Old 04-21-2010, 07:30 AM   #176
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project: Recycle
Nice work Scoti
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-03-2010, 11:03 AM   #177
SCOTI
SCOTI's Avatar
I picked up a couple of parts @ the Pate swap meet this weekend that were needed. I got the BBW sheet metal needed to get the conversion process under way.
I got the bulk of a rear cab section & whittled it down to a more manageable size. From there it was the drill, pry, & split routine (over & over.... & over again ). A couple hours later I was done.
I hope to get started on removing the small window sheet metal this week & my buddy has cleared a spot in his shop to get some fresh interior color sprayed....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-03-2010, 11:27 AM   #178
joe231
joe231's Avatar
Cool!!!
CHEVY ONLY
Old 05-03-2010, 02:24 PM   #179
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice can't wait to see the BBW install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-03-2010, 02:37 PM   #180
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I suppose I am just a pervert from way back, but BBW means something completely different to me.
Old 05-03-2010, 02:49 PM   #181
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
That's funny right thar, I dont care who you are, that's funny!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-03-2010, 02:54 PM   #182
Tx Firefighter
I'm just saying if you do a google search on BBW you will find what I'm more familiar with and it doesn't mention old truck windows anywhere.
Old 05-03-2010, 03:09 PM   #183
SCOTI
SCOTI's Avatar
Hhmm.... Is it just me, or does TX seem to know an awful lot about this 'other' BBW definition?? For some people, "way back" means last week when the bar closed on Sat night .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-03-2010, 04:19 PM   #184
Tx Firefighter
Hey I'm an old chubby chaser from way back.
Old 05-03-2010, 08:58 PM   #185
joe231
joe231's Avatar
CHEVY ONLY
Old 05-04-2010, 10:16 AM   #186
N2TRUX
Happy to be here
N2TRUX's Avatar
I think your sharing a bit too much Kevin...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-04-2010, 08:58 PM   #187
Tx Firefighter
Geez , I'm not saying I am a trench coat wearing perv, I just dated a few fluffy girls over the years.
Old 05-04-2010, 09:00 PM   #188
joe231
joe231's Avatar
CHEVY ONLY
Old 05-04-2010, 09:58 PM   #189
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Wow, totally the wrong (or maybe perfect) time to open up this thread for a read. SCOTI, very nice work so far, with so much attention to detail the end result is sure to be stunning. Subscribed for the ride.
fryer1979 is offline   Reply With Quote
Old 05-05-2010, 01:05 AM   #190
SCOTI
SCOTI's Avatar
I got a little more done tonight but didn't take any pics.
I wanted to add some reinforcement plates for the R&P notches which requires some 're-work' the pass side front frame rail where the OE idler arm mounts on 67-72 frames (earlier frames don't have the dimples for the idler arm).
My plan is to sandwhich the original portion of the frame immediately surrounding the notch between 2pcs of .1875" steel. This requires the frame to be as flat as possible so those 'dimples' had to go. I removed that portion of the frame & replaced it w/some flat steel (I used a section of the scrap frame for the flat piece).
While re-working the area, I re-shaped the area on the top of the frame rail where it curved 'up' (I believe this was OE for fuel pump clearance on 292's & 396's). I flattened the top portion of the frame to be symmetrical w/the driver side. I also trimmed the rails up a little for a nice clean edge when transitioning from the upper a-arm/bag mount to the radiator core support area of the frame rails.
I got the outside portion of the rail cleaned up after the welds were cooled; still need to do the inside. I also made my templates for the plates that will sandwhich the notches. I'll get some pics up tomorrow.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-05-2010, 06:09 AM   #191
63sbssbbw
UCA63
63sbssbbw's Avatar
You guys are too funny
I've had to explain my board name once or twice
Looking great Scoti,Am I to assume that you'll be bonding the inner pinch weld or ?
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 05-05-2010, 08:55 AM   #192
SCOTI
SCOTI's Avatar
T
Yes, that's the current plan.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-05-2010, 11:34 AM   #193
8mpg
8mpg's Avatar
Hey Scoti... crazy question, but what steel/scrap yard are you using? I have always used Garland Steel, but man..last time I left with 64lbs of drop steel, I paid like $60. Alum would have probably been more.
8mpg is offline   Reply With Quote
Old 05-05-2010, 11:59 AM   #194
SCOTI
SCOTI's Avatar
Garland Steel is the closest to me so I do get most metal from them. I recycle my old scrap w/my GF's family owned company as they have a scrap container. They also supply me w/some certain parts/pieces if timing & inventory allows. They made my rear c-notches & my air-ride control panel FOC..... Well, I live w/their daughter so not exactly free .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-05-2010, 01:34 PM   #195
Tx Firefighter
You guys need to come on over to Fort Worth. My steel yard gets 30 cents a pound for drops. Westex off North Main in Ft Worth.
Old 05-05-2010, 01:57 PM   #196
8mpg
8mpg's Avatar
Thanks man...I will check them out. Much closer. Im in Southlake. Garland Steel is 35 miles from me. I think Im going to just build my notch for the frame with the last bit of steel I bought from Garland.
edit/// They are 28 miles from me...little closer. Im in NRH all the time at the woman's place.
Thanks for the reply Scoti...
Old 05-11-2010, 12:05 AM   #197
SCOTI
SCOTI's Avatar
Alright.... A little more progress.
Friday I got the truck loaded up & got it moved over to a friends shop. He'll be letting me utilize some shop space to do the small to big back window conversion. We'll also be painting the interior while it's there & his glass guy will pop in some fresh front/rear glass.
I still had a couple of things that needed to be finished on the frame. I needed to weld in some .500" solid rod on the rear bend of the rear c-notches. With the insight of Lakeroadster, the rear bend was determined to be the 'weak-point' of the re-worked c-notches. The solid rod will help re-inforce this possible stress point. While I had the frame flipped to do the rear, I also finished welding the bottom edge of the R&P c-notches in front.
I'm in the process of making re-inforcement plates to help strengthen the frame area adjacent to the R&P notches & will try to get those finished up in the next couple of days.
Pics of the solid rod welded to the rear bend of the rear c-notches....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2010, 12:19 AM   #198
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Haha know when to say when on the frame stregnthing it gets addicacting! Looks good!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-11-2010, 12:29 AM   #199
SCOTI
SCOTI's Avatar
The strength/stress analysis he did indicated the rear would still have a stress point @ that rear bend so the solid rod was needed.
The front notches are what 'everyone else' is installing w/their Dropmember installs. I decided I would prefer the frame around the notched area to be re-inforced. That's about it.
I meant to take a couple of pics from where I smoothed the side of the frame rail & 'removed' the curved portion on the top of the frame but forgot....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2010, 06:44 AM   #200
darkhorse970
darkhorse970's Avatar
That is certainly going to be a stout notch! I'm interested in seeing the finished product.
As for the BBW conversion, I'm still pondering mine and am anxious to see step by step progress pics on yours. Don't forget to take the pics...
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
