10-11-2017, 11:35 PM | #151 |
Re: 1965 C10 ... Project Name: Just Learnin'
Let me preface these pictures by saying these bolts were all started by hand!! (I'm not a retard) I could turn them in with not issues, but about three threads in and they would lock solid. Then due to some poor hardware the bolt heads would strip out or the bolt would break..
First broken bolt All good enough sticking out to solve the problem! SECOND ONE... NOW IM PISSED! SO CUT EVERYTHING APART... CUT OFF ALL HIS HARDWARE AND WELD ON NEW GRADE 8 STUFF!!!! and thankfully I had a good welding day. |
10-11-2017, 11:42 PM | #152 |
10-11-2017, 11:46 PM | #153 |
10-11-2017, 11:48 PM | #154 |
10-11-2017, 11:54 PM | #155 |
10-14-2017, 11:29 PM | #156 |
ok so i looked at the truck the other day and the girlfriend was right this paint sucks!! its not ratty and sun beaten enough to have a really nice patina and its too beat up to polish and look nice. since a paint job is not anywhere in the near future when it comes to the budget I was trying to figure out what I should do.....
10-14-2017, 11:30 PM | #157 |
10-14-2017, 11:32 PM | #158 |
10-25-2017, 11:11 PM | #159 |
had a little time to finish up the other side of the paint last weekend while getting some red bull straight rhythm in!!
so finally the truck was able to head back up ad down the road. FIRST THINGS FIRST... TO THE DIRTBIKE TRACK! ...well lets be honest.... yankee had to check it out first when I got it home |
10-25-2017, 11:29 PM | #160 |
Ok, now if anyone is still paying attention I have a couple questions to throw out to the crowd and see if anyone can help me out here...
1. The Classic Sound (or whatever its called) radio I installed is doing some funky stuff. When the ignition is in the on position, the radio works great, all six speakers play and the radio has good reception. BUT when i actually turn the truck on, then the radio is very choppy... This has confused me greatly and I've checked all grounds and everything I have in my limited knowledge of car audio and can't figure it out. 2. Now the second one is an air ride question... I have noticed in order to level the truck out I'm running about 30psi in the back and 70 psi in the front..... If I run the same pressure front and rear the truck has a nasty rake! I may be a child of the 90s but this chevy isn't.. no rake wanted here. So I mounted the bags in the stock location of the rear springs but I still feel like it should be able to sit lower with the frame notch... ANY ADVICE?!?! |
10-27-2017, 07:51 PM | #161 |
My stereo does the same thing. I thought it was the unit, so I got a new one and it still did it. I hooked up an external power source and it still did it, the only thing thing that has helped is to unplug the antena. I have a HEI and I think it is something to do with leakage/bleed from the coil. Wierd.
10-27-2017, 09:13 PM | #162 | |
This is what I used https://www.amazon.com/BOSS-Audio-B1.../dp/B000FKP7MG
10-28-2017, 08:05 PM | #163 | |
Posted via Mobile Device |
10-30-2017, 10:41 AM | #164 | |
10-30-2017, 01:43 PM | #165 | |
10-30-2017, 03:57 PM | #166 |
Pay attention to drive shaft clearance and pinion angle.
10-30-2017, 06:17 PM | #167 | |
http://www.azproperformance.com/Dead...63-72-C10.html |
10-31-2017, 12:59 AM | #168 |
10-31-2017, 01:00 AM | #169 | |
