06-24-2020, 05:12 AM | #151 |
Re: 53 3100 - complete rebuild and upgrade . . . .
Thanks, fellas. They're not too bad to make, plus it frees me up to put the 5.3 exactly where I want and adapt accordingly. The drivers side, other than the steering interference, should actually be easier on the lower side with no starter to dodge so hopefully that'll be in progress soon. Still eye-balling column location to avoid coil packs, e.t.c right now.
More later- Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
06-25-2020, 04:17 AM | #152 |
A little more progress.
Mocked up the column for header fab. I'll do the firewall later; wanted to get this portion done first. Still have to hang my pedals, but as of now I'm happy with the room I'll have. Looks like I'll be 3/4" minimum from the closest tube, so I'll get started this weekend possibly. More later - Thanks for looking - Dan
06-25-2020, 11:53 PM | #153 |
looking good!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-26-2020, 04:59 AM | #154 |
Just a quick update but no pics. 3 tunes on the drivers side are mocked up now, so moving forward. It's hard to get motivated when I'm fishing all the time LOL!
08-26-2020, 11:01 AM | #155 |
Any progress is good progress Dan....Looks good.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
08-27-2020, 11:11 AM | #156 |
I'm surprised at the room you have for the column.
08-27-2020, 05:43 PM | #157 |
Why is that?
Dan
08-27-2020, 06:07 PM | #158 |
lv2tri2 comment made me look again haha.
do you have a double u joint at the bottom? if not you wont need that heim support.
08-27-2020, 09:29 PM | #159 |
It's just a standard u-joint top and bottom, but I'll probably use the heim joint just for insurance. Forecast is rain rain rain for the weekend so maybe we'll finish the rough fab on the headers.
08-31-2020, 04:53 AM | #160 |
Played around with the DS header a bit this weekend in the rain. Back 3 tubes are fitted up, but still ciphering on the front tube. My initial plan was to have that front tube go around the steering shaft, but I'm not sure that's the way I want to go. Might just add a u-joint and heim and go with it.
More later - Dan
08-31-2020, 07:35 AM | #161 |
Dan, I noticed from this pic. your oil pan sits lower than the lower control arm.
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
08-31-2020, 11:47 AM | #162 |
Yes it does, a little. Plan is to run a skid plate of some sort. Its still almost 6" off the ground, so I'm not too worried.
Dan
09-13-2020, 07:01 PM | #163 |
A little more progress. I didn't like swinging the front DS tube around the steering column, so I picked up another U-joint and re-routed a bit. Plenty of room for the front tube now, so I've been tinkering around on the mill making a bracket for a HEIM joint. Should finish it up soon then on to the next item . . . .
09-13-2020, 07:08 PM | #164 |
Now that is a strong steering bracket!! I like it.
09-16-2020, 04:17 AM | #165 |
A little more progress on the bracket for the heim joint. Might change it later, just seeing what works. I'll still have to figure out a good method of bolting it in if I go this way also.
More later - Dan
09-18-2020, 07:21 PM | #166 |
looks good, where did you get that mounting bracket... looks pretty stout
09-29-2020, 04:28 AM | #167 |
Still playing around with the heim bracket for the column. I didn't like the first one, so whittled up a second. I probably way overdid it, but that tends to happen. Have to drill and tap for mounting bolts, then moving on to the next part of the project.
09-29-2020, 08:26 AM | #168 |
Looks perfectly executed from here.....Nice work
Marc
09-29-2020, 08:52 AM | #169 |
Looks good. Much nicer than the piece of steel I bent up to do the same thing.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
09-29-2020, 10:02 AM | #170 |
Looks good. Is that billet steel? How much does it weigh?€
09-29-2020, 03:16 PM | #171 |
Thanks, guys. I started with a piece of 1-1/2" mild steel plate and went from there. I'd guess a pound or so.
Thanks for looking- Dan
09-29-2020, 10:02 PM | #172 |
A little more drilling, tapping and it's done for now. Back to the headers . . .
10-02-2020, 04:55 AM | #173 |
Ok, so after tinkering around the last few months here and there the headers are mocked up, steering mocked up, moving on. Thinking I may go ahead and run the exhaust on out, but not sure. Thanks for looking -
Dan
10-03-2020, 09:16 PM | #174 |
Last few couple of pics before moving on to the next step.
More later - Dan
10-04-2020, 02:18 PM | #175 |
Impressive, homemade headers
