06-09-2015, 12:28 PM | #1926 |
Re: Restoring Rusty
Where did you get those tailpipes? They look great!
06-10-2015, 08:05 AM | #1927 |
Post Whore
Re: Restoring Rusty
Not sure if you're serious or joking, but they are from LMC Truck, here's what the set looked like when I unboxed it and laid it out 9 months ago, went together very nicely
I think I walk through the install on page 1 of this long thread |
06-11-2015, 07:15 PM | #1928 |
Post Whore
Re: Restoring Rusty
well it was 96* in the shade today so it was time to get out there, no literally in the shade, I am now a certified Shade Tree Mechanic or is it Technician, LOL
06-11-2015, 07:17 PM | #1929 |
Post Whore
Re: Restoring Rusty
so got those weld beeds ground off from the rear end of the bed floor where the sides were welded down to it
06-11-2015, 07:19 PM | #1930 |
Post Whore
Re: Restoring Rusty
and the other side
06-11-2015, 07:24 PM | #1931 |
Post Whore
Re: Restoring Rusty
then it was time to flip the bed floor over and work on the underside - you know the side that no one sees but The Greg must spend half a day on, grinding, washing, wire wheeling, scrapping, aciding, and cleaning some more
I got going then I decided I should take some pics, so in the first two pics you can see from left to right how I started cleaning it, and then the last 18 inches or so still were left to clean apologies for some pics not turning out, the sun was relentless |
06-11-2015, 07:28 PM | #1932 |
Post Whore
Re: Restoring Rusty
I took the sides of the bed out and laid them out on the lawn so they won't get even more scratched and beat up, both sides needed some hammering and straitening out a bit in the bottom rears right behind the wheels where those heavy duty diamond plate bumpers attach
06-11-2015, 07:31 PM | #1933 |
Post Whore
Re: Restoring Rusty
it sort of turned into one of those days where I worked on a ton of stuff and busted my butt for a whole day non stop and really had nothing shinny or painted to show for it, you know what I mean
I worked on this piece a little bit, then I moved to another, I wire wheeled some rust off of this piece, then hammered on another, then brushed on some acid on another |
06-11-2015, 07:34 PM | #1934 |
Post Whore
Re: Restoring Rusty
so this is the rusty spot on the back of the cab, see I even wire wheeled this a little bit, I told you I was all over the place
again the sun made it tough to take decent pictures, and I wasn't going to move the truck just so I could, I was too busy being busy |
06-11-2015, 07:36 PM | #1935 |
Post Whore
Re: Restoring Rusty
even got started on the frame, I don't have a pressure washer and I am not a big fan of those (since the time it took the paint off the timing cover of my Harley when I washed it, lol)
so did one top frame rail, before I killed another wire wheel, time to get a new one... AGAIN |
06-11-2015, 09:11 PM | #1936 |
Re: Restoring Rusty
Wow ,you have been busy ,looking good .
06-11-2015, 11:38 PM | #1937 |
Re: Restoring Rusty
You are doing a great job! This whole restoration hobby is IMO 95% elbow grease and 5% money for stuff. We know how much the stuff adds up to - Gregski's thread shows how much that 95% elbow grease adds up to!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
06-12-2015, 02:08 AM | #1938 |
Post Whore
Re: Restoring Rusty
06-12-2015, 02:14 AM | #1939 |
Post Whore
Re: Restoring Rusty
Thank you Rick, well said. This is the most enjoyable vehicle I have ever worked on, for those of you considering a project who don't own a truck yet and are just looking, I totally recommend a squarebody ie 1973-1980ish truck I prefer the round headlights so I stay with the first have of the 1973-87 third gen trucks. They are still cheap but are definitely becoming harder and harder to find. Aside from my '69 VW Bug I had in high school this is so simple yet so well built.
06-12-2015, 02:42 AM | #1940 |
Re: Restoring Rusty
Yep...I would agree. The simplicity is there...and btw I had a 70 VW in high school.
06-12-2015, 05:31 PM | #1941 |
Post Whore
Re: Restoring Rusty
well it's graduation season, [ahem] promotion I should say, I guess that's the latest buzz word, our kids no longer graduate 8th grade some knucklehead decided they get promoted to high school, what ever
anywho between all the graduation ceremonies I stopped by Harbor Freight and picked up some disposable tools, more wire wheels and this cheap (one use I bet) rivet tool, I plan on using it to close off the hole in one of the wheel housings |
06-12-2015, 05:33 PM | #1942 |
Post Whore
Re: Restoring Rusty
alright so here we go, start out with a manila folder we stole from the wifes filing cabinet, we saw the pros do this on TV so monkey see monkey do
we cut out a template |
06-12-2015, 05:37 PM | #1943 |
Post Whore
Re: Restoring Rusty
then we transfer the shape to the donor metal ie the old bed side we kept just in case (it's wrecked on the other side so please no hate mail)
we did have to hammer a slight curve into it to fit nice and snug, you can sort of tell in the last pic where the piece already has 1/8th holes drilled in it |
06-12-2015, 05:40 PM | #1944 |
Post Whore
Re: Restoring Rusty
then it was time to rivet it in place, I have never rivitted before, but I learned that you just keep clamping on the handle till the rivet stud breaks off, even a cave man could do it
not bad, considerin' this will be all covered with some Herculiner IT'S A TRUCK !!! |
06-12-2015, 08:29 PM | #1945 |
Re: Restoring Rusty
Now epoxy a circular piece (JBWeld for example) into that hole and you won't even have a depression there once the liner goes on.
Rich Weyand 1978 K10 RCSB DD. |
06-12-2015, 09:33 PM | #1946 |
Re: Restoring Rusty
If you have any seam sealer, I'd spread that around all the edges to try to keep moisture out of the overlapped metal before hitting it with the bed liner material.
06-13-2015, 01:35 PM | #1947 | |
Post Whore
Re: Restoring Rusty
I did my best to heat the indents one at a time then quenched it with a bucket of cold water, and nothing really happened, I must be doing something wrong, but it's not a big deal I really don't care about these small indents |
06-13-2015, 03:08 PM | #1948 |
Post Whore
Re: Restoring Rusty
Man I could not find my JB Weld and I know I have some, and I hate buying what I already have, so I used some good ol' body filler and called it good
06-13-2015, 03:14 PM | #1949 |
Post Whore
Re: Restoring Rusty - Herculined the Bed
finally it was time to apply the Herculiner, I couldn't wait to try this product
I decided to use a brush and it worked out really well, using this method the product goes a long way, I am never agian going to spray undercoating out of a spray can this is a manly product, covers well, goes on thick, makes a lovely [controlled] mess where you want it wear long sleeves though so you won't end up with freckles on your arms like me we do the underside first |
06-13-2015, 03:20 PM | #1950 |
Post Whore
Re: Restoring Rusty
well I only had enough to do the underside of the bed floor and as you can see we ran out while trying to cover one of the wheel housings, no big deal I recon the under side of the bed has more surface area than the top since the top does not have the cross 2x4s etc
we shall buy another can of this HERCULINER and paint some more tomorrow morning, since morning is the best time to paint, that will allow the underside to dry completely so we can flip it over tomorrow and start a new |
