02-18-2019, 03:45 PM | #1801 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Finished up the rough body work on the valvecovers, then laid a coat of self-etching primer. That will get a scuff, then filler primer, then some engine orange. I’m really liking the way these are turning out
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-18-2019, 04:47 PM | #1802 |
Super clean, very nice.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
02-18-2019, 08:57 PM | #1803 |
It Is What It Is
Wow, everything that you've done recently looks great, Chris!
Love what you did with the valve covers and the firewall turned out super nice!
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
02-18-2019, 09:04 PM | #1804 | |
A guy with a truck
First shot is post-sanded filler primer, prior to final prime, then sexy orange top coat
02-18-2019, 09:34 PM | #1805 |
That is super cool!
02-18-2019, 11:19 PM | #1806 |
A guy with a truck
Thanks, bud. I’m liking them. I slapped them on the engine and I like ‘em even more:
02-19-2019, 02:50 AM | #1807 |
I'm lovin' it! So what is going to grace the top of those valve covers? Script or CID decals?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-19-2019, 01:41 PM | #1808 |
A guy with a truck
Keeping ‘em clean. I’ve even thought about painting the wilwood master cylinder cover to hide the logo...
02-19-2019, 01:43 PM | #1809 |
I would be way ahead of you on that one. It would happen quickly.
02-22-2019, 09:52 AM | #1810 |
Looking killer!
Have you seen the Vintage plug wires that Delmo sells? https://www.delmospeed.com/product/vintage-plug-wires/
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
02-22-2019, 10:21 AM | #1811 |
I feel the 'vintage' appearance of those were used a little earlier than the 70's. A solid grey or black plug wire in 8mm or larger will look fine & get it done w/o the additional expense.
02-22-2019, 11:04 AM | #1812 | |
A guy with a truck
02-22-2019, 11:39 AM | #1813 |
02-22-2019, 12:13 PM | #1814 |
A guy with a truck
Cubic Inch Displacement, this is what Steven did with his:
I like it, but I’m going for simple, smooth, and clean...
02-22-2019, 11:46 PM | #1815 |
A guy with a truck
The Holley intake manifold is cast with only one vacuum port, which will be used for the brake booster. Given that, I was forced to drill and tap a few extra holes to accommodate the manifold absolute pressure (MAP) sensor, which will hide behind the throttle body, and the PCV valve, which just barely fits underneath the plenum floor. The PCV is a mid-60s GM V8 piece that uses 1/4” NPT on one end and a hose barb on the other. The plan is to plumb to the back of the valve covers for a completely hidden system.
I went ahead and mocked up the fuel rails, injectors, and fittings and am happy with the fit of everything. Time to get this thing in some color
02-23-2019, 01:21 PM | #1816 | |
02-24-2019, 09:27 PM | #1817 |
A guy with a truck
Dy-no-MITE! Sorry, couldn’t resist...
Apologies to everyone that wanted the intake to remain raw. Water pump is next, then accessories.
02-25-2019, 01:56 AM | #1818 |
YES! YESS!! YESSS!!! This was the absolute right way to go with your truck...I would say the overall design is "understated perfection", like when the most beautiful lady in a modest dress enters the room and all the other wanna be's with goo-gobs of make-up and mini-skirts get mad. I will probably dream about how good it will look with a black air cleaner tonight.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
02-25-2019, 02:14 AM | #1819 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-25-2019, 09:51 AM | #1820 |
PROJECT 7DEUCE
Looks like the engine is coming together
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-25-2019, 11:28 AM | #1821 | |
A guy with a truck
What if I told you I was thinking of doing an air cleaner like this, too much?
02-25-2019, 11:29 AM | #1822 |
A guy with a truck
Haha, I’m a little hot-and-bothered over here myself
Slow and steady wins the race
02-25-2019, 12:24 PM | #1823 |
If it turned out you needed a dual snorkel for lack of air, so be it. I have seen others do a similar setup (MetalDoc) and I’m pretty sure it reduced the sound of the rushing air when at WOT. My thought would be to stay on the simple side if you can get away with it. Either way it’ll be great.
02-25-2019, 12:36 PM | #1824 |
No.... It's not two much
02-25-2019, 06:09 PM | #1825 | |
A guy with a truck
Yeah, 3 would just be weird, except for that one time in Total Recall...
