Old 01-05-2017, 10:59 AM   #151
Rednwhitec20
Rednwhitec20's Avatar
Re: 4x4 1971 K20 build
Things have been going slow lately but they are starting to pick up again. My 78-79 dana 60 is on its way. I'm looking into a transfer case. The wiring has been started. Steering column and gear box will be sent off to be restored.
1971 C20 Daily, Built 350/700R4
1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s
K20 Build
Rednwhitec20 is offline   Reply With Quote
Old 02-23-2017, 08:51 PM   #152
Rednwhitec20
As my truck is patiently waiting for wires I have been thinking about my motor mount setup. As it would be a nice easy setup for a stock engine, mine won't be. I have decided to redo the whole crossmember as I plan to be putting lots of ponies to the ground later on in life. My Dana 60 will be rebuilt when the truck is on the road and I collect money, but for now it will wait. My steering parts are back and look wonderful. He is about ready to start the wiring. In the meantime my 71 dd had a hg blow so we hooked it up with some arp head bolts and it's rockin again. Stay tuned as hopefully the progress will pick up again.
K20 Build
Old 02-25-2017, 03:23 AM   #153
Rednwhitec20
my DD
K20 Build
Old 02-25-2017, 11:22 PM   #154
Wide Open
Originally Posted by Rednwhitec20 View Post
my DD
Looks like a tough life 😂
Wide Open is offline   Reply With Quote
Old 02-27-2017, 12:30 PM   #155
Rednwhitec20
For my pocket it is
K20 Build
Old 03-25-2017, 09:09 PM   #156
Rednwhitec20
Picked up a straight bedside with a small line of rust in the wheel well, and a real nice gate. Brakes are mostly plumbed, engine crossmember should be finished this weekend or damn near done. Then I need gate hardware and an NP261XHD or NP261HD for a transfer case.
K20 Build
Old 03-26-2017, 12:23 PM   #157
Wide Open
That is a nice tailgate. Good find.
Old 03-27-2017, 01:42 AM   #158
Rednwhitec20
It needs a little attention on the bottom but it is really nice. Only small dings on the inside. The guy had about 30 67-72 trucks.
K20 Build
Old 04-03-2017, 09:03 AM   #159
Rednwhitec20
Fitting the Crossmember
K20 Build
Old 04-05-2017, 04:39 PM   #160
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice gate and bed side. The cross member is looking nice too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-05-2017, 10:16 PM   #161
Rednwhitec20
Thank you.
Here's the crossmember. As of now it weighs 42 lbs. 1/4" and fully boxed. This shall keep my dirtymax calm no matter what.
K20 Build
Old 04-06-2017, 03:48 PM   #162
Wide Open
Lol. That should do the trick.
Old 04-07-2017, 12:07 PM   #163
Rednwhitec20
I'd hope. Transfer case is finished
K20 Build
Old 04-10-2017, 01:12 AM   #164
Rednwhitec20
Bought some welds wrapped in 37s
K20 Build
Old 04-10-2017, 08:18 AM   #165
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
No pics?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-10-2017, 08:22 AM   #166
Rednwhitec20
Originally Posted by Ol Blue K20 View Post
No pics?
They are getting shipped out today. Got a great deal. They need cleaned up.
K20 Build
Old 04-10-2017, 08:44 AM   #167
Ol Blue K20
Nice, they look pretty good.
Dale
Old 05-04-2017, 08:36 AM   #168
Rednwhitec20
Slow progress
K20 Build
Old 07-03-2017, 09:34 PM   #169
Rednwhitec20
I was really hoping for it to be done by now but it will all be worth it. Got a heavy duty crossmember put in. Made all of 1/4" thick steel. I also bought a 14 bolt 11.5" rear out of an 8.1 and it is now installed, just needs painted. Now I'll have a huge u-joint with disc brakes. If anyone needs rebuilt 71 k20 axles I got em! All of the intercooler plumbing is on its way. The rear drive shaft should be finished soon as well. I also bought a fun daily since I have a 60 mile round trip for work each day.
K20 Build
Old 07-12-2018, 03:32 PM   #170
Rednwhitec20
Well the duramax finally runs now after new injectors. It now has an 8" lift as well. I bought a new trans cooler and i now need to order crossover steering.
K20 Build
Old 07-14-2018, 12:13 AM   #171
cornerstone
cornerstone's Avatar
That is one bad to the bone project man. A 1971 with a D-max and an LS1 daily driver.....
cornerstone is offline   Reply With Quote
Old 07-16-2018, 05:08 PM   #172
Rednwhitec20
Thanks! The LS is amazing, fun and reliable. It also averages around 21MPG.
K20 Build
Old 07-19-2018, 07:14 PM   #173
Dieselwrencher
Awesome on all accounts! Too bad you had to replace the injectors but at least it is running and you know they are new now.
Ryan
Old 03-03-2022, 04:06 PM   #174
rickcdewitt
rickcdewitt's Avatar
I know its an old thread but hopefully you'll still get notifications. What radiator did you use? Motor mounts?intercooler?
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 03-04-2022, 08:13 PM   #175
Rednwhitec20
A champion radiator, custom front crossmember, and a universal mishimoto intercooler. If I were to redo it all over again, I’d either go a custom cooling package or run the duramax frame to allow the duramax cooling package to fit. The duramax cooling package is too tall for a stock frame truck as there is not enough room between the frame and hood and/or hood latch.
4x4 build, 6 inch lift, duramax conversion, duramax swap, k20
