when I feel like he is ready we will start building on it, we have lots to do so he can learn along the way. I gotta teach him right so he can work on my stuff when I'm old and tired!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-26-2019, 05:27 PM   #174
whitels1
whitels1's Avatar
Making some progress on sound deadening, used a product called Noico, decent price and worked well. I talk about it a bunch in the video, but they recommend to use Noico closed cell foam over top, and wow is it making a difference and keeping things cooler in the cab.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-27-2019, 01:48 PM   #175
drmatera
drmatera's Avatar
I watched the sound deadening videos and will be going that route for sure.. Thanks for all the good content.
