Old 12-08-2018, 04:55 PM   #1751
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by knomadd View Post
...You're doing good... keep going!
Thanks for the boost, this will be a big hurdle that allows lots of reassembly to occur.
Originally Posted by 65StreetCruiser View Post
Intake looks nice, Chris. The HAMBers do go to the extreme, no doubt. It will look good painted!
Firewall looks very nice, can't wait to see when it's done!
Thanks buddy!
Progress report: I took a break from sanding to do some, um, sanding. What kind of psychopath wet sands and polishes his valve covers? This kind... Perfectionism is a disease. I’m leaving these at 90%, good enough
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-08-2018, 07:00 PM   #1752
Kronald_70GMC
Kronald_70GMC's Avatar
Thanks buddy!
Hahaha I thought I was the only guy who does this kind of thing! You've got an eye for detail! This thread has been extremely motivational for me to get my truck back on the road. Outstanding work.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-09-2018, 01:26 AM   #1753
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks a lot. You’ve got some heavy metal work going, keep up the good work.
The eye for detail is a blessing and a curse. Nothing is ever good enough...
-Chris
Old 12-09-2018, 11:50 AM   #1754
jocko
jocko's Avatar
‘Nother little project, speaking of under hood. Got rid of the Holley logo on the intake runner using a half-round, some 80 grit to smooth out the scratches, then 40 grit and a body hammer to recreate the as-cast look. Hoping it all but disappears once primed/painted. There will still be logos remaining on the Holley fuel rails and the Wilwood master cylinder cover; will see if they bother me bad enough to do something about it.
your manifold looks great, nice job on that. I have done this twice, but ended up sending my manifold to Lamar Walden's shop (the 409 guy) just north of atlanta for a tumble in his manifold smoothing thingy machine. Was described a as a big dryer with walnut shells in it - not sure how accurate that is, but the marks all but disappeared (removed an Edelbrock casting) - I was leaving them bare - and it also transformed the dirt-trapping aftermarket casting into smooth gm-like casting finish. I do believe yours will be practically invisible after paint.
Old 12-11-2018, 08:48 AM   #1755
mcbassin
Still Learning
mcbassin's Avatar
The firewall and valve covers look great! Keep at it..
mcbassin is offline   Reply With Quote
Old 12-21-2018, 05:13 PM   #1756
GSFMECH
On the road
GSFMECH's Avatar
Chris, it's been ages since I've been on here and I have to say it looks great bro, can't wait to see it in person.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 12-31-2018, 04:43 PM   #1757
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Thanks dudes! Moved on to final clean, prep, and paint on the engine. Gotta say, I’m digging it
What did you use to clean and prep the engine for paint?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-06-2019, 05:53 PM   #1758
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, Mike!
Thanks Mike, too! Hopefully soon...
Sorry for the delay, hope it’s not too late. Initial clean was with oven cleaner to get rid of the gunk, then simple green/power purple/whatever skin-eating acid cleaner I had around with various brushes, rags, scrapers, and implements, then final prep with laquer thinner and 3M scrubbies. Lots and lots and lots of time spent in all of the little books and crannies.
-Chris
Old 01-06-2019, 06:02 PM   #1759
gringoloco
A guy with a truck
gringoloco's Avatar
Ok, folks. Need to some honest input, here. My original plan was to do everything under hood in black and orange, like a truck engine, but I kindof accidentally mocked up the engine like a late ‘60s hipo car big block and I also kindof accidentally like it. Thoughts?
-Chris
Old 01-06-2019, 06:05 PM   #1760
gringoloco
A guy with a truck
gringoloco's Avatar
It reminds me of this style, though I’m not sure I’d go so far as to do crossed flags and tonowanda decals.
-Chris
Old 01-06-2019, 06:06 PM   #1761
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Chris, I think the engine looks great. Personally I like some color comtrast, and the only time I do blocks in black is to help hide any leaks
I hate cleaning crud off more than about anything else on a project, but it's so nice when it's done.
Zoomin is offline   Reply With Quote
Old 01-06-2019, 07:58 PM   #1762
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
I like it, think that it would look good in the truck. I have always liked the hi-po car big block look.
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
65StreetCruiser is offline   Reply With Quote
Old 01-06-2019, 08:10 PM   #1763
smbrouss70
smbrouss70's Avatar
It looks good like it is, but you know I like the black and orange more. I will say that if you go with it like it is, you better powdercoat that intake an aluminum color because it won't stay pretty very long in the elements. I would seal up those billet valve covers too.
