Old 04-28-2023, 07:34 PM   #151
28TudorAZ
28TudorAZ's Avatar
Re: Ford Model A Tudor Modern Twist on a Classic
Originally Posted by Dieselwrencher View Post
The rod looks awesome! Did you get your brakes figured out? I had a similar issue on my vette and it ended up being the MC push rod was adjusted a little too far out. When the brake fluid warmed up it applied the front calipers and they would lock on. It was the strangest thing.
I had the same thing on a 23 Bucket T where the front brakes would lock up. It ended up being the MC push rod binding just a little bit.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 05-04-2023, 02:06 PM   #152
gigamanx
Similar issue. Push rode between the booster and master cylinder was ok, but I had adjusted out the brake pedal rod thingo so it was too long. That caused the booster to sit about 50% closed when the pedal was released. Now I've gone too far the other way so somewhere in the middle will end up being my sweet spot.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 05-06-2023, 05:32 PM   #153
daveshilling
daveshilling's Avatar
Originally Posted by gigamanx View Post
Wasn't happy with the seats, so why not cut my bucket seats in half and take out a section, weld them together, buy a sewing machine, learn to upholster, buy some foam, sew seat covers....
[/img][/url]
How did everyone pass up this update?! Doing your own upholstery is a pretty rare thing around here... this is awesome! Well done.
daveshilling is offline   Reply With Quote
ford tudor sedan ls
