12-04-2012, 01:50 PM | #1951 |
Re: PO has me PO'd
Had some time to go back and work on the pcv, still have to install oem diffuser in the valve cover
Air in off of TB will be made out of a aluminum tubing url=http://www.flickr.com/photos/87678561@N08/8244153301/][/url] 20121204_124424 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-05-2012, 03:04 AM | #1952 |
Still plays with trucks
Re: PO has me PO'd
You are correct, it is the cold start injector sensor. They came on 85-88 cars. 89-92 the function was integrated into the ECM. With your setup you can just take it out and put a pipe plug in the hole.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-05-2012, 05:01 PM | #1953 | |
Re: PO has me PO'd
Its even a 1/2" NPT!!
12-06-2012, 11:34 AM | #1954 |
Re: PO has me PO'd
12-06-2012, 12:19 PM | #1955 |
Just a nother gear head
Re: PO has me PO'd
building that tpi looks like a lot of work. im sure theres a few head aches too. I was thinking of that route but now not so much. makes a carb sound so much better. lol
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
12-06-2012, 02:02 PM | #1956 |
Re: PO has me PO'd
12-06-2012, 04:04 PM | #1957 | ||
Re: PO has me PO'd
Carbs are easy, but i couldnt make them work with remote start, or steep angles off road. Maybe by adjusting my fuel pressure down, but that didnt solve the romote start problem Plus, the cool factor....someday englese eight stack Thanks to guys like dale, ive gotten past the humps Wouldve been easier without the vortec heads, and stock valve covers could save some work....although problems with the oem distri. would still have to be addressed
12-09-2012, 12:41 PM | #1958 |
Re: PO has me PO'd
Finally got the ECU installed where i want it, just some fine tuning. Final plans are to drill and tap(1/4-28) the heater control panel mounting tabs
Still have to change angle of the mount a bit, plus add some sorta support to the heater box. Probably a bolt, spacer, and a nutsert Power cable is run to the battery 20121209_113209 by jarosaj, on Flickr
12-09-2012, 12:49 PM | #1959 |
Re: PO has me PO'd
12-10-2012, 04:25 PM | #1960 | |
Re: PO has me PO'd
I did notice that you have a square bore carb on a spread bore intake, dont know if its not sealing up well, and causing a vacuum leak
12-10-2012, 05:06 PM | #1961 |
Re: PO has me PO'd
No, its spread bore on spread bore.
12-11-2012, 02:55 PM | #1962 |
Re: PO has me PO'd
Ok can you butcher a NOS part, luckily it wasnt a 67-72 part! Had to find a place to mount the MAP sensor, its pretty close to the oem location. It will be mounted on the overhang of the cover plate, underneath
Now i just have replacate the three mounting holes along with a shoulder cut. Should be a challenge to make the relief cut. I know its going to want to walk on me! Waiting for the crank trigger mount to be drop shipped in from Mallory 20121211_115821 by jarosaj, on Flickr Sorry to say, but even AC DELCO has parts made in China. Disappointed!, to say the least 20121211_120002 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-11-2012 at 03:12 PM. |
12-11-2012, 04:20 PM | #1963 |
Re: PO has me PO'd
That rear cover is different then mine, but I guess cause that was a maf system.
Putting it under it would give it a nice hidden location!! At one point, I had made a bracket to cover the egr hole in the middle of the base intake, and hold the map sensor at the same time. |
12-12-2012, 04:40 PM | #1964 | |
Re: PO has me PO'd
Now you have me thinking of building my own EGR cover Finished up the cover this morning, just have to mount the MAP sensor
12-12-2012, 05:37 PM | #1965 |
Re: PO has me PO'd
12-13-2012, 10:00 PM | #1966 |
Re: PO has me PO'd
Ok, got the MAP sensor mounted up, and plugged in...onto the crank trigger and wideband O2 sensor. Glad i bought the transfer punches, made transferring the holes alot easier
Could be a problem with the mount of the crank trigger, well see 20121213_134514 by jarosaj, on Flickr 20121213_134729 by jarosaj, on Flickr
12-14-2012, 05:03 PM | #1967 |
Re: PO has me PO'd
Installed trigger mount, of course some problems...the bottom support bolt hits the block, they provide spacers to correct this, but i want to use the spacers only for the in and out of the crank trigger
So, i have another idea... I will be using studs to mount the bracket to the block Top bolt needs thread sealant, as this one goes directly in the crankcase Anyone need a new fuel pump, you pay shipping.... 20121214_113554 by jarosaj, on Flickr Ok, heres the problem...the guide hits the block(threaded portion), really snug fit, so i plan to cut off some of the threads. Counter bore bracket slightly, about an 1/8", cut a groove in the guide for an E clip. Then the guide will be level with the bracket The adjusting rod really keeps the guide in place, but the E clip is just added insurance 20121214_155435 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-16-2012 at 11:45 AM. |
12-18-2012, 03:12 PM | #1968 |
Re: PO has me PO'd
Worked on the injector harness, plug and play...when im done wiring, it will all be wrapped same as oem, with clothe fabric loom in some areas. Wire bundle is getting smaller, have to wait till after Christmas to spend any more money...have buy my ignition box, crank trigger, wheel, and spark plug wires. Purchases gettin smaller!
