Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-13-2020, 12:17 PM   #151
First c10
First c10's Avatar
Re: Creamsicle: My 70 K10 SWB is about to get sweeter
Looking good Dan! I have had so many weird things that never happen or things that no one has seen before happen to me during this adventure of building this truck. Things that get me are the things you think you shouldn't have to worry about!!!
Hang in there the truck looks great. It will be awesome to get it on the road.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-14-2020, 09:59 PM   #152
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Thanks man. I appreciate it.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-14-2020, 10:20 PM   #153
derotoreut
derotoreut's Avatar
So I found out today that I have another minor setback. My fabricator was sent the wrong tubing material for the exhaust system. It was supposed to be polished 304 stainless, but they sent aluminized steel. His supply company in Texas is paying to have it sent back. They will also pay expedited shipping to send out the correct material. This kind of problem I can live with. I'll keep you posted.
In the meantime I thought I'd update you on some of the other stuff on the build... like my headlights. I decided to go with Dapper Lighting for my headlights. I bought their OE7 version with OE glass lens. They are LED projector headlights in a classic looking glass lens. They claim to give you three times more light then a traditional H4 type conversion while using less power. They also come with daytime running lights, which you can either use or not. I decided to tie the DTRL into my park lights. It's actually pretty bright. Check them out. I highly recommend them.
https://www.dapperlighting.com/colle...7/products/oe7
Here are the two OE7 headlights
This shows the daytime running light
You can see the DTRL at the bottom of the headlight
My headlight buckets did not require any modification. I rolled back the rubber sleeve and they fit right in. Once they were in, I rolled the rubber protective sleeve back.
I decided to add Weatherpacks to the DTRL.
~ Dan
Old 07-14-2020, 10:24 PM   #154
derotoreut
derotoreut's Avatar
Here are the different headlight beams. Kind of tough to tell, but I thought I'd post pictures anyway.
Here are the daytime running lights with my park lights.
Here are the low beams (DTRL stay on too)
Here are the high beams. I live in the country and there are a lot of deer. Hopefully this will help with late summer cruise nights.
~ Dan
Old 07-18-2020, 02:09 AM   #155
Richard
Nice. Looking at a set of Dapper lights for my truck. I may try to shoehorn in the hid classic V2's
Richard
Old 07-18-2020, 10:19 AM   #156
57taskforce
All about them K’s
57taskforce's Avatar
Nice! I need to get a set of dappers for mine too. The stock lights are really dim by today’s standards. I just run around with the highs on for now.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 07-18-2020, 08:09 PM   #157
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I used to work in an exotic shop. I brought home a bunch of European Hella H4 lights without DOT numbers .That's what I'm running. But, those Dapper lights may be next. Do they have glass or plastic lenses?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-22-2020, 01:12 AM   #158
Richard
Yep, like holding a match in front of a pie tin.
Richard
Old 07-22-2020, 10:45 AM   #159
jaros44sr
jaros44sr's Avatar
truck looks great, thanks for the updates, since I cant work on my truck, at least I can get my fix by following along with your progress. good choice on the weather pacs, did you also use the wire seals? thanks for sharing, great thread and build
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-31-2020, 01:31 PM   #160
Acregger
Truck looks great, awesome job!
Acregger is offline   Reply With Quote
Old 08-03-2020, 08:08 PM   #161
derotoreut
derotoreut's Avatar
They do come with glass lenses, but that's an upgrade. I went with the glass and love it.
Not sure what you mean by wire seals. The weather packs have seals that go over the wire that get crimped as part of the connection process. I also used solder seal wire connectors made by Sopoby during my build. They are great little connectors. They are heat shrink connectors that already have solder built into them.
~ Dan
Old 08-03-2020, 08:24 PM   #162
derotoreut
derotoreut's Avatar
I got my truck back from my exhaust fabrication one week ago, on July-27. The system turned out pretty nice. He used polished stainless steel and fabricated his own hangers. I already had some new Corsa DB mufflers, which I got from a friend of mine, that were used on the system. They are a bit louder then I hoped, but I can always change them out since my exhaust guy welded V-band clamps to allow for removal. I didn't have him go to the extent of grinding and polishing the welds. I may do this some day, you never know.
Here is overall picture of the exhaust system
Welded V-band clamps on inlet and outlet muffler connections. There was no room to put an X or H-pipe, so that was not done. He said it would not be beneficial anyways too far back in the system.
Back of exhaust over the rear axle
Another picture by the front driveshaft. You can't really see the passenger side because of the drive shaft. He did a good job getting around the transfer case.
~ Dan
Old 08-03-2020, 08:54 PM   #163
derotoreut
derotoreut's Avatar
So I also had my fabricator make up a core support/radiator cover and an engine cover. They turned out good, but maybe too much for this truck. Let me know what you think. I plan to pull them off and prime, block and paint them satin black. That might be a winter project.
~ Dan
Old 08-03-2020, 09:26 PM   #164
derotoreut
derotoreut's Avatar
So now that the exhaust is completed the truck runs much better. As I mentioned in an earlier post, it would start fine and then seem to run rich and the want to stall out. The problem was the O2 sensors being so close to the ends of the collectors with no exhaust pipes downstream. Now that there is a complete system, it runs great!
