Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-27-2009, 10:36 PM   #176
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 72' Stepside 2 1/2 Rockwell Pond Truck
I WANT THAT TRAILER! Do you know anything about that tailer?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 04-28-2009, 08:32 AM   #177
BIG HEAD
Originally Posted by LONGSWHEEL View Post
HEY THOSE ARE 18.4-30 TITAN R2'S, ON A 20 WIDE WHEEL.
What more does a person need? I LIKE......
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 04-29-2009, 01:39 PM   #178
LONGSWHEEL
Have you painted the cab yet?
LONGSWHEEL is offline   Reply With Quote
Old 04-29-2009, 02:44 PM   #179
BIG HEAD
No man, I have not touched it in two weeks. I have a ton of things going on.
Old 04-29-2009, 03:07 PM   #180
LONGSWHEEL
I understand that. Been tryin to work on my bog truck but just don't have the motivation after work.
Old 04-29-2009, 08:10 PM   #181
BIG HEAD
Are you the guy with the jeep and v-treads?
Old 04-30-2009, 07:38 AM   #182
LONGSWHEEL
Yep that is me.
Old 04-30-2009, 08:27 AM   #183
BIG HEAD
Yep that is me.
Joey Sigman and Hubey introdusted us a Pudddin' Creek. Hubey told me you built his wheels.
Old 04-30-2009, 11:03 AM   #184
LONGSWHEEL
How drunk was i?????? Were you over there saturday night?
I think i remember you, but they introduced me to alot of people.
Yes we widened out his wheels and blasted them.
Old 04-30-2009, 12:14 PM   #185
BIG HEAD
How drunk was i?????? Were you over there saturday night? It was Friday nite
They look good.
Old 04-30-2009, 12:17 PM   #186
LONGSWHEEL
Thank you
Old 04-30-2009, 12:31 PM   #187
BIG HEAD
Longswheel u a fan of 67-72 chevys? Got one? I got my build on chucks to but there is to much caring on there for me. ( like some of the avatars and language )This site is very kid friendly, i have the additude if my kids can't look at it i probably dont need to either.
Old 04-30-2009, 01:21 PM   #188
LONGSWHEEL
I have a 1972 cheyenne super c-10 swb factory air. It was my daily driver in high school now it needs some work like hood and dripp rail. Florida moisture can kill a truck.
But i am now tryin to build a 1972 blazer on 5 ton. Four link, straight frame, 18.4-30 R2S
Old 04-30-2009, 03:42 PM   #189
BIG HEAD
I like you more and more every day. Any pictures of the blazer?
Old 04-30-2009, 04:08 PM   #190
LONGSWHEEL
I originaly bought a 71 on 38's but it has way to much rust and i mean way to much rust. So i found a stock 72 blazer that i am now doin body work on. I am now buyin all my parts that i need so all i have to do iSbuild when it comes time. But two of my friends bobbY And joey from heavy metal fabrications ARE going to build the frame and do the final build. All i need now is the case and order the steel in.
Old 05-01-2009, 09:10 AM   #191
BIG HEAD
I really like the frame they built on the z71
Old 05-01-2009, 10:37 AM   #192
LONGSWHEEL
It did turn out awsome.
Hey what kind of primer would you recommend using? I am new to the painting world and figured you would know best.
Old 05-01-2009, 10:57 AM   #193
BIG HEAD
I am a Dupont man. Use all the same products. Example; primer, paint, clear, hardner, reducer. Make sure they are the same manufacture and are interchangeable. If you have clean bare metal etch prime first then 2k urthane. Dupont has an epoxy that has an etch in it. I put a coat of that down first then the 2k.
Old 05-07-2009, 11:12 PM   #194
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Just stumbled across your build. Awesome work.
Alan's Classic is offline   Reply With Quote
Old 05-08-2009, 03:35 PM   #195
BIG HEAD
Originally Posted by alan's classic View Post
just stumbled across your build. Awesome work.
thank you very much
Old 05-20-2009, 05:33 PM   #196
nvrsatisfied
nvrsatisfied's Avatar
Originally Posted by BIG HEAD View Post
Leafs are alot cheaper and stiffer. The four link suspention will ride better and you get more wheel travel. The way I built my suspention would be very dangerous on the road. My lower bars are wider at the axle than they are at the frame. What this does is makes the axles walk. If the right front wheel hits a bump and goes up the wheel base on the left side shortens or vise versa. To keep this from happening you need to make your lower bars parallel to the ground. The two lower bars on each axle also need to be parallel to each other.
i have probably donated more hits to your build than any one . i have read over and over, the only part that makes me scratch my head was this comment you had made about when making road worthy. now i understand trucks at this magnatude of a build are not going to see 1,000 mile of highway or paved road life. this is your toy i completely understand. i look at your build and another build off of www.katkustoms.com/projects/ "DOMINATOR build" for inspiration/ideas and how things work. you said your bottom bars are wider at the base and if you hit a bump this causes one side to shorten. and being more parallel with the ground is important. i'm sure this could cause some bad walking if things are way outta wack......
so question time-- the "Dominators" bars are more parallel with the ground than yours, this i understand. BUT what is the highest you can go with your bars before things go bad. . you have not got to test drive this to make your statement true about your setup......BUT being in florida i am sure you have had your fair share of riding in the tall trucks and can spit more knowledge on me than i would even begin to image.
i would still like to have some ground clearance but do want to sacrifice safty...and just to learn. besides the close's i'm get to riding in a big truck is crawling up in my build (sofa king big 71') and making motor noises like i was 5yrs old all over again......
as always keep up the great work and best of luck with the build.....
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 05-20-2009, 10:04 PM   #197
Chevy1TonFun
Grease Monkey
What size hose did you use for the fuel and trans cooler lines?
Old 05-25-2009, 01:17 PM   #198
Big J'72 GMC
wow, that is F^%&*&G amazing, cant wait too see it done
Big J'72 GMC is offline   Reply With Quote
Old 07-13-2009, 11:49 AM   #199
nvrsatisfied
how are things coming along on this sweet project........
Perry, Ok.
72 cheyenne super
55 chevy truck
Old 07-15-2009, 07:29 AM   #200
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Hey lookin good!
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
