03-17-2015, 09:46 PM | #1901 |
Re: What did you do to your truck today? Chapter II
Not something done today, but over the weekend. Removed the wheels to have the tires replaced, discovered how bad the front breaks where. After removing the dust caps, found out that a nail is a suitable sub for a cotter pin. Also, no torque on either nut. Hand tight would have been more than what torque was on the nuts. All said and done, both front brakes, calipers, pads, rotors, and bearings changed. Good-to-go!
03-17-2015, 09:59 PM | #1902 |
looks real sharp... did you do the paint?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
03-17-2015, 10:01 PM | #1903 |
Found out I was lied to about how old the build was on my motor so now guess what Im adding to my list...
03-17-2015, 10:56 PM | #1904 |
Actually let the wife drive her 67 home from dinner and she broke it. Pulled in to drive way and the driver side rear wheel was smoking. Jacked rear up and tried to turn the wheel. Could not move it. Let truck down and now it won't move at all. Sounds like the wheel cylinder locked up and...... She can't drive the truck ever again
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
03-17-2015, 11:08 PM | #1905 |
McGoo26, hope you didn't torque the wheel bearing nut. It's not suppose to be torqued. Just tight enough to put preload on the bearings. You probably knew this already I am probably reading more into your post than what you wrote.
72 Chevy C20 LWB-Just what I always wanted. Now, just need more time and money! |
03-17-2015, 11:33 PM | #1906 |
Adjusted the wiper arms to the optimum off position all in the comfort of my trucks new home in the garage
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-18-2015, 06:05 AM | #1907 |
Ball joints, front shocks, cleaned and greased front end. Man what a difference in the ride. Now if my new tires would just get here... (this was yesterday)
03-19-2015, 12:34 PM | #1908 |
Dreaming of the day!
03-19-2015, 02:36 PM | #1909 |
New tires, rear brake hose and master cylinder...
03-19-2015, 02:40 PM | #1910 |
03-19-2015, 03:08 PM | #1911 |
03-19-2015, 03:09 PM | #1912 |
After reading my post again I can see how it may have implied that it needed huge amount of torque. Another part to the task that I didn't mention was before anything was undone, the rotors had about an inch or so, if not more, of play side to side (passenger to driver side) on the hub. As I said, finger tight would have been an improvement. Torqued while spinning the hub to seat or preload everything, backed off then cotter pinned. Thanks for your insight.
03-19-2015, 05:19 PM | #1913 | |
US Army Veteran
Welcome from another Texan. Just down the road from you, in San Angelo.
1972 C10 Highlander - The making of a daily driver |
03-20-2015, 12:44 AM | #1914 |
Fixed some small dents in my front quarter panels on the 72 k2500 and shot the first coat of primer on them. Small things like that get me excited to see the finished product. Long road of body work ahead before I get to any fun stuff though.
1972 GMC K25 350 sm465 1969 GMC C15 350 th400 2009 Chevy Silverado 1500 |
03-20-2015, 08:33 AM | #1915 |
Welcome from another Texan. Just down the road from you, in San Angelo.[/QUOTE]
Thanks..... I just ordered the painless wiring kit,, puts me one step closer to rolling. |
03-21-2015, 12:00 AM | #1916 |
Installed a column mounted tach in the ol 68. I like it.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
03-21-2015, 12:02 AM | #1917 |
03-21-2015, 12:14 AM | #1918 |
What a beauty, my favorite rims too, just icing on the truck cake..
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
03-21-2015, 09:35 AM | #1919 |
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
03-21-2015, 12:40 PM | #1920 |
Worked more on the 348 the last few days. Still have a lot to do, seems never ending...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
03-21-2015, 02:33 PM | #1921 |
Never get tired of the w motor, neverending cool.
03-21-2015, 02:52 PM | #1922 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
03-21-2015, 06:16 PM | #1923 |
Added an auxillary input to my otherwise useless radio, thanks to another members instructions. Hardest thing was finding a radio shack still open for business. Installed cig. Lighter assembly. Found a cool jack in the stuff PO included. |
03-21-2015, 08:28 PM | #1924 |
Glad winter is finally over!
Got my engine, converter & trans linked up and bolted into the chassis today. I'll get to crank her soon! Can't wait... |
03-21-2015, 10:50 PM | #1925 |
Spent almost 2 hours trying to get the motor mount bolt to thread. Finally just pulled the mount out, cleared the rubber from the threads, reinstalled the promptly cross threaded one of the bolt into the block. Many profane words were uttered. I was able to replace the rubber fuel lines under the cab and at the fuel pump. Still didn't feel like a very productive 3 hours.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