I was also having an issue with my Check Engine light being on. I ended up having a MIL code P0650, which appeared to be a generic malfunction indicator lamp (MIL) issue. I found out that this could be caused by damaged, open, shorted or corroded wiring. It could also be caused by poor grounds or failed MIL bulb or LED. When I connected my Dakota Digital RTX gauges I used their BIM-01-02, which pulls data directly from the PCM through the OBDII port. In the meantime the wire connection for the check engine light was not used. The PCM was showing this as an Open Wire and therefore turned on the check engine light and P0650 code. DD suggested that I connect the check engine light wire to the main DD module and turn off reading it through the BIM-01-02 module. This seemed to work and I was able to clear the code.
After that I started having an issue with my Check Engine light flickering on my Dakota Digital RTX gauges. It seemed like when it was first started it was fine, but then shortly afterwards the light would blink maybe once every 30-seconds. The more it ran, the shorter the blink duration. The light never stayed on though. I checked the OBD2 port for any codes, but wasn't finding anything. Once again I got in touch with DD and they said that sometimes these gauges need a small electrical load to keep the MIL off. I wired a small 12V lamp to IGN Hot and the ground side to the DD check engine terminal on the main module. This definitely did the trick. So now when the key is first turned on, the check engine light comes on in the RTX display and the small 12V light also comes on. Once it's started both lights now go completely off.
Here you can see the DD gauge cluster when the key is in the ON position and engine not started. The check engine light is on along with a small light located just above the AC vent. There was already a small hole there from the PO, which fit the indicator light perfect. This seemed to do the trick!!!
~ Dan
Old 08-03-2020, 09:32 PM   #165
rsavage
rsavage's Avatar
Exhaust looks very nice, Dan. The covers I think look good too. I would be a little concerned about painting them satin black though because I think they would get spotted up fairly easily. Maybe gloss? Truck is a work of art. Rick
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-03-2020, 09:38 PM   #166
derotoreut
derotoreut's Avatar
Thanks Rick, I'll keep your advice in mind. I always value your opinion. Looking at your signature I see you sold the Blazer. That was another fine job of yours. I imagine you made out well and somebody is quite happy with it. You did a great job on it.
~ Dan
Old 08-03-2020, 10:16 PM   #167
Ol Blue K20
It's looking great! Very clean!
Dale
Old 08-04-2020, 02:54 AM   #168
Richard
Good to hear the exhaust cured the running issues. Looks like a great job. Really like the DD instrument cluster. Think they look awesome and are just the ticket for engine swaps. Wish they offered an option with the tach in the OEM location and no analog type clock. Core support cover is a nice touch. IMO satin/semi gloss would look nice.
Richard
Old 08-04-2020, 09:19 AM   #169
rsavage
rsavage's Avatar
Dan, you don't need any advice from me. You are doing a fantastic job! You have made so many substantial improvements to that truck! Can't wait to see it in person.
1961 C1 Corvette
2021 Durango RT 5.7
Old 08-04-2020, 10:26 AM   #170
57taskforce
All about them K’s
Nice updates! The exhaust came out really nice! I like the vbands for the mufflers that’s the only way to do it in my opinion. Those Dakota digital gauges look awesome too. I plan to go this route eventually too.
Tyler
Old 08-06-2020, 04:33 PM   #171
derotoreut
derotoreut's Avatar
Well the truck is finally done (for the most part). I have a few minor things that I want to do to it, but it's drivable now. I still want/need to:
  1. Prime and paint the core support cover and engine cover.
  2. Get the Vintage Air AC system charged. (Done 8/15/20)
  3. Install new door weatherstrips, then put on my door sills.
  4. Need to install front speakers. (Done 8/12/20)
I put about 70 miles on it now since I got it back from my exhaust guy. Taking a few short trips at a time just to make sure I have no issues. My water temp seems to run between 200-205 deg-F, which appears to be normal for a stock 5.3L engine. If anyone has any comments on this let me know.
I finally got it washed today. Boy was it dusty after sitting for about a year and a half, since starting this project.
~ Dan
Old 08-07-2020, 02:46 AM   #172
Richard
Congratulations on getting the truck to this point. Must be an excellent feeling. Looks great!
Richard
Old 08-07-2020, 08:48 AM   #173
derotoreut
derotoreut's Avatar
Thank you. It feels good to have it at this point. I'm looking forward to enjoying it for the remainder of our summer.
~ Dan
Old 08-07-2020, 09:19 AM   #174
Ol Blue K20
Originally Posted by richard View Post
congratulations on getting the truck to this point. Must be an excellent feeling. Looks great!
x2!!
Dale
Old 08-09-2020, 08:51 PM   #175
1972CST
1972CST's Avatar
What an incredible build! You really have something to be proud of!
How did you like the Advance Adapter kit for the 4L60E to NP205?
I have heard mixed reviews.
1972CST is offline   Reply With Quote
