Old 05-06-2011, 07:47 PM   #176
greg65
greg65's Avatar
Re: Greg65 build thread
Nothing yet. When the engine and transmission come back out I will have to drill and tap the hole. Other than the alternator getting mounted today, very little progress. Hoping my power steering pump comes in Monday.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 05-10-2011, 09:06 PM   #177
greg65
greg65's Avatar
Got all the accessories for my serpentine system mounted today. I still have to measure for the belt and make up the power steering hoses. Looks like i'll be borrowing a page from Alan's truck and using -an fittings on my hoses.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-10-2011, 09:07 PM   #178
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Lookin' good Greg!!
Alan's Classic is offline   Reply With Quote
Old 05-21-2011, 01:09 PM   #179
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Truck is really shaping up keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-21-2011, 09:37 PM   #180
towersddg9
towersddg9's Avatar
955K6 is my guess on the belt
towersddg9 is offline   Reply With Quote
Old 05-22-2011, 09:18 PM   #181
greg65
greg65's Avatar
Thanks, I try to work on it when I get extra time but usually not enough to post.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-22-2011, 09:21 PM   #182
greg65
greg65's Avatar
I will keep that in mind. First I need to finish up the power steering lines. Sounds like a good excuse for a trip to Summit racing for the rest of the -6 AN fittings and braided hose.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-22-2011, 09:41 PM   #183
65Custom
Wow Greg great to see you making progress, that motor is looking sweet, nice details
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 05-23-2011, 07:41 AM   #184
greg65
greg65's Avatar
Plans were for a 5.3 with the 700r4 that is already in the truck but it looks like I will be using my little 400 c.i. engine instead. Some changes will have to be made to the engine to make it more drivable but that will come in time. How is your truck coming?
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-23-2011, 10:05 PM   #185
65Custom
I got the roof panel off and have most of that ready to go back on, I have a few things left to before I get that back on, need to clean the underside and coat it with some POR type stuff and them gonna coat it to deaden the sound and insulate it before going back on, but that has to wait a bit I have some big changes coming in my life i hope to get back on it sometime in the next three months
My Build Thread
I must be
Old 05-24-2011, 10:13 PM   #186
greg65
greg65's Avatar
sounds good Kevin. Good luck with the changes you will be making.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 06-08-2011, 07:49 PM   #187
greg65
greg65's Avatar
Last night I started working on my power steering lines. After seeing braided lines on a friend's street/strip truck a few years ago I knew this was a upgraded that my truck would have. Also after seeing them again on Alan's truck my mind was made up. The pressure line is completed and waiting to get the fitting for the return line. After reading Alan's build thread Aggie91 posted a part number for a fitting that looked perfect (parker 6 xhbu-s). Here is a list of the line and fittings I used so far.
All are -6an Russell Performance numbers:
632610 powerflex hose six feet length
1) 648050 -6 to 11/16" -18 inverted flare
2) 640380 -6 to 5/8" -18 inverted flares
3) 620421 -6an 90 degree endura shine hose ends
Hope this helps
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 06-08-2011, 09:28 PM   #188
Alan's Classic
Looks great Greg!! Did you fit the inner fender for clearance? It looks like it should be good. Looks better than mine.
Old 06-09-2011, 07:51 AM   #189
greg65
greg65's Avatar
Thanks Alan. Yes I bolted up the radiator support and drivers side inner fender to make sure the clearance was correct. I also had to bolt on the fender to see how big of a difference the two inch springs made opposed to the 1 1/2 inch springs I took out. After the rest of the front sheet metal is bolted up it should sit about right. Today i'm trying to run down the last fitting to complete my power steering return hose.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 06-09-2011, 01:13 PM   #190
56taskforce
56taskforce's Avatar
Looking really good nice plumbing work. You may already have a plan here but for your retune line at the pump you can use a AN hose union shave the threads off one side drill the hole in the side that you took the threads off so that it slips tightly over the hard line at the back of the pump and use silver solder to sweat fit it in place.
56taskforce is offline   Reply With Quote
Old 06-15-2011, 03:59 PM   #191
sdailey
The Few, The Proud
sdailey's Avatar
Hey Greg,
Look what I've got. I'm mailing it tomorrow, along with your dizzy.
Shannon
sdailey is offline   Reply With Quote
Old 06-15-2011, 04:29 PM   #192
greg65
greg65's Avatar
Originally Posted by sdailey View Post
Hey Greg,
COOL. Now I can get the p/s line completed. You don't know how much I appreciate you finding the fitting for me. Let me know if I can return the favor.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 06-15-2011, 07:38 PM   #193
sdailey
The Few, The Proud
sdailey's Avatar
Just glad to be able to help. Thanks for letting me use the dizzy for my mock up.
Shannon
Old 06-15-2011, 09:02 PM   #194
56taskforce
Or you could just use that compression to AN fitting that Shannon is sending you LOL
Old 06-16-2011, 08:05 AM   #195
greg65
greg65's Avatar
I think this fitting is the best fix for my skill set. Will try to post pictures and part numbers when completed.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 06-16-2011, 12:15 PM   #196
56taskforce
I Worked in hydraulics for some time and that is the first time I have seen a fitting like the one, Shannon came up with there. I could tell by the more squared off end of the nut that it was a compression fitting but that is the fist I seen that configuration tied to an AN-male, cool deal. Must be from the automotive specialty aftermarket. You bet post the manufacturer and P/N for sure.
Old 06-16-2011, 12:20 PM   #197
56taskforce
BTW a Marine saves the day Semper-Fi Shannon
Old 06-16-2011, 02:43 PM   #198
Dinos63
chevy only
Dinos63's Avatar
Nice work!! Kat
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-17-2011, 11:32 AM   #199
sdailey
The Few, The Proud
sdailey's Avatar
I'm sure Greg will post a list of parts used for this phase of his build but since I have the part # handy for the fitting I'll go ahead and post it. Hopefully he won't mind.
The fitting is a Parker #6 XHBU-SS.
Just trying to give back a little. I've gained so much info and help from this board and its members, that I try to pitch in where I can.
Semper Fi!
Shannon
Old 06-17-2011, 11:39 AM   #200
FRENCHBLUE72
PROJECT 7DEUCE
Where does one get the parker fitting? Also the new hose set up looks great but I think Id look for some nicer clamps??
MEMBER #6377
Project "7DEUCE"
