Old 05-20-2007, 12:05 PM   #176
vtblazer
vtblazer's Avatar
Re: Went to a Bigger Blazer
Originally Posted by Yukon Jack View Post
Are the two tubes that are visible in that pic that go from the frame to the rails the only attachment point for the rails?
Correct, yet another reason to change the current set up.
vtblazer is offline   Reply With Quote
Old 05-25-2007, 05:50 AM   #177
vtblazer
vtblazer's Avatar
Okay, I couldn't leave well enough alone...
The front bumper was killing the approach angle so I lopped it off.
Cut off the front section of a 2wd frame and started fabbing up a new winch mount location that will allow for a stock bumper.
The change in approach angle will be almost 25/30 degrees towards the better.
With the bumper it was around a 40/45 degree approach but this will get it up to about 70 degrees.
More pics as thing's progress.
Old 05-26-2007, 07:18 AM   #178
vtblazer
vtblazer's Avatar
Running a stock bumper again.
Old 05-26-2007, 07:24 AM   #179
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mod
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-26-2007, 08:09 AM   #180
hgs_notes
GEARHEAD
hgs_notes's Avatar
I know you wanted the extra clearance, but wont that stock bumper be a mangled, twisted wreck after the first day of wheeling? They are not very strong and you don't have the end support brackets on. I think this looks better than just bolting a big C channel on it the front, but I've seen the pictures of where you take this rig and I don't think your bumper will survive for long.
I am using this thread as a partial guide for my next project, the Junkyard Jimmy (getting it home later today). Big ticket items will have to wait, but a lot of small things and DIY parts can make a big difference, as you have shown here. I love this truck.
HG
hgs_notes is offline   Reply With Quote
Old 05-26-2007, 08:54 AM   #181
vtblazer
vtblazer's Avatar
HG
Your absolutely correct about the bumper, it's not finished yet for all the reasons you pointed out.
Looking to install the angle brackets today with plans of building a tube structure behind it to try and make it hold up to what lies ahead for the poor thing.
Cause as you stated...where I take it might put a ding or to in it.
Old 05-26-2007, 01:04 PM   #182
watahyahknow
watahyahknow's Avatar
it might be an idea to modify the bottom of the bumper so it goes up towarth the corners , might even get it to look stock .
that way but it will give more room on the corners
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-26-2007, 03:33 PM   #183
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Man, I go away for a just a little while and you do all sorts of cool mods! I love the stock bumper look.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 05-27-2007, 01:27 PM   #184
swyfor5
swyfor5's Avatar
Thank's for the pic's of the slider mounts and cage frame mounts. That helps alot. Your cage mount looks like it has a moveable bushing, how does that work? Do all your cage mounts to the frame mount like that? If so how much clearance inside of the original hardtop do I need for the cage? Also your front bumper design is awesome! What kind of winch do you recommend I get for this type of setup? Hey, thank's alot for all your help!
swyfor5 is offline   Reply With Quote
Old 05-28-2007, 08:36 AM   #185
vtblazer
vtblazer's Avatar
Yep, form and function wins the day.
You know the game...wheel and learn.
Everytime you go out, you figure out/decide on something that could help the next time.
It's never ending...
Old 05-28-2007, 03:15 PM   #186
onetonk5
Cereal Killer
onetonk5's Avatar
I dont get why you changed bumpers....looks like it will be more prone to cause you probs in the future than before. Not doggin ya just dont get it.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-28-2007, 05:25 PM   #187
vtblazer
vtblazer's Avatar
Explain further for me...
What are you seeing happening to it/with it?
Old 05-28-2007, 07:34 PM   #188
onetonk5
Cereal Killer
onetonk5's Avatar
Damnit...i typed a bunch of crap and accidently hit a button and lost it....I liked the way it looked before...much like the bumper I built for my K5 13-14 years ago. It looks like the stock bumper can/will peel if/when you catch an edge. Did you consider pushing the other bumper back to help with your approach? I also see an issue if/when you have a cable issue. I always liked to use my stout bumper kinda like a blind man uses his cane and I dont see that working with what you have now. Plus I think it takes away from the HD look you had going.
Old 06-02-2007, 06:38 AM   #189
vtblazer
vtblazer's Avatar
Noted:
BUT...
The cow catcher up front wasn't working out, so I changed it.
The approach angle that has been gained will far out weigh the thump and bump method of wheeling tenfold out on the trail.
Old 06-06-2007, 07:45 PM   #190
vtblazer
vtblazer's Avatar
Recovery Points
Used solid bar stock welded directly to the frame rails.
Remove the shackles and the bumper still unbolts.
Old 07-07-2007, 03:38 PM   #191
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Hey VT how much would you charge me to make the winch frame you got?
Angelse68cal is offline   Reply With Quote
Old 07-08-2007, 07:29 PM   #192
vtblazer
vtblazer's Avatar
Dunno, let me ponder it.
Old 07-18-2007, 12:46 AM   #193
swyfor5
swyfor5's Avatar
Any more changes to your new front bumper setup? I really like that idea, with the winch tucked behind like that. I want to put a stock looking bumper setup on mine, but need recovery points, etc. Awesome dude!
Old 07-18-2007, 07:20 AM   #194
vtblazer
vtblazer's Avatar
Yeah...I finally finished it!
Built a tube structure behind it out of 1.75 DOM
Looks like a crazy structure but it should be fairly stout.
Bumper still bolts/unbolts for easy access.
Old 07-18-2007, 07:39 AM   #195
That`s tough.Something like that would be nice on my Highlander.
Old 07-18-2007, 09:21 AM   #196
Yukon Jack
Post Whore
Yukon Jack's Avatar
I had no idea you put all that behind the stock bumper - now that's STOUT!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-18-2007, 09:40 AM   #197
Burt4x4
Burt4x4's Avatar
Never seen that beeffer VT Not the hidden winch but the bumper behind the bumper idea idea
The way I deal with approch angle is More Throttel:
hahahaa
The main thing I like about my bumper is a place to stand when working in the engine bay.
Nice work bro!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 07-19-2007, 07:04 PM   #198
johnnywagon
As if I have'nt seen enough great fab ideas here, I guess I'll just ad this one to my dream list.
Impressive VT!
~John
71 Blazer One Ton
59 Belair 2 Door
Old 07-21-2007, 12:07 AM   #199
swyfor5
swyfor5's Avatar
vt, that front bumper setup is awesome! I need to put new bumpers on my 70 k5, and want to go with the stock looking setup. Man, you should really think about making that support and selling it to us less handy guy's! I know there's a lot of variables from truck to truck, but I would like to be first in line. Just awesome design and fabrication work! Think about it! Thank's.
Old 12-28-2007, 02:05 AM   #200
vtblazer
vtblazer's Avatar
Have another mod that didn't make the thread yet...new rock sliders.
(thought I had already posted this...)
Long/short of it:
Found 5 inches of metal that could go away along the body.
It's about all you can cut without loosing the floor boards while still making the attempt to keep thing's looking like it's a K5.
(barely hanging on in that department)