Where does the A/C compressor mount?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-06-2019, 08:11 PM   #1764
smbrouss70
smbrouss70's Avatar
I'm kind of wishing I had painted my engine black right about now!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-06-2019, 09:07 PM   #1765
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks. I like some contrast, too, but I’m concerned it might be a little busy
I do think it would pair well with the “muscle” feel of the truck with the Muncie, Hurst with white shift ball, and grey spoke wheels.
You bring up good points, which I’m not sure I’m committed enough to the look to properly remedy. I would paint or powder the intake and probably chrome the VCs. My other option is to do similar to what you did with a scuff and shoot. Honestly, I only grabbed the billet specialties covers because I didn’t want any oil leaks with the stamped steel stockers. I definitely don’t want something I’ll have to polish all of the time, I learn from others’ mistakes
The plan for the AC compressor is stock-ish location. Need to get the motor back in and see if plan A (Alan Grove with current compressor) will work. I fear it will interfere with the steering rack, so then on to plan B (Dirty Dingo or Holley). If. One of that works, maybe I’ll save my pennies for a Holley mid mount setup or just go ahead and install that rear sliding glass I want
LS engines don’t leak, just sayin’
-Chris
Old 01-06-2019, 09:28 PM   #1766
smbrouss70
smbrouss70's Avatar
Touche'!
I know, I know... But I have WAY too much invested in my little small block to change directions now. Brandi will kill me!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-07-2019, 01:00 AM   #1767
cornerstone
cornerstone's Avatar
Personally I would like the black and orange, nothing shinin' up the joint. Subtle is sexy.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 01-07-2019, 04:21 AM   #1768
GSFMECH
On the road
GSFMECH's Avatar
I think you hit the nail on the head Chris, I think It's perfect the way it is, I love the orange.
Mike
Old 01-07-2019, 05:39 AM   #1769
tino0217
Looks damn good brother, simple but tuff
tino0217 is offline   Reply With Quote
Old 01-07-2019, 10:50 AM   #1770
rustytruck50
rustytruck50's Avatar
Tough decision...I think either way you go is going to look great....I really like the pics a few posts back!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 01-07-2019, 11:32 AM   #1771
knomadd
knomadd's Avatar
That's a tough one. I did mine all orange and black and I like it, but I see the muscle car look in the current color scheme you have and it looks nice too. I do agree that you'll need to do something with the aluminum pieces though. You'll be polishing like crazy if you don't. And that intake won't look good for long if it's left bare.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-07-2019, 02:09 PM   #1772
SCOTI
SCOTI's Avatar
Though not an LS, I did it. I wanted the older Musclecar period look for my later model Squarebody TBI equipped set-up. While mine IS a big-block, the newer stuff bared very little visual resemblance to it's Musclecar precedent.
I had the factory painted steel valve covers chromed because they were:
A) Cheap
B) I already possessed them
C) After comparing to TRUE 70's era BBC chrome v.covers, they were much smoother.
I used an Edelbrock TBI intake vs. the cast iron BBC intake w/the TBI adapter & a period correct dual snorkel air cleaner to top it off.
I re-routed wiring & other asthetics to appear less electronic. I liked the older look once finished.
I also did the 'Built by Chevrolet Tonawanda' v.cover & 454 air cleaner engine displacement decals to finish off the 'look'. The repop decals didn't survive underhood life for long before coming apart & have been removed...
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2019, 05:26 PM   #1773
fatbass
fatbass's Avatar
Wow! I really like the look now.
I'm not a fan of the orange and black.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 01-09-2019, 09:27 PM   #1774
gringoloco
A guy with a truck
gringoloco's Avatar
I agree, but this made me re-think my former stance on the subject
Thanks, it does have a nice classic look to it
Agreed, thanks
Super tough, I’m still not decided. I do have a few more ideas, too
That’s the thing, not sure I’m in love with it enough to make it permanent
A) Cheap
I really like the air cleaner setup. Is that the LT1/Z28 base?
Thanks, I’m still undetermined. I like a simple, stock look, usually
-Chris
Old 01-09-2019, 09:31 PM   #1775
gringoloco
A guy with a truck
gringoloco's Avatar
Another variant. Pretty sure the water pump will be orange and the accessories black no matter what else happens...
-Chris
