#1726 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1727 |
![]() Join Date: Aug 2020
Re: What did you do to your truck today.The 3rd chapter
This week has been shovel snow, replace the cargo light switch, shovel snow, install under dash courtesy lights, shovel snow, set the hood properly, chip ice off the driveway, help from you guys figure out my driveshaft issue, new headlights, new steering wheel ...oh, and shovel snow.
#1728 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#1729 |
![]() ![]() Join Date: Jan 2005
Installed a temporary front fender and made some brackets for the front turn signals so I will be able to drive my truck while several parts are off at the body shop. Waiting for a new cam to arrive so I can finish the Vortec head upgrade.
#1730 |
pjmoreland that is exactly what I want to do with mine. I have the original seat out my ol '67 and would like to have the folding feature in the '71. Nailed the color combo too! Must be the great minds thing!...or just a quinkydink...
#1731 | |
Old member
![]() Quote:
Ok thanks, man $127.00 for the pair great deal sir! ![]()
#1732 |
I was going back and forth between the black/white and black/orange houndstooth, but my wife convinced me the orange wouldn't match my truck, so I gotta give her some credit. I think the black/white looks good with the silver on the gauge cluster bezel.
#1733 |
I'm in love...pjmoreland
#1734 |
Who Changed This?
![]() Join Date: Jan 2013
I like the black and white hounds tooth. I have the black vinyl brocade that is just too hot in summer, and it's all split out. I want to replace the cover, but I ain't going back to black if I can help it. I'll show my wife this pic.
#1735 |
I had the black with cloth but at the time couldnt find it reproduced I since have found the correct seat cover but like the hounds tooth . Misses hates the feel of vinyl or even the leather in my Envoy. Specially when shes in shorts which is most of the summer
#1736 |
![]() Join Date: Mar 2011
bought this one for parts
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#1737 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
New TH350 Shift Shaft and Speedo gear to be leak free and I installed these sweet license plate holders for front and back that I got off eBay when I brought her home tonight :-)
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#1738 |
#1739 |
A picture is worth a thousand words (four letter words, in this case).
#1740 |
#1741 |
laying low
![]() Join Date: Mar 2001
Looks like a collapsed oil filter. Did someone say Fram?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#1742 |
Mr. Cheyenne
I am guess I am glad and listen to my brother and got a AC Delco...
#1743 |
Beep! Beep!
![]() Join Date: Nov 2003
Rebuilt the top end of the steering column yesterday. My truck had a broken hazard switch when I bought it and never replaced. Put in new levers, signal/hazard, and indicators. Only issue was a I mangled the end thread with the puller, so I'm currently trying to figure out to best rectify. Still need to correct the indicator position as well.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
#1744 |
It's a Mobil1 filter that refused to come off. There was paint on the block and the seal stuck to it. You can see a little red on the seal.. I have since cleaned the paint off. I am also feeling a bit skeptical of the recommended 1-1/4 turns past contact they show on the sticker.
#1745 |
70+ ( Old Skool Club )
I picked these up to use on my 400 small block build.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#1746 | |
#1747 |
Mr. Cheyenne
Transmission leaks fixed (shift shaft and Speedo gear) - though I didn't do it myself. Replaced signal mech, hope that nails my short/blowing fuse and after replacing all the screws, inserts, and springs I did a very early morning headlight adjustment a bit ago! Nice to have a morning drive in the truck :-)
Oh and for a nice little topping, noticed my antenna was loose and moved, so I adjusted that when I got home.
#1748 |
1/4 turn seems a little loose, but I agree 1-1/4 is way too tight.
#1749 | |
Old member
![]() Quote:
Split the deference! ![]() ![]() ![]()
#1750 | |
