#1776 |
Re: What did you do to your truck today? Chapter II
got the new engine and trans in. have to find the right shifter or bend this one. and get the driveshaft shortened
#1777 |
I replaced the rear tail light lenses, the housing buckets, the back-up lenses & housing buckets. And I also repaired the reverse light/neutral switch on the steering column. So now it won't start if it's in Reverse or Drive & now the back-up lights come on when shifted into "R". That was no easy job for a big guy like me. Those tiny screws that holds the switch onto the column can be trouble getting them back into their holes. And there is no room between that switch, the column & the firewall. It was a great day! (sarcasm) lol
"Now all I need is a shop to go with my shop vac!" ![]() |
#1778 |
![]() Join Date: May 2013
Pulled the old 283 out. Salvaged the flywheel, starter, and oil pan to reuse on the replacement.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#1779 |
![]() Join Date: Sep 2013
Made and installed an aluminum firewall harness/plug cover to match all my other fabricated looking things. Liking the exposed welds on my rad, rad over flow, washer over flow, valve covers. Making a custom alum scoop for carb next..
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
#1780 |
Yesterday I installed a center seat belt and figured out why the fuel gauge reads empty all the time. The float is missing. time to order one of those.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#1781 |
POR15 the cabin floor, added peal and stick, heat shield bubble wrap and jute padding. Used the original foam as a template. Was going to go MLV route but never got around to ordering.
Hope to take for a test drive tomorrow and see how effective it is. ![]()
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#1782 | |
![]() Join Date: May 2012
#1783 |
Got a replacement fleetside long box today. The sides had already been removed. Gonna remove the back panel and wheelwells, and go to town with the wire wheel drill attachment. There's a few small dents and some surface rust on the floor. But, it's so far superior to my current bed (rust is pretty much the only thing holding it all together).
Tomorrow, gonna get the bed floor off the truck and find a place in the garage for it.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#1784 |
Completed my suspension- CPP 5.5 up front and 7 in the back. 5 in spring and 2in block for the rear. 18X8 up front and 18x9 in rear.
#1785 |
![]() Join Date: Jun 2011
Did some finish wiring to the tail light circuit and following my engineer friends advice about never using slip connectors but solder all splices and use shrink tubing to prevent moisture from creating problems.
#1786 |
Did you already get yours back together & running? I went to Jumbo Joe's in mine yesterday while the weather was nice. I'm thinking of going to Sonic on Thurs about 6pm & see if any of the car gang shows up, it may still be to early in the season for them but it's suppose to be 70 degrees & windy thou.
#1787 | |
#1788 |
The one at 5802 64th St. Actually it's at the corner of S. Frankford & 64th Street.
#1789 |
#1790 | |
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#1791 |
Polished the new radiator. Can’t wait to install it.
#1792 |
I stood in the driveway and waved goodbye to her while counting the fat stacks of cash. I'm ready for a new project now!
#1793 |
Installed my drop springs and before the new springs wheel well measured 33 7/8. After it measured 33 7/8. I was expecting more out of 2 inch drop springs. How long should it take to settle?
#1794 |
RAT1968 '68 Cab/'71 Parts
Finally "finished" the column shortening and switching out Tom's amp:volt gauge kit. That part was a breeze. Works like a charm.
What *was* a PIA was the fact that the reverse/neutral switch wouldn't find a home on the tilt column where it would clear the firewall clamps...whether I ran it inside of the cab or in the engine bay. So, since I'd already used the M & H jumper on the neutral safety switch, I just wired in a toggle switch for the reverse lights and put it in the e-brake cover. Up:ON Down: OFF Simple.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#1795 |
well I bet you will miss that truck , I am glad we got to take them out for a cruise night a sonic before she left , cant wait to see the new project , let me know when you get it , I would love to see it ....... glad to know you and lets have another cruise nite when you get the next one going..... Don
#1796 |
Pulled the cab up off the frame of the shortbed and suspended it so a body guy can come put it on his trailer and take it to his shop to repair the rot. Finally decided I am going to get some help at least on the cab to get the project moving faster. Wanted to do it myself but just can't get time on my side.
![]() 72 K5 Blazer 72 K10 SWB (in pieces under slow construction!) 72 K20 |
#1797 | |
#1798 |
I bent a push rod and so went off to the junkyard and pulled a new set of matching ones :
You can see the one bent one there , need to do some serious cleaning before using these . I yanked them out of a 1980 G/10 van , the engine was full of crud : It looks like they used cheapo paraffin based Dino oil and never changed it : One of these push rods was so gunked up I had a heckuvva time getting it out . I also went back to the 1968 C/20 I've been harvesting hardware from and they'd taken the V-8 engine out so I scored all the correct original motor mount to frame bolts & nuts plus some of the original tranny to engine bolts and lots of misc. 3/8" hardware they left scattered about . All in all a good day , after that I ha to pull the dash out of a 1988 M-B W-126 , what a job that was ! about a million fasteners and I couldn't break / cut anything as Ineed to put said dash into my Brother's car ![]()
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#1799 |
Theres a reason that pushrod bent. check the rockers at the cylinder of the bent pushrod to make sure the rocker wasn't riding off center on the valve. check rocker ball, and rocker itself for cracks or uneven wear. Have fun cleaning!!!!!!
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#1800 |
Thanx Joe ;
Yes , the push rod bent because the engine tipped over on the engine stand , denting the chrome rockerbox slightly : I'll replace them all because I don't like mis matched parts . I thought I had a thread on this engine job but couldn't find it . it's getting there bit by bit , a lot of wrong & gone missing hardware . As far as cleaning , how's this : This is the inside of the oil pan when first I removed it ~ I'm a firm believer in BLISTERING HOT regular oil changes . The gunked up blue engine was the junkyard one . The inside of my engine : I have lots of photos of the engine and parts but not sure if they belong here or elsewhere....
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() Last edited by VWNate1; 02-22-2015 at 12:05 PM. |
