Old 06-03-2020, 11:27 AM   #151
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
Originally Posted by DeadheadNM View Post
What are your thoughts on adding a push bar/brush guard?
Maybe. I talked to a guy that makes factory style brush guards a few hours away from here. I am more concerned with protecting the body when offroad, and repro bumpers are junk for that. I'd still like to install the winch I have behind the front bumper.
jimbosprint is offline   Reply With Quote
Old 06-03-2020, 11:53 AM   #152
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Find one of these and problem solved.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-03-2020, 05:09 PM   #153
jimbosprint
Something like this is my new plan.
Old 06-03-2020, 05:17 PM   #154
Ol Blue K20
Attachment 2021394
That looks good.
Dale
Old 06-03-2020, 05:46 PM   #155
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I've got a Smittybilt brush guard with the bolt-on hoops that protect the headlights if interested. There's a set of KC lights on it. Main center section is like a Hickey guard but the rise is greater - extends to the level of the upper part of the grille more than the Hickey. Not sure if the winch could be adapted for use with it though.
Old 06-04-2020, 02:00 PM   #156
jimbosprint
I opened up the rear differential this morning to find out what I've got. As I suspected, it has a Detroit Locker. The ring and pinion gear in the rear is 4.56 ratio.
Plan is to put matching gears in the front with a TrueTrac carrier.
Old 06-04-2020, 02:24 PM   #157
Ol Blue K20
Holy cow! It's not a freeway cruiser. What's in the front now?
Dale
Old 06-04-2020, 05:21 PM   #158
jimbosprint
Definitely not a freeway cruiser. The front has 3.07 gears I think. That's what it says on the tag.
Old 06-08-2020, 11:49 PM   #159
jimbosprint
I installed the new bumpers today. They sure are flimsy, and a big patch of chrome flaked off when I tightened down the front bumper. I'm afraid a trail jack would probably destroy them. Good thing this isn't a restoration.
Old 06-08-2020, 11:50 PM   #160
jimbosprint
At least now the truck has legal bumpers and it looks complete.
Old 06-09-2020, 08:35 AM   #161
Ol Blue K20
Looks good, but I would do a lot of complaining to the vendor on the chrome issue.
Dale
Old 06-10-2020, 01:25 AM   #162
SRU1436
Looks good, did you get the brakes squared away?
SRU1436 is offline   Reply With Quote
Old 06-10-2020, 07:39 AM   #163
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks good. Bummer about the chrome.
Old 06-10-2020, 01:01 PM   #164
jimbosprint
Thanks. I am taking it to a friend with a hot rod shop to look at the brakes today. I hope he is able to help me out.
Old 06-10-2020, 01:02 PM   #165
jimbosprint
It's a bummer, but the vendor has already said they will replace or refund.
Old 06-10-2020, 09:28 PM   #166
jimbosprint
Brakes saga update:
When I pushed on the pedal, my friend noticed the linkage was sloppy. This would have been impossible to diagnose by myself. We adjusted the brake pedal pushrod and it seems to have a much firmer pedal and improved stopping power. I need to mess with the brake light switch as it seems to stop the pedal from returning up all the way sometimes. Most importantly, it feels a lot safer to drive. I am still going to be extra careful testing it.
Old 06-11-2020, 07:44 PM   #167
jimbosprint
I made a cardboard mockup for a winch cradle to hang between the frame rails behind the front bumper. The rivets on the front spring hangers are in the perfect spot to mount it, but I think I will just add new bolts.
Old 06-11-2020, 08:53 PM   #168
Ol Blue K20
Nice winch, keep us posted on how it's going.
Dale
Old 06-13-2020, 12:35 PM   #169
jimbosprint
I made an alternative design for the winch cradle. It rotates the winch 90 degrees so the clutch handle faces forward instead of up, which would be much easier to engage/disengage. The wiring will be more difficult this way, but that only has to be done once.
Old 06-13-2020, 02:21 PM   #170
Ol Blue K20
Post pics of the mount process as you go. It'll look good I'm sure.
Dale
Old 06-15-2020, 11:02 AM   #171
jimbosprint
I'll probably make a separate thread for the winch install once it is done.
I went on a little drive yesterday about 15 miles into the foothills to visit with my friend that is going to help cut the winch plate out at his work. Here is a short video from the drive up - https://youtu.be/OBSpvhzhaZM
Old 06-15-2020, 12:02 PM   #172
Ol Blue K20
That road reminds me of the road to Oregon house/ Dobbins...lol
Dale
Old 06-15-2020, 09:21 PM   #173
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks like a nice drive.
Old 06-16-2020, 03:27 PM   #174
jimbosprint
Thanks guys! I love driving around Norcal foothills.
I dropped the truck off this morning to have the front gear work done. They are going to replace the wheel bearings and ball joints while they have the axle apart. Got to take a nice bike ride home on my old Raleigh.
A friend helped me cut out the metal for a winch plate. Now I need to get it welded together.
Old 06-17-2020, 07:33 PM   #175
jimbosprint
The truck is home from the gear shop. The front axle should be better than new. It has a TrueTrac limited slip carrier with 4.56 ring and pinion, new seals, bearings, u-joints, ball joints, and wheel bearings. They also did a nice job cleaning up and painting the old parts.
ochre
