10-23-2012, 10:12 PM | #1876 |
Re: PO has me PO'd
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
10-23-2012, 10:19 PM | #1877 |
Re: PO has me PO'd
Dude you are good, now i can play in the workshop tommorrow morning
Thanks for your time
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-25-2012, 10:46 PM | #1878 |
Re: PO has me PO'd
They wanted 50 bucks for this piece in billet, since you dont really see it, i thought what the...., so, i cut most of it off on the bandsaw, then a little rough trim with the dremel. Some more filing and sandblast
I dont live in alaska, so the heated water jacket does me no good A couple more days and i get to order my F.A.S.T. XFI 20121025_105334 by jarosaj, on Flickr 20121025_122502 by jarosaj, on Flickr 20121025_130340 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-25-2012 at 10:54 PM. |
10-26-2012, 12:08 AM | #1879 |
Re: PO has me PO'd
Cut the vc oil vapor diffuser out, figure out how and where to mount it in my other vc
20121025_112019 by jarosaj, on Flickr Side bar....this is a indicater how many times this tool has bit me over the years. Each red line is a scar....so, wear cut resistant gloves. Im right handed, so im always holding the work in my left 20121025_122747 by jarosaj, on Flickr
10-31-2012, 01:56 PM | #1880 |
Re: PO has me PO'd
Relocated my pcv valve to the rear of the aftermarket vc, more direct line to the intake. Bored hole out to 15/16" using a deming drill ( reduced shank to fit in my 1/2" chuck). Bit of a struggle to get the grommet over both pieces, since vc was thicker then oem.
Next will drill both pieces, oem diffuser and vc, and use a countersunk pop rivet to hold in place. Grommet alone holds well, but i dont want to take the chance and have it rotate with vibrations 20121031_130644 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-01-2012 at 11:02 PM. |
11-02-2012, 02:10 PM | #1881 |
Re: PO has me PO'd
Hey, dale 99.....
Have another favor to ask. Could you show me how your coil is mounted on your intake? Was told today, as i was ordering my FAST XFI, that my coil could mount up like the camaros...any help? Thank you for getting me past the pcv system
11-02-2012, 02:18 PM | #1882 |
Re: PO has me PO'd
My coil is not normal. Normal is on the passenger side of the intake, bracket bolted to the left 2 rear bolts.
like this if the link will work. http://s3.beta.photobucket.com/user/paulo57509/media/camaro/coilbracket-mod.jpg.html?filters[term]=recent&filters[primary]=images Last edited by Dale99; 11-02-2012 at 02:28 PM. |
11-02-2012, 02:31 PM | #1883 |
Re: PO has me PO'd
there we go. Thats the coil on the left of the pic, thats cut off. There is a "z" bracket that bolts to the intake. Then you have an L shapped bracket that the coil bolts to, that sits on the z bracket.
I dont even have that stuff to assemble and snap pics of for you. |
11-02-2012, 03:07 PM | #1884 |
Re: PO has me PO'd
Thanks, thats a start....wonder if gm might still have that stuff. I have a MSD coil, so i will have to modify it anyway
Thank you for your time
11-02-2012, 05:50 PM | #1885 |
Re: PO has me PO'd
which msd coil? They make a "oem replacement" one, which is what I'm running. Its just not in the stock location.
Found a pic of my setup from a few years ago online. Coil is still in this location, but everything else is different. https://sphotos-a.xx.fbcdn.net/hphot..._7371417_n.jpg |
11-02-2012, 06:55 PM | #1886 | |
Re: PO has me PO'd
11-02-2012, 10:39 PM | #1887 |
Re: PO has me PO'd
6al is a controller box which does the same thing as a computer system. IIRC you still need an actual coil.
11-02-2012, 10:51 PM | #1888 | |
Re: PO has me PO'd
Sorry
11-03-2012, 11:14 AM | #1889 |
Re: PO has me PO'd
Hey Dale, my coil is blaster gm pn8226, any closer pics of how you mounted your coil.
Thanks for any help
11-04-2012, 07:24 PM | #1890 |
Re: PO has me PO'd
8226
11-04-2012, 11:30 PM | #1891 |
Re: PO has me PO'd
Thanks bud, thats about what i was thinking....theres two problems you got me past.
XFI should be in mon. tues., a whole can of worms
11-05-2012, 07:39 AM | #1892 |
Re: PO has me PO'd
Xfi??
11-05-2012, 02:24 PM | #1893 |
Re: PO has me PO'd
Hopefully ill show you a pic tommorrow...just found a oem coil bracket on ebay
11-06-2012, 02:14 PM | #1894 |
Re: PO has me PO'd
Holy crap Batman, this is not my forte! This mod. is going to take awhile
20121106_123426 by jarosaj, on Flickr
11-06-2012, 03:39 PM | #1895 |
Re: PO has me PO'd
ohhh, a pcm. I grew up with an electrician, so wiring is not difficult for me. But just take your time, dont rush it.
11-06-2012, 04:39 PM | #1896 | |
Re: PO has me PO'd
Consider yourself lucky to have electrical background, it doent come easy to me. Trust me, i will be on the phone alot to the technicians at FAST. First step in the directions states to only run plus and negative to the battery, no intermittent leads any where. Not heeding this advise is the leading cause of problems. Also, running pcm wires to close to the ignition wires, and spark plug wires Now i have to find about a 4" holesaw, location right above trans. cover Dont rush it....possibly you havnt noticed when i started my build. lol
11-07-2012, 02:14 AM | #1897 |
60-66 Nut
Re: PO has me PO'd
Is that harness designed specifically for the TPI?
11-07-2012, 07:48 AM | #1898 |
Re: PO has me PO'd
You have pcm, or ecm.
PCM=Powertrain control module. ECM=Engine control module. Main difference, if it controls the transmission and more (ABS, traction control, transfer case, etc). So that may just be a "ECM". |
11-07-2012, 12:25 PM | #1899 | |
Re: PO has me PO'd
Thanks for the explanation, i have pcm
11-08-2012, 02:19 AM | #1900 |
60-66 Nut
Re: PO has me PO'd
No, just curious if FAST makes a retrofit harness for the TPI for use with the XFI, or if you had to modify one to work.
So the EFI will control an electronic transmission?