Opps, forgot fuel system, oh well Issue with air temerature sensor, seems that there was a 1985 only, which i have. Twice the price, my luck holds true. So, i think i will change it to the 86 and later, which is coolant and air sensors the same. Might be easier on the next guy The green wire on the right bank, will go to a senser in the rear of passenger side head Ok heres the mandatory pics, or as you guys say, it didnt happen unless you can show pics 20121218_105738 by jarosaj, on Flickr 20121218_105829 by jarosaj, on Flickr 20121218_105943 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-18-2012 at 04:35 PM. |
12-18-2012, 03:36 PM | #1969 |
Re: PO has me PO'd
12-18-2012, 03:45 PM | #1970 |
Re: PO has me PO'd
huh, that is one I didnt know.
12-18-2012, 04:38 PM | #1971 |
Re: PO has me PO'd
Me neither, but the link you gave me to the tpi parts says its so
12-26-2012, 10:01 PM | #1972 |
Re: PO has me PO'd
Alright, bought the 1985 only, air temp. SEN- 601,since the company wouldnt sell the connector w/o pigtails ( didnt want an unnecessary splice ) side note, fast sells sensors for less
Sensor is for a 305 cu.in., ive got it going in a 350 cu.in., hope that doesnt cause problems in the future... Thank goodness for smart sons with a bridgeport, stopped down for the holidays, and showed him the problem i was having with the water neck not fitting up. With the o ring design on the outlet, it interferred with the intake....his solution was to ship it to him and he could machine the intake allowing the outlet to shift over and align with the studs. Still taking advantage of the swivel oring design. Sweet! Dang smart kid there.... 20121226_122328 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-26-2012 at 11:08 PM. |
12-26-2012, 10:59 PM | #1973 |
Re: PO has me PO'd
You can see it in this pic, intake comes in real close to the water neck. Cant be more than a 1/8", but it might as well be a mile if you cant bolt the part up
01-12-2013, 12:48 AM | #1974 |
Re: PO has me PO'd
Finally got to play with the wifeys christmas presents.....
I did have an ah ha moment in relation to the ecu mount, more on that later The ignition box isnt going to work there, soo, i plan to use the isolation mounts jegs sells. They just give you enough clearance on the curves of the inner fender to mount it there, using the jegs mount for the ignition box. I should say that im not sure how the isolation blocks will handle the constant strain of tension and compression. Ill contact the manufacturer, and see if they have any input Crank trigger and wheel are mounted up, just have to get the oreintation to tdc. Plug and play! Last sensor to deal with is the O2 sensor 20130105_143449 by jarosaj, on Flickr 20130111_133941 by jarosaj, on Flickr 20130111_141902 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-12-2013 at 03:06 PM. |
01-14-2013, 01:06 PM | #1975 |
Re: PO has me PO'd
I think ive finally located the ECU, after 4 attempts to put it under the heater control with varying degrees of success. So, i decided to put it on the heater box. The ecu is slightly larger then the box, so it has to be mounted on a plate first, then the plate can be mounted on the box. Now i can clean up the mounting plate
I used nutserts, and 2" flathead bolts and nuts. The standoff allows me to run the harness up and into the dash area. I dont know how strong the nutserts are hanging off the heater box, so in the near future ill be putting 1/4-20" isolation blocks in to support the weight of the ECU Using a tranfer punch helps to locate the holes, there is a flapper gate in that area to be mindfull of 20130113_112004 by jarosaj, on Flickr 20130113_174519 by jarosaj, on Flickr 20130113_174617 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-15-2013 at 07:25 AM. |
