Old 06-08-2020, 03:44 PM   #151
jjzepplin
jjzepplin's Avatar
Re: Speed Engineering LS Swap Headers Findings
My 99 Fbody manifolds would not fit my 72 Blazer. I got the 1 3/4" long tubes and the passenger side needed the frame massaged a bit to fit right. I just bent the frame up a bit. I am mating the T56 to it and other than that the headers seem to be a pretty good fit. I am however planning on using the original F body Master cylinder which if I am correct would be in a totally out of the way spot. I am still mocking everything up at this point.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-08-2020, 10:06 PM   #152
Captainfab
60-66 Nut
If header to clutch slave cylinder clearence is an issue, you can always change to a hydraulic release bearing.
Old 06-09-2020, 10:55 AM   #153
Willie Makeit
Willie Makeit's Avatar
got a brand new set in the box that i won't be using due to the fact that you have to cut the "ears" off a 4L80e to run them.
Willie Makeit is offline   Reply With Quote
Old 06-10-2020, 06:59 PM   #154
clay68c10
clay68c10's Avatar
I’m going to use an internal slave. Check out gringoloco’s build. He’s running a TKO with an internal slave.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-10-2020, 08:40 PM   #155
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
price to 27612?
--Josh
Old 06-12-2020, 10:59 AM   #156
Willie Makeit
Originally Posted by STOCKISH View Post
price to 27612?
sold locally
Old 12-25-2020, 07:51 PM   #157
shortbed70
shortbed70's Avatar
I know this is an old post but I’m wondering how they have held up or if there is a better brand that won’t break the bank for an 65 c10 with a 700r4 2 wd that doesn’t hang way down below the frame...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-26-2020, 09:34 AM   #158
Acregger
Sorry cant help with how long they will hold up but I have to say they are pretty well built and do fit very nice for the price. So far I am happy with them
Acregger is offline   Reply With Quote
Old 12-26-2020, 06:08 PM   #159
LS short box
I've had them on my 68 C10 LS swap for 3 years with zero issues. As much as I hate China made stuff I just couldn't see spending $800-$1200 for US made. My LS is a small cam LS1 so not huge horse power. If I was running a big HP engine I would not buy the Speed Engineering headers. The best designed headers have the longest gradual turn down after the exhaust port. If you look at the SE header design they take a tight bend after the exhaust port.
LS short box is offline   Reply With Quote
Old 07-08-2021, 01:00 AM   #160
lts70
1970 Daily Driver
lts70's Avatar
Has anyone used their mid length? Trying to decide between mid length and long tube. See lots of information on the Shorty and Long but doesn’t seem to be much info on the mid length.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
